Question about Samsung CLP-600N Laser Printer
Error Engine Fuser low heat
We had a printer jam with glossy paper wound tightly around rollers and needed to remove part of roller assembly to clear. After restart we got this error.
What is needed ?
  • 51 Answers
Possibly the fusers thermostat is displaced. it rides very close to the roller to get an accurate reading, look for 2 wires into a black "thing" toward the middle of the roller. this is a thermistor which sends its reading to the mainboard. check if the fuser is getting very warm, there is a thermo couple in series with the fusers power so it wont overheat but if its getting hot and the printer doesnt know it then the dammaged/displaced thermostat would be the thing to look for,
Posted on Sep 28, 2009
600N Printer - Engine fuser low heat error. I'm not sure where this part is. The error light indicates it's in the center of the printer. But when I look for the part and how to install it is for a different part.(fuser) Is the engine fuser the part that has a orange roller?
Posted on Jun 25, 2010
Clear a paper jam on 3330
When you say "release it from around the roller", do you mean that the page looks like it is wrapped around the roller? If so then the fuser will possibly need replaced. Depending on how skilled you are you could try removing the fuser and disassembling it to remove the paper but it may not be possible. if you decide to try be careful not to tear the "roller". It is actually a fixing film, a thin mylar type product with a nonstick surface. It is easy to damage it and then you would have to replace the fuser for sure.
Jan 04, 2013 | HP LaserJet 3330 All-In-One Printer
Paper is jammed in printer under the heating element and I can't get it out
remove the back cover, 2 screws holding the redrive (back) assembly.
You will have access to the fuser, again held with 2 screws. Disconnect cables going to the fuser, remove and clear paper. Examine the surface of the rollers, bottom has rubber surface. If surface is showing ripples in the rubber, you may need to replace it to prevent further jams.
Oct 21, 2011 | Lexmark T632 Laser Printer
Paper jammed at exit rollers of Canon D860. Paper
If you remove the plastic covers on that side of the printer, you will see a small screw holding a bar against the rollers. Set the printer on end so you can remove this screw with out dropping it into the printer, and then the rollers will be loose enough that you can get the paper out.
May 12, 2010 | Canon imageCLASS D860 All-In-One Laser...
Brother mfc 9880 fax/copier makes grinding noise and has paper jams
Probably a broken Hot Roller gear in the fuser. The fuser is the section in the back, that presses the print between a pair of hot rollers to melt the powdered toner into the paper, making the image permanent. That combination of heat and pressure makes the fuser vulnerable to breakage in any laser printer or copier. The HR (hot roller) gear is a ring around one end of the heated roller, and it sometimes breaks apart.
The MFC 9880 isn't listed on Brother's US service website, so I can't tell you whether you need to buy a whole fuser assembly or just that gear.
Mar 31, 2010 | Brother MFC-8860DN All-In-One Laser...
Fuser Error. Low Temperature
there is a small thermometer that contacts/sits very close to the metal heat roller on your fuser, chances are when removing the jam its been bent away from the roller, have a look and try and see if you can see it, not knowing this exact printer im not sure the exact position but it is usually in the middle of the roller coming from the top of the fuser housing, another thing to check is if your fuser is actually warming up atall, if you cant feel any heat then the fuser lamp that heats it up has gone bad
Nov 14, 2009 | Xerox Phaser 6100/BD Laser Printer
13 Paper Jam - but there is no paper inside!
I have a long solution (possibly) to your issue:
Error 13 Paper Jam
  • Paper jams can occur in 3 places: Entry, registration and exit.
  • If the paper isn't picking up out of the paper tray, visually inspect the pickup roller. If it looks shiny, replace it. You should also replace the separation pad as they work together. On the 4L/4P/5P/6P the pickup roller has a plastic shaft that breaks. You'll have to replace the whole pickup assembly. This requires major disassembly of the printer. Check our printer repair kits for your model printer. If you don't see it listed, email us.
  • If you have an HP 4/4+/5 with an optional 500 sheet feeder that's jamming, check the balance knob adjustment. Center it with a full **** of paper for proper operation.
  • If the paper is jamming at registration or anywhere between pickup and exit it could be a number of things. Check the paper path for torn bits of paper or label residue. On the II/III series, remove the metal registration guide plate (2 screws) and check underneath it. If the pickup rollers are moderately worn, the paper will stop just short of the registration roller. On the 4L/4P/5P/6P remove the screw holding the oblique roller assembly (Inside front of printer) and pull out and inspect the assembly and the area under it. On the HP 4/4+/5 pivot up the metal plate and check underneath it. Check the roller assembly on the left side for torn scraps of paper (a flashlight or torch is necessary).
  • Make sure paper cassettes are firmly seated, corner tabs aren't bent. Some trays have lifting springs that could pop out if tray has been dropped.
  • On HP IIP/IIP+/IIIP printers if the paper scrunches up at the toner cartridge you'll need our Inside Accordion Jam Repair Kit.
  • Check your software settings in the program you are attempting to print from. Do you have the correct paper size specified? If you have a different paper size than what is in the tray, you'll get a paper jam.
  • Exit jams are frequently caused by exit sensors. These sensors are typically mounted on the fuser assembly or adjacent to it. They are plastic arms that block and unblock an optical sensor. The arms can get stuck or knocked out of place when clearing paper jams. The optical sensors can also get dirt blocking the photo cell. Clean the sensor and check for free movement and proper installation of the sensor arms.
  • On HP II/III series exit jams are mostly caused by worn gears. The best way to troubleshoot this is to defeat the door interlock (see door interlock photo on troubleshooting page). Press down on the arm on the top right of the fuser. Initiate a test page. While holding down the arm, press one of the metal cartridge detect switches just below the door interlock. Watch the movement of the gears. You will get a 51 error because the door is open. Recycle power to get rid of error. There is an arm gear on the lower right of the fuser that can shed teeth. There is also a 14 tooth gear below the large gear on top of the fuser. You can also manually rotate the large gear and check for binding or crunching. If that happens, then replace the 14 tooth gear. On the door, there are some delivery coupler gears that mate with the fuser and drive the exit roller. Check the gears for excessive wear. Replace if necessary. If the paper gets almost all the way out and jams, replace the exit roller or the exit roller assembly. If the error occurs after fuser replacement, check and see if the connector on the left of the fuser is properly mated with the one in the printer.
  • On HP IIP/IIP+/IIIP printers if the paper has accordion folds on the bottom and jams on exit, order our Top Output Accordion Jam Repair Kit.
  • On HP 4/4+/5 printers the most common cause of exit jams is the exit assembly. Order our 4/4+/5 Exit Jam Repair Kit. Exit jams in the fuser can be caused by a broken fuser drive gear or a broken gear on the fuser. Remove the fuser and check the gear inside the printer for broken teeth. Manually turn the gears on the fuser and check for smooth operation. Check the paper exit sensor arm for proper mounting and free movement.
  • Check to make sure the rear door is closed on the printer. Open doors can cause 13 paper jam indications.
  • On the 5L/6L check the registration sensor arm below the pickup roller. Also check the exit sensor arm (bottom center of the fuser). These arms frequently get stuck or dislodged clearing paper jams. On these printers, if you are experiencing frequent paper jams, order our 5L/6L Multi-Sheet/No Feed Repair Kit
All this comes from:
http://www.fixyourownprinter.com/reference/errorcodes/hp
Good luck with it, I love the HP LaserJet 4 series of printers. I used to warm my coffee on the top of the fuser when I was doing large print jobs :-)
If this information helps, please give me a rating, thanks!
OpenSource13
Apr 07, 2009 | HP LaserJet 4 plus Printer
HP Laserjet 4100 series , paper jam output tray.( on top of the printer ). The roller under the topcover is turning the wrong way. The paper can't get out of the printer, and jams between the upper roller...
Hi F_bulsara,
First thing to try is to flip the paper over in the input tray. There are 2 sides to paper. One side may curl a bit too much due to heat of the fuser and get caught near the output rollers.
Unless the Output Assembly was assembled wrong, it is impossible for the rollers to turn the wrong way. The gear in the fuser drives the output assembly. The top rollers are rolling out.
If the rollers are not rolling, then one of the gears must be broken or missing. The output rolllers might need cleaning.
Next check the fuser unit. Disconnect power to printer and turn printer round. Remove the back output tray and the two small covers (left and right). Undo the 2 screws that hold the fuser in place. Pull the fuser out. Check the gears on side of the fuser. A broken gear in the fuser could cause this problem.
S88
Nov 18, 2008 | HP LaserJet 4100 Printer
Paper stuck in roller
Clear the paper jam. To see paper jams and how to clear them, click here. If the printer does not start printing, press the control panel button.
Mar 31, 2008 | Brother HL-2040 Laser Printer
Phaser 7300N paper jam
Problem:
    The Printer's Front Panel Displays Jam At Top Cover; Open Top Cover To Clear (A7)
Cause:
Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. TRY FIRST (Solutions without parts):
1. Unsupported media. - Load supported media and set the media type correctly. 2. Dirty exit rollers. - clean the exit rollers. Paper catching on the duplex guide assembly. - Remove and reinstall the duplex guide assembly. Fuser not fully seated. - Reseat fuser
REPAIR/INSPECT/PREVENT PROCEDURE:
1. Clean feed rollers and exit rollers only when dust or
debris is visible.
2. Clean the LED assemblies.
3. Check version of print engine and image processor
firmware; as appropriate.
4. Check cleanliness of interior and exterior of printer,
including fans; if necessary, clean (dust or vacuum) these
areas.
5. Review proper operation of printer using a customer
file, if possible.
6. Review with customer all work that was performed; also
discuss how to properly care for their printer.
Rev DT: 01 22 2003
Jan 23, 2008 | Xerox Phaser 7300DN Laser Printer
Reporting my inactive printer
To clear this error: Power the printer off and let it stand for at least 30 minutes to allow the fuser to cool. Remove the coating roller from the top of the fuser unit to reveal the orange fuser rollers underneath. Check to see if any paper/transparency has become wrapped around the fuser rollers or jammed in or above the fuser unit itself. Since some paper jams can be very difficult to see with the fuser installed, remove the fuser and check for paper/transparency jams under the unit as well. A jam in that area can cause 993 errors. If there is no media jam and the error remains after the printer is restarted, try replacing the Oil Coating Roller (OCR). The OCR comes with the black toner cartridge. (It can also be purchased separately. Click here to do so.) If the error remains after the OCR has been replaced. If that does not help I would highly recommend taking it back to the place you bought it from
May 06, 2007 | Lexmark Optra C710 Laser Printer
Samsung CLP-600N Laser Printer Logo
662 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
