Question about Campbell Hausfeld PW1550 1550 Psi Electric Pressure Washer
Shooting water but no pressure-suggestions - Campbell Hausfeld PW1550 1550 Psi Electric Pressure Washer
Chrysler 3.3 Town and country, oil shooting out somewhere behind the water pump, what could it be?
Hi Nathan:
"Shooting out" sounds like a high pressire leak.
I would suggest that you give it a really good clean, and then run it for a very short time, Like only a minute. Use a mirror and flashlight to try to lee if you can see fluid.
The only high pressure oil that I can thinik of that is near the water pump might be pthe power steering pump. Perhaps one of the hoses has been chafing and has a leak.
Keep us informed as to what you find.
Mar 20, 2015 | Chrysler Town and Country Cars & Trucks
E11 frigidaire front load washer solenoid hums
change the water inlet valve located where the hot and cold hoses screw in to it
Dec 03, 2013 | Frigidaire ATF6000ES Front Load Washer
Water is shooting up in front of the motor
Autozone has a free loner tool called a pressure checker with your engine off ,make sure it has not rune for 8 hours remove the radiator cap(make sure radiator is full) install tester. Pump it up no more than 13 pounds of pressure. you will be able to tell where water is leaking from. If this was helpfull please leave me good feedback
Feb 23, 2013 | 1996 Ford Taurus
My whirlpool front load washer, only a year and a half in use, stops after filling and flashes the message F35. The trouble shooting manual does not give any explanation for F35. Any suggestions?
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&&&&
Jun 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Honda GVC 160 lost pressure - noticed small black valve (back - rear) after pressure builds up , short spray then nothing - hot water comes shooting out the black valve - did something pop off?
The small black valve is called a thermal relief valve. If it is open you will have no pressure. If the water is getting hot enough to pop that valve, there might be internal problems with the pump.
Nov 22, 2009 | Karcher 2500 PSI Pressure Washer
I have had 3 Karcher pressure washers all experience the same problem and so have two of my neighbors. Our area has very hard water and it causes problems with the washer not bringing up the pressure when...
If your water is that hard (and it appears it is) WD40 will NOT solve the problem. You should look into a water softener. However, chances are that a small, inexpensive model will not have the flow capacity required for a pressure washer. You'll likely need to look at a larger, whole-house model.
Use vinegar to through the machine's "soap" dispenser to break up the hard water deposits or a heavier solvent such as CLR which is available at most retail outlets.
Nov 04, 2009 | Karcher K2.26 Electric Power Washer
Porter Cable pcv2250 pressure washer shooting water out of siphon
non return valve on syphon injector on high pressure outlet stuck or 'o' ring worn. remove barb should be a spring and ball bearing in there.
it may be that the spring has broken too.
new non return valves are available.
Jul 06, 2009 | Porter Cable Cable Commercial Pressure...
Water pump presure is low
Obstruction I would say. check connection from supply, hose not folded or whatever.
Apr 14, 2009 | LG LDF6810 Built-in Dishwasher
Not enough water pressure to move upper arms or clean dishes
Recommend you pull the bottom spray arm straight up, then out of the DW.
Remove 9 phillips screws that hold the filter shroud down. Remove the filter and clean/rinse it out.
While the filter it out, grab a flashlight and inspect all over the sump area. Especilly in the area the has the check valve that rotates (Vario motor-driven) to feed the water pressure either to the lower and then the upper arms. Watch out for broken glass! Also, inspect the impeller to see if it is undamaged and spins easily.
Reassemble, then test out.
If problems remain, the the wash pump motor is probably the culprit. Do you get any error messages on the time display?
Good Luck!
Apr 05, 2009 | LG LDF6810ST Stainless Steel Built-in...
I have a frigidaire ultra quite modle number fdb126rbs1 there is a a spout with a rubber flap on the end and it is shooting water out of it with a lot of presure?
Hi, lilztheman
You said,
I have a Frigidaire ultra quite model number fdb126rbs1 there is a a spout with a rubber flap on the end and it is shooting water out of it with a lot of pressure?
And is the water inside your dishwasher and cleaning your dishes??
Please clarify what the problem is and what's wrong.
Where is it shooting pressured water too?
This dishwasher has the older tower type spray system inside the dishwasher.
It consists of a number of tower like tubes that fit one inside the other by the water pressure and they all are pushed up into each other to create a tower which sprays the dishes clean with high pressure water.
At the top of the tower is a plastic cap to direct the water with pressure in all directions!
Please tell me in detail what the problem is so I may suggest a solution.
Sep 17, 2008 | Dishwashers
Campbell Hausfeld PW1550 1550 Psi Electric Pressure Washer  Logo
159 people viewed this question
Top Campbell Hausfeld Garden Experts
John Trevino
Mike Squire
Are you a Campbell Hausfeld Garden Expert? Answer questions, earn points and help others
