Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
Honeywell 3035D won't open
I'm unable to open my securtiy box. The batteries must have died so I'm unable to use the electronic key pad to enter the code. The bypass keys won't open it either. When I put the bypass key in and turn to the unlocked position, I still can't open the box. Very frustrating!!
2 Suggested Answers
  • 588 Answers
SOURCE: i honeywell 3035d security box, no key, dont know code.
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Posted on Mar 16, 2010
Need to open a Sentury safe key pad only the batteries died
without knowing the model the best i can doe is link you to you tube and some of the fixes there. i used this search term how to open a sentury safe key pad only batteries died. you may try other terms to get different videos on how to do it. good luck.
https://video.search.yahoo.com/search/video?fr=crmas&p=how+to+open+a+Sentury+safe+key+pad+only+the+batteries+died%3F#id=1&vid=1b6eaea93a88d9929e8b1ce283d04996&action=click
Oct 23, 2017 | The Home Security
Got old honeywell safe No:HWF19004340, no key and don't know combination. Can it be opened?
contact a locksmith for the answer to your problem All safes can be opened by professional trades people.
Apr 06, 2013 | Safe International Digital Electronic Safe...
Safe won't stay locked, key missing but have key pad.
You might need to have the key set to lock in order to use the keypad or check the battery in side the door
Mar 08, 2013 | Locks & Locksmithing
I need a replacement key EX2005138875 for my Safewell electronic safe. The batteries have failed and I cannot open the door.
I was locked out of my Honeywell safe after battery died. I ordered a replacement key from firstalert.I was required to photocopy the receipt and type out an witnessed affidavit stating I own the safe. About 3 weeks later I found my spare key,4 days after that the replacement key arrived in the mail ($10.95 money order for that key). The other two spare keys were in the safe, I did not think the batteries would die so soon. Crappy factory batteries that came with the safe.
Mar 15, 2011 | Locks & Locksmithing
I honeywell 3035d security box, no key, dont know code.
HONEYWELL WEBSITE:
Go to honeywell.com
Mar 07, 2010 | Honeywell Electronic Programmable...
Unable to open electronic safe
Locksmiths say this is how to install sentry safe batteries
slide open the battery cover located just below the keypad.
Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated.
reconnect the connector and put back the battery holder. Slide the cover back in place.
How do I insert the batteries on my advanced electronic lock safe? On the newer model Fireproof Sentry Safes my locksmith recommended me To install batteries,
turn the electronic lock case to the right and remove. Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
Mar 06, 2010 | Sentry Fireproof Safe
When i put in new code unable to open have to use key
battery may be weak or dying or locking rods may be sticking lube lock rods
Oct 13, 2009 | Safe International Digital Electronic Safe...
I forgot the safewell electronic code and didnt have the key
NOTE: The safe needs to be upright and right side up or the locking mechanism
won’t work.
ELECTRONIC SAFES
To open an electronic safe the first time, press the following numbers/letters on the
electronic keypad –159B. (These numbers are preset. You should change the code as soon
as possible after opening the safe to insure proper security). After you have entered the
factory set code, you will need to turn the knob on the faceplate to open the door. You will
have 5 seconds to turn the knob before the locking mechanism is reactivated.
ENTERING YOUR SECURITY CODE
To enter your own security code you will need to follow the steps listed below:
1. After opening the electronic safe (with the pre -set factory code of 159B) locate the
small red button on the inside of the door near the hinge.
2. Press the red button and then release it, you will hear a beep.
DO NOT SHUT THE DOOR UNTIL YOU HAVE CONFIRMED THAT YOUR NEW
SECURITY CODE HAS BEEN ENTERED CORRECTLY.
3. With the door open, enter your own personal security code, which can be 3- 8 digits
long, and confirm your new code by pressing the letter “B” on the electronic touch pad.
Before you close the door, try the new security code to make sure the lock release the
knob so you can turn it and retract the live action locking bolts.
If you can not get this open more then likely you will have to cut it open.. One last thing to try is to email safewell sales@safewellsafe.com
Good luck
Sep 14, 2009 | Locks & Locksmithing
I locked my key in the safe and I CAN'T REMEMBER THE CODE THAT THE MANUFACTURER GAVE YOU WHEN YOU FIRST PURCHASE IT. psf80 PRO-SAFE ELECTRONIC DIGITAL SAFE
Press 159 - safe will beep for each number pressed on the key pad, Then press A or B, the green light will come on. Rotate the knob clockwise and pull the door open.
Aug 18, 2008 | Office Equipment & Supplies
Heating & Cooling Logo
282 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
