Question about Honeywell Electrical Supplies
Have an Ajax electric motor wired for 220 volts, want to wire it for 110 volt. schematic to do so is rubbed of info plate. 1 1/2 HP Mod # 7204CDR328CBWCCW
muttandjeff
  • 359 Answers
SOURCE: electric furnace wire heating up
you should have a 3- conductor # 6-3 copper wire running to this 60 amp breaker @ the furnace to the panel if this is not the case you should replace this with a # 6 as of now as it is a fire hazard as it is and needs to be fixed at once , # 10 -2 wire is only good for 30 amps and a 60 amp breaker will not trip under fault condition and you could have a fire , if you need further assistance on this let me know and i will try to help
Posted on Jan 10, 2009
  • 10865 Answers
SOURCE: Wring for trolling motor
just hook the two batteries up in series. To do this buy one short cable and use it to hook the positive of one of the batteries to the negative pole of the other. Then use the two remaining poles, one positive and one negative to hook up to the motor. good luck
Posted on Jan 18, 2009
  • 4 Answers
SOURCE: Need to know how to wire a motorguide 767 brute trolling motor
The white wire is the ground. The black wire is neg. and the red wire is pos.
Posted on Apr 30, 2009
  • 10865 Answers
SOURCE: I want to wire in a 71lb motor to a Brute 767 head. The 71 has two extra wires than the 767. Everything else has interchanged. The 767 is stuck on high speed. I have changed board, 3 way switch, a
If your dishwasher is cleaning poorly, check these:
Water-inlet valve
Internal filters
Drain valve
Spray arms
Water temperature
Detergent cup
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it.
When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it.
Dishwasher Water Inlet Valve Replacement
Be sure to read and understand any instructions that come with the new water inlet valve.
Tools required:
Adjustable wrench
Multi-Screwdriver
Pliers
Step 1. Disconnect the dishwasher from its power source.
Note: Dishwashers are usually wired directly to the home’s electrical system. To disconnect the power, switch off the circuit breaker or remove the fuse for the electrical circuit the dishwasher is attached to. Try to turn the unit on after disconnecting the power to be sure you were successful.
CAUTION: If you’re not sure you’ve shut off the power properly, DO NOT CONTINUE. Call a qualified appliance repair technician to complete the repair.
Step 2. Turn off the water supply to the dishwasher. This is usually underneath the kitchen sink or in the basement or crawlspace near the location of the dishwasher. Pliers may be helpful here.
Note: If there are no shut-off valves, you must shut the water off at the main water supply valve for your home.
Step 3. Remove the lower panel(s) of the dishwasher. These are usually held by 2 to 4 screws at the upper and lower corners of the panel(s).
The inlet valve is usually near the front of the dishwasher. Attached to the valve you’ll see: 2 or 4 wires, the water supply line from the house and the water feed line that goes to the dishwasher.
Step 4. Remove the household water supply line from the valve. The line is usually secured with a brass compression nut. The water supply line is usually copper or braided stainless steel.
CAUTION: Water supply line may be hot.
Step 5. Remove the fitting from the valve the water supply line was attached to. This fitting may be very difficult to remove. It may help to put the valve into a vice in order to remove the fitting. If you cannot remove it, replace it. The fitting is not an appliance part but a plumbing part that is available at most hardware stores.
Step 6. Remove the screws holding the valve to the dishwasher frame.
Step 7. Label the wires to the valve so you’ll be sure to reattach them correctly.
Step 8. Remove the wires from the valve.
Step 9. Remove the clamp on the black rubber water discharge tube and pull the tube off of the valve.
Step 10. Reinstall the old fitting (or a replacement fitting if necessary) onto the new valve the water supply line was attached to. Use Teflon tape or pipe joint compound as a thread sealant. Make this fitting tight to prevent leaks. Make sure that the fitting points in the same direction as the old one so that the water supply line will meet up with it properly.
Step 11. Install the new valve in the reverse order of the removal instructions.
Note: The water supply line is under high pressure. Be sure to tighten the fittings properly.
Step 12. Turn on the water to the machine, and check for and correct any leaks.
Step 13. Reinstall the access panel(s). Restore the power to the dishwasher and test.
Note: You may have to let the dishwasher run a few minutes before it reaches the next water fill cycle.
Internal filters Every dishwasher has some type of filter to keep large food particles and foreign objects away from the pump assembly:
  • Most modern dishwashers have self-cleaning filters that don't need any routine cleaning.
  • Some have filters in the bottom of the dishwasher that you need to periodically clean. You don't need any tools to remove the filter, and cleaning it is easy. Consult your owner's manual to determine which type you have and its maintenance requirements.
If your filter is clogged, it may be causing the cleaning problem.
Drain valve Some dishwashers have a valve (or gate) that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged.
Spray arms There's a spray arm at the bottom of your dishwasher--it may have a tall spray tube mounted to the center of it. There may also be a spray arm located directly beneath the upper rack of dishes and/or above the upper rack.
If debris is blocking the holes in the spray arms where the water comes out, it could cause cleaning problems. Regularly inspect each of the spray arms and clean out the holes as necessary.
Water temperature To get the best cleaning results, the water entering your dishwasher needs to be hot enough. Try running the hot water in your kitchen sink for about 30 seconds before starting the dishwasher, to pre-heat it. Also, if your dishwasher lets you select a higher wash or rinse temperature, try that to see if it helps.
To check the temperature of the hot water that comes from your kitchen faucet use a waterproof thermometer. If the water isn't 120 degrees Fahrenheit, your dishwasher may have trouble getting your dishes clean. You could increase the temperature of the hot water to the whole house--and therefore the dishwasher--by adjusting the hot water heater thermostat.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Detergent cup Dishwashers don't perform their best if detergent is introduced only at the beginning of a cycle, so add detergent to both parts of the cup.
Posted on May 29, 2009
  • 770 Answers
SOURCE: Hooking up a Hot tub
Everything above tells me this is 120V unit...if thats the case a single pole breaker is sufficient. Also by what you have written, a 15 amp breaker should suffice.
Posted on Jun 22, 2009
This is not a question about a dryer! I have a Sears 10 inch Radial Arm Saw. How do I switch the motor from 220 volts to 110??
If the motor is a dual voltage type the instructions might be printed inside the motor cover or alternatively in the saw handbook.
It is important to find the correct instructions and to follow them exactly.
Dec 23, 2016 | Dryers
Single phase motor 220 convert to110v; do you have switch wire inside the motor
There should be a label showing the change, one wire gets switched over to a different screw, all motors are different, but all basically the same, some will not switch. It would be just as easy to run a new line to your motor and it will be right, single circuit, 220 volt,?amp, no worries., Your motor as is will not run in 110 volt mode at all. Hope this helps.
Feb 26, 2012 | Delta Table Saw Tool Base 50279 Band Saw...
How do i take apart an electric motor
usually there is a plate where the wires go into the motor and on the back of it is a wiring diagram for switching from 220 to 110.UNPLUG TOOL BEFORE REMOVING ANYTHING.
Jan 08, 2012 | Powermatic Saws
A o smith b854 motor schematic diagram 115v . How do I hook up 115v to the factory set 230v?
Remove the back of the pump housing ... inside you will find the 110 volt connection place.
If your pump is on a dedicated line (as it should be) run it on 220 VAC ... To convert your line from 110 to 220 all you need is a double pole breaker of the proper amperage ... take the white wire presently on the ground bus bar and put it on the other side of the new double pole breaker. Then you will have 220 ... and you will save a few bucks on electricity.
Jul 11, 2010 | Smith Pool Pump Motor Square Flange - 1 HP
Am I able to step this motor down to 115 ? Plate specifies 230V.only
it depends on how many motor wires you have available to work with .. IF the name plate says 220 volts , not 120 / 220 volts , then no. If there are only 2 wires for the motor, then NO
thoughts?
Jun 23, 2010 | AO Smith 1.5 hp 3450/1725rpm 56J Frame 115...
Wirng connecions for 110v pentair pool motor???
There shopuld be a diagram on the nameplate of the motor, or on the cover for the wiring compartment, or there is some stamped indication at the wiring lugs that tell you where to put your feed and what position the internal wires are to be in or the jumper .. for 110 volts or 220 volts.
May 29, 2010 | Pentair 3hp Whisperflo Pool Pump In -...
Replacing new AOSSQ1152
What's the source of the info that the two orange wires are Low & High?
Orange is an unusual color, but I'd say, with 99.999% certainty, that if you put a voltmeter across the two orange wires, it'll read 220 volts (nominal).
The two orange and one white lead give you the ability to run @ 110 volts -- there will be 110 volts between one orange and white and also the other orange and white.
For this motor you only need the two orange wires which will give you 220 volts between the two. Cap off the neutral/white wire (not needed) & connect the two orange wires, one to L1 and one to L2 on the motor (L = Line). And don't forget to connect the ground...
Charlie
P.S. You should also have a GFCI on this circuit.
Sep 11, 2009 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
I have bard central unit model# a/c ph11361 blower not running
220 is just putting two 110 volt circuits together. You should read only 110 volts from each leg to ground. But you should read 220 between both legs. Measuring between two legs that are supposed to be 220 and you read nothing than you are not measuring the differences. This means you are only getting 110 volts. Check your units data plate and make sure you need 220. Usually the condenser fan on a split system is 110 volts and the condenser fan is 220 volts. Which motor are you checking?
Apr 02, 2009 | Heating & Cooling
Electrical Supplies Logo
161 people viewed this question
Top Honeywell Electrical Supplies Experts
Dennis Boxerman
 Kenneth
Kenneth
obsteiner
Are you a Honeywell Electrical Supply Expert? Answer questions, earn points and help others
