Question about Sony KP-57HW40 57" Rear Projection Television
Kp-57hw40 screen goes bright red or green then powers off
I have this problem posted already, but am looking for the info that Sony extended warranty until Aug 08. I called Sony, got the normal commentary of being out of warranty. The pots on front work to remove the lines, not necessarily fix the powering off situation. I can't figure out whether i have one or two or zero crt's going bad, since the problem switched from red to green. Originally it always flashed bright red, now after tinkering, it goes bright green. TV still comes up when re-powered and has a great looking picture.
    President:
  • 4,402 Answers
Http://esupport.sony.com/perl/news-item.pl?news_id=24
heres a recall of sony hope it helps.
Posted on Jan 02, 2008
Sony rear projection kp-577hw40, screen turns red after being on for 10 minutes
This model and some others had bad picture tubes that are no longer available---there is an option here.
If screen gets bright red, green, or blue set will shut down as it detects too much current being drawn.
Seen over 100 with this issue--what can be tried and usually will help is a physical adjustment inside the set.
No parts to replace and takes about 15 minutes to do.
I can tell you how if you want to know.
Jun 13, 2012 | Sony KP-57HW40 57" Rear Projection...
My sony kp-57hw40 projection tv picture is not as bright as usual. There is blue arc lines that show up at the bottom of the screen.
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 07, 2010 | Sony KP-57HW40 57" Rear Projection...
The screen is all bright blue
I have Model # KP-WS500. The screen turn blue.
May 02, 2009 | Sony KP-57HW40 57" Rear Projection...
Sony Color Rear Video Projector - KP 57hw40 / Mfg. February 2002
i have the same problem picture is blue/green with blue and green arched horizontal lines
no picture at all only sound then tv shuts off after 5-10 seconds and then a bright blue flash in the center of the screen
have tried adjusting the voltage screws didnt do anything
Jul 13, 2008 | Sony KP-57HW40 57" Rear Projection...
Green screen
sounds like your green crt is shorting let me know if you need more assitance or if you would like to know where you can purchase a crt at.
Apr 10, 2008 | Sony KP-57HW40 57" Rear Projection...
Sony kp57hw40
Reset RGB screen controls....located behind lower front speaker
grill & access cover.....turn down ( CCW ) green screen slightly
and other two colors as needed.....T.
Mar 05, 2008 | Sony KP-57HW40 57" Rear Projection...
Sony KP-57HW40 Error Codes 6 & 8
ITS PROBABLY THE RED PICTURE TUB (CRT). IT LOOKS EASY TO INSTALL, BUT YOU NEED TO MAKE ADJUSTMENTS TO THE SCREEN ONCE IT IS INSTALLED. THE PART IS $3OO. TRY TO FIND SOMEONE TO INSTALL IT FOR $150 OR LESS. HERE IS A WEBSITE TO HELP YOU MAKE ADJUSTMENT IN THE FUTURE ON YOU OWN.
PRIDAH
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Nov 10, 2007 | Sony KP-57WS500 57" Rear Projection...
Red Screen
Sounds like the red color tube is goeing bad you wil hafto call in a tech to conferm it Sony is noted for tubes goeing bad, in the future leave sony alone
Sep 24, 2006 | Sony KP-57HW40 57" Rear Projection...
Sony big screen
is the pic bright red or dim with no video and small faint red lines??? if the picture is there then it sounds like the red screen on the High voltage block may be turned up a bit to high. Was somebody tring to focus the pic latly>> need more info please>
May 05, 2006 | Sony KP-57HW40 57" Rear Projection...
Sony KP-57HW40 57" Rear Projection Television Logo
154 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
