Question about Toshiba Televison & Video
TV-out problem with toshiba regza 32AV605PG 32"
I have a toshiba regza 32AV605PG 32" and I am trying to connect it to a laptop via tv-out cable. I have it connected to scart 1 on the tv and both computer and tv are set to pal but I only get a black and white picture.
I have connected the cable with the same computer to an older tv and that works, so the cable is fine.
can you help me out, how can I get color?
ctf1800
  • 4402 Answers
SOURCE: Toshiba Regza 32"
I would return it, sounds like the bulb died.
Posted on Feb 22, 2008
  • 43 Answers
SOURCE: Connect LG 42LY95 LCD to Toshiba Laptop
Hiran
can you use the vga source from your laptop to the pc input on the LG a standard vga monitor cable will do then set your laptop to output the vga signal
Scott
Posted on Mar 23, 2008
  • 48 Answers
SOURCE: I want to connect my Toshiba Satellite A305-S6863 Laptop to TV
You have to configure yout laptop to output through the s-video (which does not carry sound, so you need to either use the laptop speakers for sound, or the line output (headphone jack) to the TV).
I don't know if all toshibas are the same, but with mine, if I hold Fn (near the windows key) and press F5, it will change the output, do it a few times until you see a picture on the TV, some settings make this your extended desktop, meaning you can drag a window from one screen to another.
Posted on Apr 28, 2009
Testimonial: "Very helpful and well stated information! Thank you."
  • 814 Answers
SOURCE: no sound on my Toshiba Regza 42HL167
Found this troubleshooting method on the www.Toshiba.com website. Q. My TV has a picture, but there is no audio?
Models: 20DL77, 20HLK67, 26HL47, 32HL17, 37HL17, 42HL17, 26HL37, 32HL37, 20HL67, 26HL67, 32HL67, 37HL67,
42HL167, 42HL67, 47HL167, 52HL167, 42LX177, 46LX177, 52LX177, 57LX177
REF:FAQLCD00128
1. Please check your connections and make sure if you are using COMPOSITE “yellow, white, and red cables”, SVIDEO,
with “white, and red” or Color Stream COMPONENT “green, blue, red, white and red cables,” that the white
and red cables which are used for audio are plugged in securely into the same inputs as the video.
If your connections are secure, the station may have broadcast difficulties. Try a different channel.
2. If you are using the coax cable from the wall, press the “ENTER” button on the middle of the remote. If the
information provided shows that you have SAP selected we will need to change it to STEREO or MONO. To do
this, we will need to press the “MENU” button, and use the RIGHT or LEFT arrow keys to highlight the AUDIO
menu. Next we will need to use the DOWN arrow to select AUDIO SETUP press “ENTER” and then arrow down to
MTS and use the RIGHT arrow to select stereo.
3. If you have a cable box or satellite receiver, please make sure the TV’s volume, as well as the box’s, volume is
turned up sufficiently.
4. The station may have broadcast difficulties. Try another channel.
5. The sound may be muted. Press VOLUME.
6. If you still have problems after following these steps please contact Customer Solutions at 1800-631-3811 Monday
through Friday 8am to 7pm CST. The Toshiba customer service number is 1-800-631-3811. I hope this helps you with your problem.
Posted on May 17, 2009
  • 36 Answers
SOURCE: Connecting Compaq Presario CQ40 to LCD tv Toshiba REGZA '32'
Check your resolution output from laptop it maybe set to high for the TV to handle, also go to the Display Properties and ensure that the second monitor out is enable. Good luck!!
Posted on Aug 03, 2009
How do you change the time zone on 2007 Toshiba Regza 42HL67?
the manual doesn't mention anything about setting the time, so I am wondering if it comes from the cable or satellite box connected to it.
this is how it is done on another Regza model
Setting the time zone
The Time Zone setup will allow you to specify the
correct time zone for your region. This feature will
allow the TV status information to show the correct
time zone information for your viewing area.
From the SETUP menu, highlight TV Settings and
press T.
Press B or b to select Local Time Setting and press
T.
Highlight Time Zone and press C or c to set your
desired time zone.
If you want to activate the daylight saving time,
highlight Daylight Saving Time.
5
Press C or c to select On and press O.
Toshiba REGZA 46SV670U Owner Manual Setting The Auto Input Feature Setting...
your model manual
Toshiba 42HL67 42 LCD TV Service Manual
Jul 24, 2017 | Toshiba REGZA Televison & Video
How can i connect my toshiba 32AV600E to samsung HT-D455K via HDMI? but
Here is a link to the Toshiba owner manual:
http://www.regza-asia.com/pdf/LCDTV/AV600/AV600_OM.pdf
Note that the two HDMI connections on the Toshiba are for input and not for output of anything.
Jun 02, 2012 | Toshiba 32AV600E 32 in. TV
Ihave got a dvdxvideo combi plus a thomsons freeview box could you tell me how to plug it into the correct places please
best connect via a scart lead on the freeview box plug into scart socket marked tv and the other end into tv then select the av funtion on tv remote.
Jul 12, 2010 | Toshiba Regza 32LV67U 32 in. LCD HDTV
How do i connect my pc to my toshiba 42X3030D TV?
In the user manual it says what resolutions are supported. I think you have to adjust your resolution on your PC to match one of those listed.
Mar 11, 2010 | Toshiba REGZA 47HL167 TV
How to set up freeview on toshiba regza 32 inch tv
Make sure set on air,not cable in menu setting,Get a digital antena or a rooof antena.Hook up u should get the DTV free signal.
Nov 24, 2009 | Toshiba REGZA 32XV515DG 32 in. LCD HDTV
How do you play games on a regza toshiba tv i wana play games on my regza toshiba tv
What game system are being set to this tv?IF PS3 use a HDMI cable for connection to play.
Oct 12, 2009 | Toshiba REGZA 32WLG66 32 in. Television
Tuning my toshiba tv to hdmi
You don't need to tune it to HDMI. Connect the HDMI cable to the rear HDMI socket & then select the HDMI source from the remote control, this will switch the TV to this input & show whatever the picture is from that source ie DVD/Cable etc.
Aug 27, 2009 | Toshiba REGZA 32WLG66 32 in. Television
May 28, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Cant get dtv on my toshiba regza
Does it work with a DVD or VCR?
How is it connected? With a Coax cable or a an RCA component cable? Check that the correct video source is selected (The one associated with the input you are connected with) or that you are tuned to the correct channel on the TV if you are using the coaxial cable to connect. Could be channel 3 or 4 but I have seen them set for channels like 73.
Jan 03, 2009 | Televison & Video
Televison & Video Logo
549 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
