Question about LG DLE7177 Dryer
Dryer does not heat up/ dry clothes
LG DLE7177WM. # weeks old. Wored great until yesterday. HAve confirmed voltage to dryer is 240. Have tried sensor dry and manual dry modes. All the bells and whistles work, laundry tumbles and cycle counts down but no heat is ever produced. Getting ready to call LG as it's under warranty but was hoping for a quick fix to avoid this.
  • 20vturbo Sep 28, 2009
    weird. I pulled it out yesterday to check the vent hose. I pulled it out again today to check for power, upon pushing it back into place it suddenly started heating up again. Two loads later and it's drying away. Never had an intermittent dryer issue before?!?!?!?
  • statusmoe1
    statusmoe1 Aug 11, 2012
    so what did you end up finding out? Mine is doing the same thing.
  • 142 Answers
Sound like heater or stat call them out.
Posted on Sep 28, 2009
  • quady Sep 29, 2009
    poss loose connection some where, by moving it in and out could of remade connection intermitant faults are quite common and very hard to find sometimes,hopefully it will continue to work.
LG Model DLE1501W - I set the dryer for appropriate cycle. It shuts off after 10-15 mins or so. clothes are still wet.
The moisture sensors seem to be the issue. The two metal bars on the lint filter housing. Try cleaning with alcohol and stop using dryer sheets.
Dec 14, 2016 | LG Dryers
I have an LG gas dryer only 7yrs old. Some loads are coming out still soaked after the cycle has finished. I've looked through the back of the unit and the flame is igniting. However, I have noticed that...
i am not a dryer expert,so i can only make these suggestions.
1.make sure the lint filter is very clean.
2.make sure the dryer is sitting level on the floor.(if it isn't sitting straight on the floor,the clothes may not be touching the sensors,causing the heat to turn on & off while drying.
3 do not overload the dryer with wet clothes.
4.pick the right heat setting for the amount & type of clothes.
Mar 30, 2015 | LG Dryers
DLE7177WM - Seems to work ok, but it is taking
Its going to be an issue with the wall vent of your house. The dryer is not venting the air at a good enough volume and that is why it is taking longer to dry. Sometime you may have to run a second cycle and I bet there is lint on your door gasket around the 6 o'clock positon.
The flex vent behind the dryer, the wall vent, and or the vent's outlet (roof or wall) outside the home needs to be cleaned to improve the air flow.
Good Luck.
Jul 04, 2010 | LG Dryers
I have a LG DLE7177WM dryer that doesn't completely dry the clothes while using the sensor dry cycle. I have had it for just over 2 years and my wife said this hasn't been working correctly for a bout 6...
What I would do is check for air restrictions inside and out. Clean the dryer good and then check the thermister for proper tolerances using this service pamphlet
Mar 06, 2010 | Dryers
LG TROMM Front Load Dryer / Not drying clothes
check the vent or condensor depending on what type of dryer.
Sep 28, 2009 | Dryers
LG dryer (model DLE3733W) takes forever to dry the clothes.
check your vent hose for a clog. If dryer dont vent clothes wont dry.
Aug 25, 2009 | LG DLE3733 Electric Dryer
LG clothes dryer (DLE7177WM) signals completion of cycle when clothes are still damp. This even occurs when 'Very Dry' option is selected, which seems to now be required.
Hi thanks for the question The easiest thing to check is the venting make sure the dryer is far enough from the wall so the vent wont kink check and see the air going outside is not restricted in any way . dirty vents can also cause fires especially in gas dryers thanks for the question the appliance doc
Sep 12, 2008 | LG Dryers
LG DLEo332W electric dryer not drying full time
you have to change out the timer motor...
http://www.partselect.com/repair.aspx?appliance=dryer&part=dryer-wont-heat
Jun 08, 2008 | Dryers
DV338AG
Hi Linda,
First I would make sure the dryer is heating. If the dryer is heating then I would check the airflow out of the machine. Check the dryer vents, and check the opening outside where the air comes out. Make sure they are all clear and the air is flowing out properly. Any blockage in the vents will cause the dryer not to dry your cloths. If you find that your dryer is not heating, you should check the voltage to the machine. You should have 220-240 volts AC. If you only have 110 volts then you may have a blown fuse or a tripped breaker in your box. Reset the breaker or replace the fuse if you find one bad. If you are getting the proper voltage to the machine and you have good airflow and still not drying well. Call for warranty service. Do not attempt to do any internal repairs yourself. If you do this will void your warranty and you sure dont want to pay for service on a 1 week old dryer.
I hope this will FixYa, and if you have any other questions please feel free to ask. I am happy to help.
Mike Anderson
Jun 03, 2008 | Samsung 7.3 Cu. Ft. 9-Cycle Super Capacity...
Dryer will not heat
Hi jillsimons,
If you have had two new dryers not heating it really sounds like it may not be a dryer problem but a home problem. I would first make sure you have the correct amount of voltage to the machine. It will require 220-240 volts to operate correctly. If one leg you your breaker is kicked or you have a blown fuse in your breaker box then your dryer will only be getting half the voltage it requres to operate. It will run but it will not heat. Secondly if you do infact have the correct voltage then this could be the only other possibilty.
The dryer vent would either be to long or blocked off. This will cause the dryer to blow its thermostats and the dryer would then stop heating until the thermostats are replaced.
I am sure one of these will solve your problem. So check your breaker box, kick them off and back on then see if you get heat. Then check your vents. If they are blocked clean them out and get you some thermostats. Or call for service, since the appliance is new they will not charge you for a service call. Atleat I would'nt. Have a great day and good luck to you, I really hope this was helpful to you. MCA0824@aol.com
May 01, 2008 | LG DLE2512W Electric Dryer
LG DLE7177 Dryer Logo
524 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
