Question about HP LaserJet 4 plus Printer
This is for a HP Laser Jet 4. I have had it for years and it has worked well. Now on an erratic basis, paper gets hung up sometimes only partially coming through (with wrinkles at the end) other times it is hung up in the machine. It is not consistent, but the hang ups are more frequent recently and especially so when I ask it to print a multipage document. I have given it a thorough cleaning, but to no avail. Any help will be appreciated.
Symptoms: Your HP LaserJet 4/4M is constantly jamming at the back of the printer. Sometimes the paper is folded like an accordion. Other times the paper has a big curl on the bottom
How to fix:
http://fyrskeppsvagen.com/tips/printers/hp_lj4/paperjam_accordion.html
Posted on Oct 05, 2009
I have a snow king sno blower HMSK80 ,with a Tecumpsh 8hp,how do I adjust the carb., #1432F6h
If you have an adjustable main jet on your carb. Which is a screw sticking out of the bottom of the carb bowl. And you tried turning it and nothing happened. Then chances are your carbs main jet is just partially blocked. So no amount of adjusting will richen the mixture up. If your snow blower has a few years on it you may also be suffering from poor valve clearance which can sometimes cause erratic operation. A compression gauge will let you know if you are in need of a valve grinding or not. Finally you can try draining your fuel out and getting fresh fuel. Also be sure the fuel doesn't go into any can with old fuel in it. Be safe and good luck!
Feb 16, 2015 | Garden
Hp laser jet 5025 paper jam
Clear the paper jam...
Also make sure all the pick up rollers are not smooth, if they are replace them. Also make sure the tray is set to the right paper and not offset. A lot of times people slam the tray and it moves the setting bar.
Jul 09, 2012 | HP LaserJet M5025 Printer
Manual laser jet 4
The paper size selection knob or MP paper size does not
match the installed paper or more than one sheet of paper
was picked up.
Oct 23, 2011 | HP Hewlett Packard LaserJet P3005n Printer
I have an HP Laser Jet 1320. The error light with the triangle and the explanation point is flashing. There is no paper jam. I have turned off the unit and plugged it back in. Can you please tell me what...
Its indicates attention..1. door open 2. cartridge missed 3. no paper in tray 4. paper jam.
open the door there is notch which pushes the switch check notch broken? reinsert the cartridge check, load paper in tray check paper sensor flag strucked. Lift registration assm plate any paper partials under clean it..
Sep 07, 2011 | HP LaserJet 1320 Printer
HP Laser Jet 4250, print getting very light in last few months or year. 135K page count, 6 years old, 600 DPI, PCL 5 - Windows Vista HP Cartridge, or compatible cartridge no difference - still light No...
The laser mirror could be dirty, the transfer roller could need changing. Looking at the "print quality" sub menu, the toner density default setting is 3. Up it to 4 or 5. See if that makes a difference. Remove the cartridge and open the covers. Use canned air or an air compressor and blow out the printer.
Sep 01, 2011 | HP Office Equipment & Supplies
Laser Jet 4 plus can't print with USB?
1.check the cable compatibility
2.install the driver HP laser jetIII
Sep 05, 2008 | HP LaserJet 4 plus Printer
Hp Laser jet 4 plus
Bad toner cartridge or fuser is burned out.
Aug 15, 2008 | HP LaserJet 4 plus Printer
HP Laser Jet 2550l
When moving/storing Laser printers, its suggested that you remove all Toner Carts prior to the unit being moved. The Toner "Dust" (If you will) will settle in the bottom of each cartridge, and become compact. (When LJ's are used on a normal basis, the toner is tumbled around like clothes in a dryer).
Sometimes just turning (Shaking?) your toner carts will help the toner flow better in the drum.
I hope this helps you a little.
Jun 26, 2008 | HP LaserJet 2550L Printer
HP 1510 - Photo Paper Jams
Hi, try using HP brand photo paper, HP makes their special photo printers and special photo paper for them.
The surface of the back of the HP's paper is rough, like sandpaper to avoid the paper being jammed in the cheap loading mechanism of their actual printers.
Oct 11, 2007 | HP PSC 1510 All-In-One InkJet Printer
HP LaserJet 4 plus Printer Logo
197 people viewed this question
Seeker5211
Seeker5211
