Question about Ovens
Good evening, the main oven is getting hot but the fan is not working. A humming noise can be heard
  • Anonymous Mar 25, 2014
    convenction fan works
  • 42 Answers
Your fan unit is jammed.
Posted on Sep 28, 2009
The fan in main oven only blow out cold air
The fan does not produce hot air. It just circulates it. The thermostat turns on the heating element and the fan moves the hot air around. Unless you have an odd working machine. Baked bread for years an it only moves air for even heat.
Jan 31, 2015 | Ovens
I have just moved and the oven is a bosch. I do not have any directions. The top oven and grill works OK but the main oven does not get hot. I can hear the fan but even when the oven has been on for an...
If the fan is working o/k, then it is probably the oven element that is faulty.
This is located at the rear of the oven compartment behind a removeable cover.
Nov 22, 2010 | Bosch Ovens
Oven making whirring noise when switched off
The back panel of the main oven houses the circulating fan. From experience, fat/grease/gunge accumulates and drips down the inside of the plate through the vents. This will then rub on the fan as it turns. There are four self tapping screws, one in each corner of the panel. Remove the screws and the panel will come off. That is the easy bit, getting rid of the grease is harder. Don't forget that the oven side of the panel is a stay clean and shouldn't be cleaned with anything abrasive. I use the Lakeland brush on oven cleaner on ALL the walls of the oven (even the Stay Clean) and it works a treat. It may take some time to disolve the residue and a couple of goes, but it does work.
Apr 20, 2010 | Stoves 720EF Electric Double Oven
Faulty main oven
If the fan is working in the oven, and it is electrically heated, then it will be a faulty oven element.
This is located at the rear of the oven behind a removeable cover.
Feb 10, 2010 | Zanussi Ovens
Hi.i have a hotpoint creda c362e cooker the rings work grill works but main oven and top oven elements dont come on even when lights come on when switched on fan works but no heat could you help me on this...
Hi.
Frpm the sympton's you list, I would say that the main oven element has failed, espsecially if the fan is working o/k.
The element is located at the rear of the oven compartment behind a removeable cover.
In addition to the grill elements in the top oven compartment, there is an additional base element which you can't see.
If you turn the top oven on, the base of the compartment should get hot, if it does not, then the base element has probably failed.
Hope this helps.
Jan 09, 2010 | Creda Ovens
Cold Whirlpool AKZ451!!
You may have had a surge during the storm. Check main control board in console for damage.
Sep 01, 2009 | Whirlpool AKZ159IX Oven
Oven not getting hot
The fan oven element needs to be replaced in the Hotpoint 6150 cooker.
Access is by removing the inner rear cover of the oven, there you will see the element.
Replace with a new one.
It is possible the base element is faulty in the top oven of the Hotpoint EW95,
The other possibility is that the high speed grill element is only part working.You need to check both these elements.
If the fan is working o/k in the main oven , but not getting hot, then you need to replace the element.
If it does heat, then it could be a faulty thermostat or possibly selector switch.
Unless you have a good working knowledge of electrics and know how to use a meter, then I would suggest you call some one in.
Plz rate my solution
Thanks.
Dec 26, 2008 | Ovens
Squeeky noise while baking
If it is a fan oven then it could be a noisy fan bearing
Nov 17, 2008 | GE Ovens
Ovens Logo
69 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
