Question about Microsoft Xbox 360 Console
My xbox 360n has one red ring when i turn it on, how can i fix it?
    Novelist:
  • 168 Answers
This is a common fault with the 360, it says that its a "general hardware failure" which could mean anything
really. In truth its the lead free solder that cracks with so much heat and as a result the Xbox 360 fails
causing the 3rrod (3 red rings of death) or e74 or even no sound but graphics or sound and no graphics just like you are reporting.
Firstly get a spare av cable from someone else, try this, if that does the same then try a different scart
input on the tv. if all this fails you need to fix your machine as it WILL get worse
You will need to get a 3rrod repair kit or get someone to fix it for you, there are guides available on the
internet.
Posted on Sep 28, 2009
My xbox ix switching on and shows three red rings and after 5 minutes the brick turn orange and it now has two red rings whay do i do to fix it
Thanks for your question. To fix the 3 red lights what you will need to do is stop the heat getting to the GPU and the CPU and to do this you can use a good Xbox 360 Repair guide or of course you can send it in.
Jan 10, 2013 | Microsoft Xbox 360 Console
When i turn on my xbox 360 the on switch is turning red
It's called the ring of death
does it look like this?
there is a fix for it, I looked up a website for you, how to fix it.
http://www.squidoo.com/xbox-troubleshooting-red-ring-of-death-fix
I hope this helps you my fellow gamer.
Mar 03, 2011 | Computers & Internet
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
Red ring
hi there,
your xbox 360 need service open it and remove all dust around the fan and prosseser every thing fine again.
Jul 11, 2010 | Microsoft Xbox 360 Console
Xbox 360 power supply light turns yellow when xbox 360 is off (usually i think) and turns green when on, I've had one red ring on my xbox to,twice
make sure your xbox is in an open area where it can breathe, otherwise the one red ring means there is a hardware failure, if it is under warrenty send it back into xbox, otherwise there are some diy fixes on youtube
Mar 02, 2010 | Microsoft Xbox 360 Console
It freezes when you turn it on and shuts off. and when you try to turn it back on, instead of the green ring a red ring surrounds the xbox symbol.
It sounds like the RROD. If your XBOX360 is still under warranty, you can call Microsoft and they'll fix it. If not, you can either ship your XBOX off to be fixed by Microsoft or another company or try fixing it yourself. I fixed my red ring of death with a clamp fix (http://www.llamma.com/xbox360/repair/ring_of_light_x-clamp_fix.htm)
Jan 01, 2010 | Microsoft Xbox 360 Console
THREE RED LIGHTS
just got mine fixed call1-800-469-9269 took one week to get it back one of the first xbox 360 to come out . red death ring is because it over heated .didnt cost me anythang they even sent me the boxes to ship it in
May 16, 2009 | Microsoft Xbox 360 Console
X Box 360
It might be Red ring of Death problem, You can either send your Xbox toMicrosoft and wait for 2-3 weeks till you get back your Xbox or you canfix the problem yourself with the help of a DIY fix guide.
Check out the post discussing about RROD problem here: http://www.fix-xbox360.info/2008/08/23/xbox-360-red-light-fix/
Hope it helps...
Jan 05, 2009 | Microsoft Xbox 360 Console
Xbox 360 wont load to main menu. No red ring.
This is the problem with the GPU, Just fixed on the other day with the same problem. best way to fix it is with a heatgun and an xbox360 repair kit. The same kit for fixing the 3 red lights and E74 problems.
You can get the kit here.
Nov 12, 2008 | Microsoft Xbox 360 Console
Red rings
Unfortunatly you have found the "red rings of death" One of my friends had the same problem and he couldnt find any way to fix it, however he let his xbox sit for about a week then plugged it back in and it worked just fine so...I don't know exactly how to fix it but if you want to try to just let it sit it has worked for me. I recomend calling Microsoft and seeing if they will do anything about it.
Feb 25, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
