Question about Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
Will not start
Will not start .changed spark plug. seems to have no spark
    President:
  • 2,220 Answers
I
Ignition Coil Test
http://www.youtube.com/watch?v=L7WNBDRG4C4&feature=PlayList&p=3789DC1EE87C8098&playnext=1&playnext_from=PL&index=21
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You don’t have to bend up the electrode.
These flood easily and are very difficult to start once that has occurred.
Start Procedure
Cold:
  1. Ignition on/off to on
  2. Set compression release – optional step even if saw is equipped with a compression release
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls)
  4. Set compression release – optional step even if saw is equipped with a compression release
  5. Push (open) choke pull starter until it starts. (usually first pull)
Warm:
  3. Pull (close) choke, set fast idle - Don’t pull with choke closed.
  4. Push (open) choke, pull starter until it starts. (usually first pull)
Hope this helps
Lou
Posted on Sep 29, 2009
We changed spark plugs transmission fluid brakes and rotors and oil change. now it wont start it seems to be getting to much gas all at once can you help please?
Well, only the spark plug change would affect the vehicle from starting. If you didn't put the wires on in the correct order after changing the plugs, then it's never going to start until this is corrected.
May 25, 2015 | 2004 Chevrolet TrailBlazer
2003 ford crown victoria shuts off when driving i try to start it up it just cranks but wont start. Already changed the fuel pump and spark plugs and that dont seem to work. Any one please Help??
You'll first need to find out if you are lacking fuel or spark to know where to go next. Do a basic test for fuel pressure with a gauge and spark at the plugs when it fails to start.
Feb 16, 2015 | 2003 Ford Crown Victoria
Have a 1985 buick centruy with a 2.5 seems like its loading up with to much fuel wont start.I have spark timing is good, compression good, and changed the temp sensor. tried a different maf sensor(used)...
If you have spark, and the timing is good, you are either not getting enough fuel or there is not enough compression. If you checked the spark from the spark plug wires and got a spark, try changing the spark plugs. The spark from the plugs may be too weak to ignite the fuel.
Have you changed your fuel filter? This is a very common cause of a no start condition. Have your fuel pressure tested to ensure you are getting the correct amount of fuel. Also, you could try replacing your Fuel Pressure Regulator.
Feb 17, 2011 | 1985 Buick Century
Running real rough and uneven at idle and slower speeds
Seems like this car have the same symptom wherever it is, I have this trouble as well, I did the tune up, injection cleaning, change spark plugs and spark plugs wires, change the air filter, change the engine mounting but still the same trouble :(
May 03, 2010 | 1989 Toyota Camry
Honda lead 100cc scooter wont start atall.changed the spark plug and filter still no luck.doesnt seem to be getting petrol to the spark plug
maby you have touched somthing on the carb when you changed the air filter or maby spark plug is to big or maby faulty try new one or your old one
Apr 13, 2010 | 2007 Honda XL 125 V Varadero
Triumph sprint st 1995 wont idle,getting good spark, inside of tank painted brown! is this common? problem started with just riding along and the engine would stop, wait a few minutes start and off you...
Try changing your spark plugs, I have recently had a similar problem with a CBR900, spark plugs seemed to be fine (held against frame outside of engine) but didn't actually work under compression, changed for new and bike now runs like a dream.
Mar 12, 2010 | Triumph Sprint ST Motorcycles
Changed spark plugs because of misfire. now when
seems like you are leaking antifreeze inside your engine have it checked white smoke usually means antifreeze
Jan 10, 2010 | 1997 Mercury Sable
Changed spark plugs and wont start now
check the plug wires make sure tere are lined up propely then double check the spark by removing the #1 plug and see if it sparks when some one ealse trys to start it word of advice don't be hoding plug wire when they start it
Dec 05, 2008 | 1992 Honda Accord
1997 Pathfinder cranking but not starting
replace coil pack, or check fuel pump is working,worst case peplace ecu(engine management computor unit)check spark leads,and fit new spark plugs,discard all the ones in the engine ,thats in there,with new ones,,,,,,,
Nov 15, 2008 | 2001 Nissan Pathfinder
Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw Logo
227 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
