Question about Bosch 7 - 1/4" Skilsaw Circular Saw
The switch is intermittent. The saw has #5375 on the nameplate. I t has the two-handed safety switch where you have to push the red one with one hand and squeeze the trigger with the other hand. Sometimes it works, sometimes it doesn't. Sometimes it will start working and then stop.
    President:
  • 1,653 Answers
Simply the switch will need replacing and this can be obtained from the mfr or you can get it repaired at a local tool repair center. Get it replaced asap.
Posted on Sep 28, 2009
Borrowed for weekend. Proper fuel mix. Chain oil. Temp 36 degrees. Won't start following directions. What to do? Sparkplug? Contacts?
Should be a standard mix. One ounce of oil to one gallon of fuel. From there, when you are starting make sure you are switched to the on position, prime it a couple times and make sure the safety break bar is pulled back. That is the guard that is in front of your hand. If the saw kicks it pushes it out and stops the saw.
Nov 21, 2015 | Garden
Tip
How to change a mitre saw blade
When changing the blade on your mitre saw the first step is to unplug the tool for safety reasons. DO NOT disassembly the safety cover, there is a bolt on the housing that when loosened allows the cover to be moved away from the blade to expose the spindle bolt. After moving the ASSEMBLY away from the blade turn the blade by hand slowly while pushing on the spindle lock to stop rotation. Loosen the blade bolt (usually left hand thread) and place the parts in the order removed, e.g. blade bolt outer flange, blade spacer if used. Reinstall blade noting the rotation of the teeth and replace parts in reverse order. After installation check for rotation by carefully turning the blade by hand and replace safety cover to its original position and tighten bolt.
on Jul 04, 2011 | Saws
Just Bought a 2003 Buell Blast. Lights work, turn signals etc. Where is the starter Button. Pushed yellow button nothing happens?
There are safety systems involved with the newer bikes. Kick stand must be up, transmission in neutral (some allow to start with the transmission in gear and the clutch disengaged). Some even require the front brakes to be applied. Unless all of the above conditions are met, when you push the start button, nothing will happen. If all of this is met, then you may have a faulty safety switch somewhere in the system.
Apr 02, 2011 | Buell Blast Motorcycles
I have been trying to turn on my chain saw. Ive pulled the handle back by the trigger gave a few pull on the rope. then i pushed the button in on the side also the push the button back in by the trigger...
The chainbrake should be activated when starting the chain saw. Activate the chain brakeby pushing the front hand guard forwards.b>Cold engine Start position, 1: Set the start/stop switch in the choke position by pulling thered control outward - upward.Decompression valve: Press the valve to reduce the pressure in the cylinder and makestarting easier. Once the machine has started the valve will automaticallyreturn to its original setting.Air purge: Press the air purge diaphragm repeatedly until fuel fills thediaphragm (at least 6 times). The diaphragm need not be completely filled.Grip the front handle with yourleft hand. Hold the chain saw on the ground by placing your right foot throughthe rear handle.Pull the starter handle, 4: Pull the starter handle with your right hand and pull out thestarter cord slowly until you feel a resistance (as the starter pawls engage)then pull firmly and rapidly until the engine fires.Push down the red choke control: As soon as the engine fires which can be heard through a"puff" sound, push down on the red choke control.Pull the starter handle (6): Keep on pulling the cord powerfully until the engine starts.
Nov 18, 2010 | Husqvarna 450 e-series 18" Chain Saw
I'm a wife with a do-it-yourself knack. I recently purchased a Ryobi 10 in. BTS211 table saw. I find the manual complicated as far as how to actually use the device. Can you recommend where I can get...
I am a retired contractor.
I have a shop with a 10" table saw.
And I have opinions about safe operation.
For safety, turn saw off when making adjustments.
1) Raise blade:
There is a handle you turn to raise the blade.
If you are cutting 1/2" plywood, then set your blade at 3/4" or a bit more.
Keep blade low and away from hands.
Keep hands high and away from blade.
For 1-1/2" thick 2x4, I usually set the saw at 1" and run the board through, and then flip the board over and run it through again, taking 2 passes to make really thick cuts.
2) Blade angle
There is a second handle you turn to set blade at an angle up to 45 degrees
Angle cannot be set if saw blade is fully raised >> lower blade to half way or less and experiment.
Angle cuts are difficult if wood is not perfectly flat and square, or too long or too short (boy is that helpful ... but cutting angles takes some experimentation)
3) Table Guide
You stand behind power saw to operate
The saw table guide is on left side of blade and clamps across the table
The guide markings show inches >>> these are usually approximate
To set guide for accuracy, measure distance from blade to saw guide, and then clamp guide down.
4) Push sticks push sticks push sticks and other safety stuff
Let me emphasize safety first last and always
A table saw will chop your fingers off in a blink
On the plus side, I hear it doesn't hurt. But OMG.
There is a very strong human instinct to reach in with your hand when working on stuff
Train your mind >> if the saw is running, do not lean or reach into the saw
If a board is stuck >>> turn off the saw and wait for full stop
If you wear baggy clothes of a loose shirt, the saw will grab you and pull you in too fast for you to react
Keep your clothes tight and your arms bare
Always use push sticks or push boards::
Notice the saw blade is set low
Two push sticks are used to assist when cutting short board > one stick holds down the board ahead of blade, the other stick is pushing board through saw.
Keep your hands away from the blade no matter what.
The person stands behind and to the side of the board being cut.
The cut wood is supported by a catch table (in this case there are rollers)
Where to stand
Obviously you stand behind the saw to cut wood, and sometimes with long pieces, you can move in front and pull them through, and sometimes with large plywood you stand kinda back and to the side.
Why not stand directly behind a saw? Because saws throw stuff back.
When 'ripping' a board lengthwise as shown in photo above, if the saw catches the board just right, it will throw it backwards like a spear.
If a board 'binds' the saw causing saw blade to stop, then turn off saw, back up the board, and cut again.
Crosscut guide
The saw comes with a T-shaped guide that fits into a groove.
This is a 'push stick' >>> you use it to cross cut a board, and it lets you stand to the side of the saw blade so things wont flip back on you
When using the cross cut guide, remove the table guide that clamps across the saw, or push the table guide WAY back so pieces don't get caught in a bind and the blade flips up the piece and hits you in the face
Remember, the saw throws everything backwards
The saw is strong and fast, and you are best when traveling slow and without rush around your strong friend.
Oct 15, 2010 | Garden
Car was in an accident, is there a fuel pump safety?
its in the back of the car trunk or hatch left hand side push the red button its called an inertia safety switch
Mar 05, 2010 | 1994 Mercury Sable
Craftman model 315.11823 circular saw. Its intermittent. I have hit it with my hand and it works. Any suggestions.
checkk the brushes and then loose wires at the switch and brush holder connections.
Dec 27, 2009 | Craftsman Saws
Grinder question
Use a pencil and straight edge to mark the cutting line on the wood. Place the wood on the saw table and line the mark up with the saw. Place the mark on the right side of the blade to ensure proper cutting. Plug the saw in and put on your safety goggles. Support the wood on the work surface with your left hand, placing it far from the saw blade. Place your right hand on the handle, and push the trigger to start the saw. Move the saw blade down onto the wood. Put constant pressure on the handle to slowly move the blade through the wood. Release the trigger and raise the blade once the cut is complete. Make diagonal cuts in the same manner, by marking the wood and lining the mark up just to the right of the saw blade. Continue as you would for a straight cut. Remove the wood from the saw. Unplug the chop saw and dust the sawdust off. Remove the dust bag from the back and empty it. Vacuum any remaining dust off of the saw.
Aug 27, 2008 | Dremel 10 Diamond Cut-Off Wheels Saw Disc...
Circular saw Safety issues
If you are left-handed, you must be extremely cautious when operating a circular saw, since most saws are designed for right-handed operation. But if you can, you'll be better off with a left-handed model or an adjustable one (suitable for right-handed and left-handed as well).
Aug 27, 2008 | Bosch 5" 60-grit Sanding Discs for Wood (5...
Drill Presses Safety question
Before connecting a drill press to a power source be sure that the voltage supply is the same as that specified on the nameplate of the tool. A power source with a voltage greater than that specified for the tool can result in serious injury to the user, as well as damage to the tool. Using a power source with a voltage less than the nameplate rating is harmful to the motor. Also, when operating the drill press, use safety equipment including safety goggles or shield, ear protection and protective clothing including safety gloves; Keep the area free of tripping hazards; Periodically check that all nuts, bolts and other fixings are properly tightened; Never use your hands to remove dust, chips or waste close by the drill bit.
Aug 27, 2008 | Makita Tools 1/2" Spade Handle Drill -...
Bosch 7 - 1/4" Skilsaw Circular Saw Logo
211 people viewed this question
Top Bosch Saws Experts
Parson's Repair...
Parson's Repair...
Jim London
Jim London
Are you a Bosch Saw Expert? Answer questions, earn points and help others
