Question about Frigidaire Affinity ATF7000ES Front Load Washer
Error code PF when dryer is running. I think the
Error code PF when dryer is running. I think the dryer thermostat may be shot. But want to make sure before I call a repair man. Can anyone help?
    Genius:
  • Frigidaire Master
  • 1,461 Answers
Make sure the fan motor is running....
Posted on Sep 28, 2009
Start for just 1/3 second then stop with error PF ?
Hey Andy, thank you for your post!
From what you have described your Frigidaire dryer, GLEQ2152ES, is running for a few seconds and then displaying an error code of "PF". The error code of "PF" means there is a power failure and this could be an issue within your control panel or power source. I would suggest performing a reset, this could help clear our any miscommunications within the panel, and you can do this by disconnecting the power cord for at least ten minutes. I hope that this information is helpful towards your repair. -Matt
Feb 17, 2016 | Frigidaire GLEQ2152ES Electric Dryer
My Maytag Neptune Dryer stopped running & is
as per heatman The most common cause of your appliance giving you the PF error code is a problem with the power coming in from your utility company. Of course if there is an interruption of power, and then the power comes back on you will get the PF code Loose wires going to the circuit board or the control can also be a cause of the error code. If a wire terminal end happens to get corroded or loose, the vibration from the machine can cause slight power problems and this can cause the PF code to be displayed. Finding the cause of this type of problem is like finding a needle in a haystack. Sometimes you can cause it to be displayed by banging on the side of the appliance or slightly moving the wiring harness, to see if you can get the error code to display.
The bottom line about this power failure error code, is that it is power related. Finding the exact cause can be difficult. If you are continually having to reset the appliance then check to see if all of your appliances are giving the same code. This will indicate utility power problems. If only one appliance is giving the PF code then it is probably internal to the appliance.
Jul 12, 2011 | Maytag Neptune MDE5500AY Electric Dryer
My whirlpool dryer is getting an error code pf. What does that mean?
Here is a tips that I wrote that will help to explain why you get the PF Error Code
PF Error Code for Appliances
heatman101
Jul 19, 2010 | Whirlpool WED8300S Dryer
PF Code as soon as try to start dryer, you get the code when select the time
heatman101
p[[p
Mar 14, 2010 | Whirlpool WED6200S Electric Dryer
The dryer runs for a couple seconds and then give a PF code which I think means power Failure. brand Frigidaire
that is a power failure code. check the main cisuit breaker and the cord to the dryer and make sure the connections are tight.unplug the unit for a few minutes and plug it back in this should clear the pf code out.
Feb 22, 2010 | Frigidaire AEQ6000ES Electric Dryer
Error code pf
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 01, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
Error code PF
PF means power failure. Check your electrical connections and voltage for proper voltage
Jul 09, 2009 | Frigidaire AEQ7000ES Dryer
Whirlpool gas dryer doesn't run. error code pf shows on lcd
pf usually means power failure. Try to clear the screen or hit the off button to clear pf and then see if it works.
Nov 16, 2008 | Whirlpool GGQ8831L Gas Dryer
Washing Machines Logo
165 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
