Question about Xerox Phaser 5500N Laser Printer
Xerox 5500 jaming at tray 3 and 2 constantly - Xerox Phaser 5500N Laser Printer
  • 67 Answers
There are mylar guide strips that get bent if paper is misloaded and the drawer is shut. Otherwise you need new paper feed rollers, which are part of the fuser maintenance kit.
Posted on Oct 03, 2009
Message 'Empty trays constantly displayed, although trays were emptied
Xerox Workcentre 7855 Bypass Tray 5 empty - Customer Support Forum
forum.support.xerox.com/t5/Hardware/...Tray...empty/td.../14901...
XeroxSep 29, 2014 - All my 7855 have the Tray 5 (Bypass) is empty. message. .... as there is no paper in it the message will always be displayed in the driver here:. Error message-Paper Tray is empty
Dec 8, 2011
Phaser 3600 reports as paper try empty
Oct 20, 2011
8560 waste tray error
Dec 13, 2010
More results from forum.support.xerox.com
empty drip tray Questions & Answers - Fixya
www.fixya.com > Forum > Tags
But now the display shows "Empty the drip tray" constantly. ... Empty Drip Tray message Getting the message "Empty Drip Tray" even when the tray is completely .
Nov 21, 2015 | Office Equipment & Supplies
How can I get the paper drawer for my Xerox Phaser 4600 to open? The paper tray is empty but won't open.
Hi Anonymous,
I suspect you must have solved this one by now.
I can only assume you have something jamed inside. (your thoughts too I expect)
I would have thought removing as many panels as you could to gain access to the drawer unit to add paper might reveal where the problem might be!
Good Luck.
Jul 02, 2014 | Xerox Phaser Office Equipment & Supplies
Xerox 6180 James at Tray 1 mpt every time!
Your lower trays are programmed incorrectly. Change the size and or the paper type back to letter and plain paper
Aug 23, 2012 | Xerox Phaser 6180N Laser Printer
Xerox Phaser 5500 will only print if started in the manual tray.
Check your printer setup/default settings on the printer. Make sure you are using the right paper in the trays and that they are set properly to the proper paper tray & size. You have to have it right in all locations for it to work right, or it will default to by-pass tray. 1st in the settings, 2nd in the trays, and 3rd in your printer software. Good Luck!!
Jun 07, 2012 | Xerox Phaser 5500 Laser Printer
Dear sir i buy dc 12 machine. now the paper not going on at 5th tray. it was jamed part off. what can i do? pls help me. charles
The feed rollers for tray 5 need to be cleaned periodically, especially if you have been using coated stock.dampen a lint free cloth with isopropyl Alcohol (rubbing Alcohol) and carefully clean each roller.
Gently turn them with your finger so you clean them all around.
Aug 03, 2010 | Xerox DocuColor 12 Printer
My Fuji Xerox C525A constantly says that the bypass tray is empty when it is not. I have to remove the paper and slide it back in and it will print 2 pages and then I have to remove the paper and slide it...
make sure you have the right paper size settings. The paper loaded in the tray might be shorter than the setting in the document. Check also the output size in printer setting.
May 20, 2010 | Xerox DocuPrint C525A Laser Printer
I have xerox workcentre xd105f, can't make copies, paper jamed and letter P on display
to remedy the P display error remove the paper tray and take any paper from under the tray and between the rollers, clean the rollers with alcohol or an acetone solution to remove paper dust and paper debris, refit the paper tray with the paper pushed below the tabs on the tray ensuring that the correct paper size is shown, IE: ltr ltr-r etc.
power the unit off and on and you should be back in business.
If this remedies the problem please rate the solution accordingly
thanks
Derek
Jun 19, 2009 | Xerox WorkCentre XD105F Laser Printer
I have xerox workcentre xd105f, can't make copies,paper jam
P will flash on the screen when the paper tray is empty, paper misfeeds or the paper tray door isn't closed all the way. Make sure both (if you have 2 paper trays) are loaded, that the paper isn't folder and wrinkled, and ensure that the tray doors are closed firmly. Then hit start on the workcentre to continue any unfinished jobs.
Jun 19, 2009 | Office Equipment & Supplies
Xerox Phaser 5500 printer...paper stops halfway thru fuser unit.
Are the paper tray settings correct? If you have the tray mis adjusted, such as the tray thinks it has 14 inch paper in it and it has 11 inch, it will just shut down like that.
Make sure the settings are correct on the computer and the printer.
Also, its unlikely but the latch for the load springs in the fuser may be unlatched, but you shold NOT be able to close the covers like that.
Jan 06, 2009 | Xerox 5500/DT Laser Printer
5500 xerox phaser
Check the paper path for any and all debris. Use canned air to remove any debris. Also check the paper tray guides to see if they are matched correctly.
Oct 30, 2008 | Xerox Phaser 8500N Printer
Xerox Phaser 5500N Laser Printer Logo
120 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
