Question about Olympus FE-210 Digital Camera
Batteries only last a few minutes - Olympus FE-210 Digital Camera
My fully charged batteries for my HP R 707 only last a few minutes and then I get the error message that they are too weak for live view. Any ideas?
Replace the batteries. If they won't hold a charge, they're toast. All batteries wear out eventually, chargeable or not. You might also check the battery contacts for corrosion -- remove any with a small piece of fine snadpaper and blow out the battery compartment with compressed air.
Oct 21, 2014 | HP Photosmart R707 Digital Camera
FULL CHARGE LAST 5MIN. MAX
My guess is the batteries are probably no good. All batteries will only last so long and it also depends how often they are keep charged and discharged. Basically all batteries require some kind of maintenance (recharging / discharging).
Jan 23, 2013 | SPOT SL5W09 Spot Light
Our Super Gaucho 24volts is 2-years-old and barely used. Now the battery is not lasting to long. Is this normal? I mean, with a more frequent charging/use will its performance be improved? Thx ahead &...
Unfortunately the batteries just lose their holding power after awhile, and if you don't keep them charged every few months (like during winter if your child isn't riding, you still need to charge / refresh the battery every 2 months or so, if it isn't charged for a few months, it'll lose some of it's holding power), that's a very common problem. Our 24V Perego batteries for our Gaucho only seem to last like 30 minutes of constant riding (my son rides non stop sometimes for 30+ minutes). If you check out the site modifiedpowerwheels.com , people convert them to use non Perego batteries that run for much longer!
Nov 01, 2010 | Peg Perego Gaucho Superpower
Brand new AA batteries last only a few minutes, i.e. 5 new pictures. why?
Are you using normal AA batteries? i.e. non-rechargeable ones? If so, this is probably why... Digital cameras will **** these dry super fast. You will need to use some AA Nickel Metal Hydride rechargeable batteries (NiMH) with at least 2500mAh capacity to get some decent run time.
Apr 01, 2010 | Kodak EasyShare C875 Digital Camera
Zoom H4 Battery Problem
I am having the same problem with my Zoom-H2. I have 2 2650 mah rechargeables, and the draw is such that 20-30 minutes of record &/or playback kills the batteries. Last night I just turned the power on and did nothing. 5 hours later the batteries were dead...
This isn't a solution. It is a reaffirmation that you aren't crazy!
Jan 05, 2010 | Zoom H4 Handy Recorder
Once it is fully charged it last for a few minutes then switches off
it sounds like the batteries need replaced. batteries can be purchased at shaveroutlet.com. repair services are also available
Dec 22, 2009 | Philips Philishave HQ7780 Electric Shaver
Toshiba wireless mouse cursor not moving!
Try replacing the batteries or if it has rechargeable batteries, try removing and replacing them. Also clean the red lens on the bottom of the mouse with a cotton swab. Good luck!
Mar 14, 2009 | Toshiba Wireless Mouse PA3205U-1ETC
Batteries
This is typical of HP Cameras. Try using rechargeable batteries or remove the batteries when you are not using the camera.
Jun 10, 2008 | HP Photosmart E317 Digital Camera
Bushnell Holosight short battery life, batteries hot
This sounds like a short. Send the unit for factory service!
Jerry G.
Mar 16, 2008 | Optics
Olympus FE-210 Digital Camera Logo
61 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
