Question about Motorola Mobility RAZR V3
Memory card removal
My appointment notification is stuck and won't dismiss or snooze. I removed the battery and now am attempting to remove memory card. Good idea?
    Scholar:
  • 181 Answers
I would try setting the clock on the phone to a year ago, then go back and delete the appointment reminder. Set the clock back, and see if that works.
Posted on Dec 18, 2007
How do I remove the photo cartridge from the camera
Removing Memory Cards
Before removing memory cards, turn the camera off
and confirm that the power-on lamp and monitor are
off. Open the battery-chamber/memory card slot cover
and press the card in to partially eject the card. The
card can then be removed by hand. Do not attempt to
remove the card at an angle.
Sep 29, 2014 | Nikon Coolpix S-4000 S4000 Silver Digital...
I mean stuck on android start up
Here are some steps you can take that can get you past this point.
1) Remove the battery and memory card from the device.
2) Reinsert the memory card and attempt to start the device.
3) Insert the memory card back into the phone and restart the device
Note: if this does not work you may have to resort to steps that require knowledge in basic computing
4)
Format the memory card
5) Wipe the cache partition of the memory card to clear all of the used system memory.
Apr 04, 2014 | Tablets & eReaders
How to remove memory card from camera
Confirm the power-on lamp and the monitor are off and open the battery-chamber/ memory card slot cover. Be sure to turn off the camera before opening the battery-chamber/memory card slot cover.
Removing Memory Cards 1 Before removing memory cards, turn the camera off and confirm that the power-on lamp and monitor are off. 2 Open the battery-chamber/memory card slot cover and press the card in to partially eject the card. 3 The card can then be removed by hand. Do not attempt to remove the card at an angle.
Insert the memory card.
4 Slide the memory card in correctly until it clicks into place. 5 Close the battery-chamber/memory card slot cover.
Oct 08, 2011 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
My A480 stopped transfering images to my computer. After plugging in and turning on camera the notification to transfer does not appear...?????
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
May 22, 2011 | Canon PowerShot A480 Digital Camera
My jazz video recorder is stuck on a menu that says " Format... yes or no" I can't push anything, need help!
Remove the battery, wait several minutes, then re-insert battery & power-up again.
If you have videos / pictures on a removable memory card, remove the memory card after removing the battery and upload the videos/pictures to your PC using a card reader.
Mar 01, 2011 | Cameras
Sony erricsson k800i
Connect the phone to a computer, remove the memory card (if one is in) and sim card and use the SEUS (Sony Ericsson Update Service) program to try an update on the phone. (you can just search SEUS on google to download), follow the instructions and see if that helps. If not, turn the phone off, hold the 2+5 keys, plug in the USB and wait 15 seconds while still holding 2+5. Once this is done (you will not see any notification on your phone so count to 15) remove the USB, remove and reinsert the battery and power it on. Either of those methods should reset the phone, but recommend attempting the SEUS method first. The 2+5 keys is only intended to be accessed by phone engineers. But just so you know in future, don't click Factory setting next time, click master reset. This will remove everything barring what is on your memory card and sim card.
Feb 11, 2009 | Sony Ericsson K800i Cellular Phone
Razr V3 Alarm Will Not Shut Off
My Razr V3m also has this issue. One way to shut the alarm off is (1) make a call to your cell from another phone. (2) Disconnect the call from the other phone without picking up (3) You should see two events on your cell - one for missed call and the other for alarm. (4) Delete the alarm event first and then the missed call.
Drawback for this solution is you need access to another phone...everytime :-(
Sometimes, I am able to shut the alarm successfully without any problem
Aug 22, 2008 | Motorola Mobility RAZR V3
Alarms and reminders
the one issue where when you powercylce and the allarms come back on is an issue with all windows mobile devices called a phantom alarm....it sounds like a sw malfunction....do a master reset, by going through start>settings>clear storage....back up your info fist by using the PC or the memory card....this will remove all of you info and your settings.......if you are using an outdated sw you will have to reinstall and that should fix the problem...
Dec 11, 2007 | T-Mobile MDA
Duplicate alarms
I may be off base but might the problem be as simple as the frequency being set for the alarm. What I mean to say is, might the default reminder time for the alarm be set to such a low setting like sec's or minutes leaving the unit to repeat the alarm rapidly prior to your being able to dismiss/snooze. Good luck.
Sep 14, 2005 | HP Jornada 548 Pocket PC
Blinking Green Ligh
Yes, this blinking green light is an appointment notification. So if you set up an appointment for September 30th, 2005 at 9:00 AM with a reminder set to 1 day....then on Sept 29th at 9:00AM, the IPAQ will turn itself on and a reminder screen will appear on your IPAQ. After a length of time (the default of which I can't remember now) the Ipaq will turn itself off, but will leave that green light flashing. When you then turn the IPAQ back on, the reminder screen will again appear and you can choose to dismiss the reminder or snooze it.
Sep 07, 2005 | HP iPAQ HX2415 Pocket PC
Motorola Mobility RAZR V3 Logo
63 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
