Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Compressor seems to be cycling all of the time
Kenmore model 363-9554710, the freezer has frost on the itmes on the freezer and the fan on theback is running non-stop. The compressor also seems to be cycling on and off every few minutes but it does not stay on. Don't know if it is self-defrosting or if there is a problem. It was quite full and I have moved some of the items to the dep freeze to see if that will help. We also have indoor dogs so I have cleaned the coils but they did not seem too bad. It was working fine this morning it appeared and then came home for lunch and it was clicking on and off. Help and tell me what to check.
  • Kenmore Master
  • 3,361 Answers
Hopefully your compressor is still good.
Replace the compressor start relay. It attaches directly to the compressor. If it has a capacitor attached to it,replace that too.
Posted on Sep 28, 2009
I have a Kenmore Elite model no is 59673502201 and it stop cooling in both the frig and freezer i replaced the condenser fan motor and it worked so i replaced the back and the unit will STILL NOT GET
Do you hear your evaporator fan running in the freezer drawer area?
If not, then that's the fan you should have replaced.
If your compressor is running and both the compressor fan and the evaporator fan are running, check the back wall of your freezer compartment. If it is frosted up, then you have a defrost problem.
If it's not frosting up, disassemble your freezer drawer section and remove the back panel in the freezer to look at your evaporator coil.
If it's partially frosted at the top, or bottom, but the rest of it is dry looking, then you've got a leaking sealed system.
If it's lightly frosted all over, then you have good coolant flow and you need to start looking at your thermostat and damper up in the fresh foods section.
Nov 10, 2014 | Kenmore Refrigerators
Its not getting cold
MAKE SURE THE FANS ARE RUNNING FREEZER AND COMPRESSOR, THEN CHECK THE BACK WALL OF THE FREEZER IF ITS FROSTED UP YOU HAVE A DEFROST ISSUE. IF THE COMPRESSOR AND FANS ARE WORKING AND NO FROST IN THE FREEZER THATS NOT A GOOD THING..
Jan 13, 2010 | Kenmore 74852 / 74854 / 74859 Top Freezer...
2 year old Kenmore freezer won't keep cold. It
Check underneath the unit and make sure the compressor is running and that the compressor fan is turning.
Oct 15, 2009 | Freezers
Won't freeze
Is the compressor running the whole time? If so may have a problem with a refridgerant leak....check the compressor in the rear of unit, feel if its hot....may be as simple as a relay.
Jun 17, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Light works - that's it! Just quit working.
All frost-free refrigerator-freezers have a thing in the system called a Defrost Timer. The thing is a little clock of sorts that tracks accumulated running time. Every 8 hours of run time the thing cycles through a defrost cycle. The defrost cycle is necessitated by the humidity that forms ice crystals on the freezing coils, if the frost is not eradicated it can build up to the point where no air flows over the coils to chill the inside of the box. The Defrost timer in all boxes fails eventually from old age. When that happens, the coils frost over until they become pretty much just a solid block of ice. Your case may however be the exception, as it seems likely that the timer quit during a defrost cycle. Most timers are located on the front of the machine, behind that removable grille under the door. The timer has a round hollow shaft through it, and can be turned with a screwdriver. If the compressor is not running, give the shaft a slow twist until a click is heard. The compressor should start. If it does, check the fridge in 12 hours to make sure it is not stopped again. Sometimes the nudge will make the timer run for a while. You will need to get a replacement timer. If that doesn't make it take off you should call a servicer.
May 20, 2009 | Kenmore 64802 Top Freezer Refrigerator
Kenmore top freezer fridge does not cool but freezer works
Turned refrigerator off for 8 hours, let the frost melt and the fan in the freezer worked again. The compressor now only has a soft clunk when it goes off.
Jan 30, 2009 | Kenmore 64823 Top Freezer Refrigerator
Kenmore coldspot model:10653502330 does not stay cold
hi thanks for the question i would check the back by the compressor make sure its clean . then check the fan in freezer to see if it works then see if the frost built up in freezer you could have just a dirty condenser thanks the appliance doc
Sep 08, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore Upright Freezer Model 2539252110
constant clicking, sounds like a compreesor trying to start itself, you might geta way with replaving hte starting device for compressor, sometime s a bad compressor will burn out a starting device, checl your warr papers, most compressors had afull 5 year warr
Mar 16, 2008 | Frigidaire 5 cu. ft. / 142 liter Chest...
Kenmore 13.7 Frost Free Freezer
You may want to check the compressor area of the unit.There may be something on the coil or fan blade.(Packing foam,paper, etc)
Dec 11, 2007 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
125 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
