Question about Sony PCS-1 (PCS1) Video Conference
How can we connect the sony pcs-1 to a pc? - Sony PCS-1 (PCS1) Video Conference
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 66 Answers
GO TO A SHOP AND GET THE CORRECT LEAD,OK,MATRICK.
Posted on Sep 24, 2013
  • Richard David Walden Sep 24, 2013
    GO INTO A COMPUTER SHOP AND GET THE CORRECT LEAD NO PROB,OK,MATRICK.
2 Suggested Answers
  • 3 Answers
SOURCE: Sony PCS-1 Video Conference
in order to help you:
- are you behind a firewall?
Sounds a lot like a firewall issue.
You may contact us for free troubleshooting:
Contact
Furthermore this is our detailed PCS-1P page.
Best regards,
Andy
Posted on Feb 19, 2009
We have a network that is split into 2. Example
Hi,I understood taht you have 2 n/ws.192.168.1.x haveing all static addrsss & 192.168.3.x have all dynamic address.
Sol:
There are many reasong, but we wil try to start with basic testing
  1. You can try with Ping, if it replying or request time out ..You might need to check your Windows firewall.
  2. Try the following commnd c:\tracert 192.168.3.x .let see if you can reach to mention network, try it as vice versa...
try above procedure & let me know if it work..
Please rate this , i f you like....
Thanks
Sandeep
Mar 09, 2011 | Microsoft Computers & Internet
Tip
Using Zyxel P-600 from two PCs
to use Zyxel router/modem from two pcs for internet usage : it has two ports 1 is USB 2nd is Rj-45 connector LAN port
connect it with one pc via USB cable and connect 2nd via LAN port using Cross cable then its one DSL connection from two PCs.
i am using it and it working good.
on Apr 20, 2010 | Computers & Internet
My psp won't recognized by the computer every time i insert the usb.
Well does your PSP recongnise other PCs?
Do you have other MSs?
Try other USB ports.
Try other PCs.
So it won't show up when you plug in your PC.. or... does anything pop up when you connect your PSP to your PC?
If this doesn't work, take it to SONY. If your PSP is still under warranty, then the repair is FREE.
.. wait, did this MS come with your PSP when you bought it?
Nov 09, 2009 | Sony PlayStation Portable (PSP) Console
LAN Error in Sony PCS-1 Video Conference
Sounds like you are either working on a network which must provide you with an IP address automatically (i.e. not permitting static entries), or you are incorrectly configuring the information for your static address.
Is there a requirement to use a static address, or will DHCP work just fine?
Jul 10, 2009 | Sony PCS-1 (PCS1) Video Conference
3com 8 port hub not connecting to 2nd pc
Be sure that when you say its a hub that is indeed a layer 1 device which is just passing the signal and data along to all ports. Be sure to check the cable on the second device. At this point it must a straight cable you use to connect the PCs to the Hub. PCs transmit on pins 1 & 2 and Receive on 3 & 6. Hubs are the opposite. So a crossover will not work. You need PC pin 1 & 2 Tx to Hub Pin 1 & 2 Rx and over to PC pin 3 & 6 Rx to Hub pin 3 and 6 Tx. Tx = transmit and Rx = Receive. Also assign an IP address on each machine that is in the same subnet as each other. Such as PC1 192.168.1.100 mask 255.255.255.0 and PC2 IP address as 192.168.1.101 Subnet Mask 255.255.255.0 This way the 192.168.1 is the same for 8 PCs and the only change is the last number (octet). Also keep the speeds at either 10/100/1000 what ever the product is rated for but always keep the duplex half. Half is good because on a layer 1 hub, everyone is broadcasting at the same time. So you have to have half of all the ports listening at all times.
I hope this helps. My advice is to buy a layer 2 switch.
Mar 18, 2009 | 3Com OfficeConnect TP800 8-Port Ethernet...
Which mdel in Polycom is compatible with Sony PCS 1, which is better.
Basically every Polycom is fine - as long as software is a current release!
Dec 16, 2008 | Sony PCS-1 (PCS1) Video Conference
Bouth it used need disc to make it easier to download music with direct connect
Metro PCS just as Sprint PCS does not use the same GSM network as AT&T or Verizon Wireless.
PCS is a completely separate wireless system. The phone MUST be compatible with the PCS communication platform to work properly, in other words it must be able to connect at the proper frequency bandwidth that PCS connects to. GSM uses the 900Mhz frequency range and PCS uses the newer 1.9Ghz.
The 800i does not support the PCS frequency so most likely you will not be able to use it with a prepaid Metro PCS SIM card. There is only T-Mobile prepaid that you can use with the available frequency connections.
As for accessories, there are several places to find adapters, the Sony Ericsson website still carries most components although they a bit more expensive, you are getting genuine Sony hardware. The download software suite can be obtained for free from the Sony website. The software makes transferring files from your PC to phone easier and allows you to change the sampling rate for MP3 files so that you can store more music for your listening pleasure.
I have a similar model Sony phone the W600i and have yet to have a problem with it (2.75 years old). The memory storage is only 256MB, however with reducing the music sampling rate to 64kb from 192kb it allows me to store around 8 hours of music, enough to fly to Europe or South America. The camera has a lot of features found in regular digital cameras like:
White balance
Appeture setting
Date Stamp
Sepia Tone
B/W image
Panoramic Image (Great feature)
Hope this helps you out.
Keith
Oct 16, 2008 | Sony Ericsson W800i Cellular Phone
DLink DIR 625 Wireless Router
It is the wireless computer setup with the same network name?
Feb 08, 2008 | D-Link DIR-625 (790069292637) Wireless...
PCS-1
Reset password sony pcs-1
1. Access the Setup menu as follows:
Press and hold the MENU button on the remote commander.
2. Select Dial using the �� button on the remote commander.
3. Access the Service menu as follows:
Press 7 then 2 on the remote commander (without pressing the
PUSH ENTER button).
The Service menu appears. (See Figure 1.)
NOTE: To cancel Service mode and return to the Setup menu,
select Cancel using the arrow buttons, and press RETURN.
Jan 18, 2008 | Sony PCS-1 (PCS1) Video Conference
check for your lan settings, try to see if there is no nat on one of your network make the nat settings
Jan 11, 2008 | Sony PCS-1 (PCS1) Video Conference
Sony PCS-1 (PCS1) Video Conference Logo
484 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
