Question about KitchenAid Refrigerators
Refrigerator not cold freezer ok - KitchenAid Refrigerators
    President:
  • 1,653 Answers
In side by sides if the fridge side not working correctly it means that the air vent from the freezing unit has stuck in the closed position which causes the fridge to not be any where near as cool as it should be and if it is too cold then the vent is stuck in the open position. The vent is controlled by a small sync motor and either the motor has become faulty, the control module is faulty or the vent is iced up, which can be caused by putting too many hot items in the fridge so the steam condenses and freezes the vent in position and then the motor cannot open or close it causing it and / or the control module to become faulty. Other times it is just old age that causes the motor and / or the control module to fail. Best call a service engineer asap.
In stand alone fridges the answer could be that the cooling panel at the rear is dirty and needs thoroughly dusting / cleaning / unblocking and checking that there is enough space around it to cool properly and that it is not near any heat sources such as an oven, air vent, microwave exhaust, etc.. It could also be caused by a problem that has resulted in a loss of the refrigerant gas and will need regassing by a service engineer. Also check that the thermostat is working correctly, turn it up and the fridge compressor motor should kick in, turn it down and the motor should turn off. Also make sure that the fridge is not iced up, or overloaded, so cool air cannot circulate inside it.
Posted on Sep 28, 2009
dididsaythat
  • 291 Answers
SOURCE: My refrigerator doesn't get cold enough
Things to check
Check freezer...
for Frost build up and if Fan is blowing,
Check condenser...
To make sure clean, and the fan is blowing by compressor & IF it is running
Check Recirclating Vents in refrigerator... to make sure theres no blockage,
CONTROLS ...should be in the middle setting,
Posted on Oct 26, 2007
  • 3 Answers
SOURCE: the refrigerator is not getting or staying cold enough. the freezer seems to working ok
Check the vent at the top of the shared refrigerator wall for cold air from the freezer. If not, then you can either replace the motorized flap inside the vent or prop the flap open with a stick or something. The manual solution won't harm anything. The motorized flap is an over-engineered solution designed to create service calls. :<)
Posted on May 21, 2009
  • 212 Answers
SOURCE: Hi, We have a whirlpool eb22dkxfw01
need to check for ice build up in air vent. if not make sure you hear your evap fan blowing in the freezer section. this blows your cold air into the fresh food side. do you have ice build up on rear wall of freezer section?
Posted on Jun 21, 2009
kdgrayson
  • 195 Answers
SOURCE: Freezer section is cold, but the refrigerator section is not
set to colder refrigerator ... not colder freezer!! the fridge is reliant upon air migrating into the area from freezer side! if you peg both controls to max , you get a warmer refrigerator , but colder freezer, the control that does not operate the compressor is the setting i mean, it usually says .. for coldest and everyone pegs it and its a common cause for a service call and people cant believe it, if you cant tell which is which set both to middle! evfen at warmest setting the freezer should still make ice and thats the test for freezers state1 can it make ice!
Posted on Aug 23, 2009
hiltonjug
  • 612 Answers
SOURCE: GE Refrigerator-Freezer side works fine/Refrigerator side not ok
You most likely have a defrost problem. Check the inside back panel of the freezer. See if there is ice built up. If so, you have a problem with the defrost. 85% of the time, it's caused by a bad heater. It could be the termination thermostat, timer or fan. If the ice is built up. Take the panel out and defrost with hair dryer. If you want, you can now check the heater and termination thermostat. It's a closed switch that opens on the rise. If you fix it your self or not, To save your food. You can replace the panel and turn the fridge back on, it will operate correctly for 3 or 4 days. This will give you time to either get the part and fix it or for someone to get out and repair.
Please rate solution and make it worth the while to summit solutions. Thanks
Posted on Aug 28, 2009
Refrigerator part not keeping cold- freezer freezing. I unplugged it . Cleaned the freezer and thawed it out. It seems ok but the refrigerator part is not cold.
There is a fan that delivers cold air from freezer to the fridge section. if freezer is working fine, and fridge part is not cooling replace the fan motor/fan
Dec 29, 2016 | Refrigerators
Kenmore side by side freezer is working and air flow is ok with freezer door open...when close freezer door cold air flow to fridge stops
fan sometime runs when doors open only. if freezer is set too cold then a little door leading to refrigerated compartment freezes shut with frost and then the cold air cant get from freezer to refrigerator. good luck
May 07, 2011 | Refrigerators
Freezer ok fridge not cold enough
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 07, 2011 | Daewoo FRSU20IA Freezer
Freezer ok but fridge does not get cold
heatman101
Feb 27, 2011 | Zanussi ZEBF250W Bottom Freezer...
Freezer side cold, other side not cold, temp settings ok set to 33f
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Nov 10, 2010 | Frigidaire FRS-26DR7D Side by Side...
The freezer is working OK but the refrigerator is not getting col
you have leakeage on pipes(smal hole) in short time and the freezer wil not getting cold.call specialized service, they must have a good welder.
Feb 15, 2010 | Frigidaire FRS3R5EMB Side by Side...
Freezer not getting cold enough.
That is normal since the cold control is on the refrigerator side and is satisfied. It needs to be in a heated environment and not in an unheated garage.
Jan 02, 2010 | Frigidaire FRT21P5A Top Freezer...
Refrigerator isn't getting cold, but freezer part & ice maker seem to be working OK
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Jul 13, 2009 | Refrigerators
The refrigerator is not getting or staying cold enough. the freezer seems to working ok
May 21, 2009 | Frigidaire FRS3R5EMB Side by Side...
Fridge not cold enough, Freezer ok
The refrigerator gets its cold air from the freezer section through ducts and damper control. Check for blockage.
Apr 27, 2009 | Candy CPCA240FFK Bottom Freezer...
Refrigerators Logo
14 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
