Question about Zenith R50W46 50" Rear Projection Television
Zenith R50W46 My colors all went haywire. My tv mostly shows green, no matter what adjustments you make. Someone said the convergence was bad, or my tubes were out of line. Run convergence but it doesn't change anything.
  • 1,113 Answers
Jennifer
Yes could be a convergence issue, but if you get no results with adj it will need the convergence boards worked on / replaced. ie you need to call a tec. to look at it, this is not something that will fix without pulling it appart.and performing repair work on it.
S.
Posted on Dec 18, 2007
    Master:
    Sergeant:
  • 482 Answers
Take it to a TV repair place, they charge $50 to look it over and tell you what it takes to get it back up. This is your cheapest way out if you want to try to keep it.
    President:
  • 4,402 Answers
You have bad convergance ic that need to be replaced.
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Shadows of green and red in picture
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 08, 2011 | Zenith R50W46 50" Rear Projection...
Colors are misaligned on my zeneth r50w46 and the auto convergence option did not solve the problem. the red droops off on the left side of the screen and the green droops across the top center.
Your convergence IC's are out and this is why you can't use the auto or manual convergence. This type of repair done at a verified Zenith service shop most likely will run you $400.00 to $500.00 dollars. However, if you have some electronic skills and are familiar with soldering and de-soldering, you can do the repair yourself for around $85.00 to $100.00. You will need to buy a convergence repair kit which has all the parts you need and gives pretty straight forward instructions. Plus, if you run into trouble, they have online support. Here is the link for the convergence kit.
http://servicemanuals.vstore.ca/product_info.php/pName/zenith-r50w46-r57w46-convergence-repair-kit
This is not really a hard task to do. It usually takes about 2 to 3 hours from start to finish if you take your time and make sure you follow the instructions to the letter.
Again, if you don't have any sort of electronic skills, it is always better to have the unit serviced by a professional.
Apr 14, 2010 | Zenith R50W46 50" Rear Projection...
Image is out of focus. colors do not align
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
9e1b49a.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Jan 14, 2010 | Zenith R50W46 50" Rear Projection...
My tv is blurry, showing green and red waves...zenith d61w25
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic2_bing.gif,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 01, 2009 | Zenith D61W25 61" Rear Projection...
Zenith R57W46 bottom bowing and color off and double lettering
Projection TV sets have two very common problems listed below.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
*Screen Looks 3-D
*Colors wont align
Mar 28, 2009 | Zenith R57W46 57" Rear Projection...
Doubling
you can get the convergence repair kit to repair that problem at this link. The kit contains both ICs and the feed resistors, and also has instructions so you can do the repair yourself.
http://servicemanuals.vstore.ca/product_info.php/pName/zenith-r50w46-r57w46-convergence-repair-kit/cName/convergence-repair-kits
Feb 02, 2009 | Zenith R57W46 57" Rear Projection...
I want to fix the convergence of a zenith r50w46
•Screen looks 3D
Jan 12, 2009 | Zenith R50W46 50" Rear Projection...
Color mostly green
Sounds like tyo me that the picture tube is getting soft on ya!!. Its a common factor that occours with all tvs but mostly with zenith. A service tech might be able for a small fee rejuvinate the picture tube but theres never a warrantee with this type repair. Its not something a user should attemp to do as theres hi voltage inside this set even on the tube socket after its ubplugged for awhile. Seek the advise of a repair pro to see how bad the tube is. Good Luck
Jul 02, 2006 | Zenith A27A23W 27" TV
Zenith R50W46 50" Rear Projection Television Logo
239 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
