Question about Kenmore 73952 Gas Dryer
My kenmore dryer is not heating
I have a kenmore elite gas dryer and it runs but it is not heating up. any suggestions
  • Anonymous Oct 06, 2008
    dryer wont heat
Check the thermal fuse
Posted on Dec 27, 2007
  • 66 Answers
Ck the igniter if it get hot red.if not .replace it.
Posted on Dec 20, 2007
Kenmore elite dryer not hearing
Most likely the heating element or wrong voltage if an electric dryer. If it is gas it could be the coils located on the gas valve. The gas valve itself. Or the ignitor.
Mar 06, 2015 | Kenmore Dryers
He3 gas dryer not heating
http://homeguides.sfgate.com/troubleshoot-kenmore-elite-gas-dryer-wont-heat-77443.html
Apr 30, 2014 | Kenmore HE3 Gas Dryer
Hello! Yesterday we cleaned out our home dryer vents. Today the heat wil not come on in our kenmore elite dryer. It tumbles and blows cool air, just no heat. Suggestions? Thank you!
If you have a gas dryer, your problem is probably caused by the ingition panel.Generally, with a gas dryer, there is an ignition device that heats to a specific temperature and this causes the gas to ignite. When this electric ignition fails to work, the gas will not ignite and there will be no heat. I had this happen and had to call a professional. It was a simple matter of installing a new ignition device and it worked perfectly for years. I hope this helps! If it is a new dryer, check to see if this part might be covered under warranty.If this helps solve your problem, please come back to Fixya and rate my advice
Jul 25, 2011 | Kenmore Elite HE4 Electric Dryer
I have a kenmore elite he4 dryer and it is running but isnt getting hot. Need to know where the fuses are located to check them
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 04, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite will run, but won't heat
could be the thermal fuse or the heat element to start with.  also, check to make sure you have 220v at the outlet
Jul 08, 2010 | Kenmore Dryers
Kenmore Elite HE4 gas dryer, no heat at all
The ignitor may be bad or the thermal fuse may be failed.
Aug 27, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer won't Heat up - Kenmore Elite HE4 Gas Dryer
hi..A poor connection between the wire terminals and the
heater relay causes high current draw and damages the
terminals on the heater relay on the main control board.
check it out..
thank u..
kindly rate my response..
Jun 09, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore elite dryer no heat
You may want to check if the heating element needs replacing. Most Dryers have 2 heating elements that are found by taking the back off, some of the newer dryers have 3.
Jun 08, 2009 | Kenmore Dryers
Kenmore Elite gas ddryer model 72062--No heat
Check the glow coil ,if its not glowing run a test for voltage when its heating ,should be around 117 volts.check thermal fuse.
Please Rate This !!!!
Aug 10, 2008 | Dryers
Kenmore 73952 Gas Dryer Logo
253 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
