Question about Sony Cyber-shot DSC-W70 Digital Camera
Says to turn camera off and then on again, but that does nothing
Camera turns on and says please turn camera off then on again, this is a never ending cycle have tried new battery etc etc, nothing works, also tried the tapping on carpet/table does nothing. please help...
The camera only says please turn off and then turn on again, when something serious is wrong. Could be a mechanical problem. like a lens that got stuck, but also when the camera can't access the memory. Please don't hurt your camera. Only when you know why and how to tap, it could help. But just tapping won't solve anything.
If the lens is really stuck, and you don't know what caused this, probably you can't solve this. When inside something broke, you can't solve this. Did you try to remove the battery for a little while and replacing it. Sometimes it can reset and forget a sensor is telling something is wrong. But really, if nothing helps, you only can get advice in a repair shop or with Panasonic.
Jan 04, 2014 | Panasonic Lumix DMC-LZ20
Casio Exilim won't turn on
My guess, only support people know what the two beeps mean.
Try to remove the battery and after a few seconds insert it again.
Then again switch on. If the error returns, contact the dealer or Casio support. Still it could be you think the battery is charged, but the capacity is not enough to power up your camera.
Dec 31, 2013 | Casio EXILIM EX-ZS10 Digital Camera
Suddenly I keep getting the message "please turn camera off and back on again" but nothing happens when I do I just get the message again. I can turn the dial to view pictures but if the dual is turne
did you try to wait several seconds before turning the camera back on?
When it happens again, after turning off the camera please remove the battery for a few seconds and put it in again. then switch on.
If the problem persists goto the repairshop or your dealer.
Dec 23, 2012 | Panasonic Lumix DMC-FZ20 Digital Camera
Camera will not turn on, says turn off camera and turn on again, but does nothing else
Click on the link below to fix the Camera issue. This link will be helpful for you in future too
Troubleshoot Camera Issue
Regards,
Suhail
May 16, 2012 | Pix Cameras
My m1093 kodak camera won't turn on, it turns on briefly and then turns right back off again. i have tried charging it but nothing works
try taking out the battery and memory card, then put back in the battery, and try turning on again
then if that works put in the memory card and turn on
or try connecting to ur computer and transferring the pictures and then disconnect and try turning on again
Aug 04, 2010 | Kodak EasyShare M1093 IS Digital Camera
Error message
This may be due to the aperture ring in your lens. Try the following:
1. Turn off your camera
2. Move the aperture ring clockwise then lock
3. Turn on your camera and try again.
If this does not work, do the same thing again but turn the aperture ring counter-clockwise.
Sep 20, 2009 | Nikon D80 Digital Camera with 18-135mm...
Panasonic dmc fx-10 digital camera -
The lens may be broken(barrel)replacing kost you about 175,00 euro
May 11, 2009 | Panasonic Lumix DMC-FX10 Digital Camera
Sony Cyber-shot DSC-W70 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
