Question about Plumbing
Why does my saniflow continuously come on even
Why does my saniflow continuously switch on, roughly every 25 minutes, even though there is no water going into the saniflow
    Sergeant:
  • 399 Answers
Could be a part blockage alowing water to filter back never put paper or towles in it
Posted on Nov 14, 2009
On my new KENMORE elite top loading washer it will not move past 29 minutes on any cycle. It just slowly spins and continually adds water. How do I fix this?
CHECK THE WATER PRESSURE SWITCH BUT MORE LIKELY U HAVE A STICKING TIMER. OR BAD CONTROL BOARD. FOR CONTINUALLY ADDING WATER THOUGH I WOULD CHECK THE WATER INLET VALVE?
Mar 23, 2015 | Kenmore Washing Machines
Saniflow runs, but not straight after flushing
Here is a nice link for your saniflow maintenance.
http://www.plumbteamltd.co.uk/sanifloguide.html
This will definately help.
Jan 30, 2013 | Saniflo Home
Saniflow keeps blocking with hair
It is but this is something you must put up with. Make sure though everything is tightened well.
Jan 23, 2013 | Saniflo & Saniplus& Macerator Pump
Saniflow macerator
Depending on the pump model it can be that the float switch (membrane) might be warped or solids could be build up at the bottom which dont allow it to shut off. You wil have to open up the unit, remove the motor with pressure chamber and inspect it.;
Aug 02, 2012 | Saniflo & Saniplus& Macerator Pump
Involuntary flushing operation occurs every 10 minutes
hi,
i was having same problem with my sanicompact48,it was flushing continuously after few minutes.i opened and cleaned every thing still it was the same thing.and i noticed irreguliar flushing due to SOLONOID VALVE.just replaced and works fine.yo can order by phone # 1 800 571 8191 to "saniflow".tale them your problem and your toilet model.
good luck
garry
Sep 06, 2010 | Elite Saniflo SaniCompact- SaniCompact One...
Full water indicator lit continuously even though
Problem was a stuck float in the small water reservoir to the rear left of the unit.. Remove top and left hand side panel. Small reservoir can be seen at the bottom left. Remove small screw and slide off the cable assembly above. You should then see into the reservoir and the float. Clean float and reservoir and reassemble.
Feb 08, 2010 | Zanussi TC7114W Electric Dryer
Ice maker makes even though Switch is OFF
replace ice maker. the cost of a service call.part's and labor would exceed the worth of the unit.
Nov 16, 2009 | Refrigerators
Shower tray is low and fills before saniflow kicks in cant alter height of tray
See if you can adjust the highth of the saniflow,to make it kick on sooner. goodluck.
Jul 13, 2009 | Saniflo 013/005/007 Sanibest Toilet with...
My laptop keeps switching off by itself even though its fully charged, keeps switching off roughly every 10 minutes. the laptop is quite new and this has not happened befor.
I would look at the power settings located under control panel and if you are running the laptop from the battery these are set usually in minutes I use different setting for wall power and battery power
Jan 24, 2009 | Computers & Internet
Plumbing Logo
75 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
