Question about Dryers
I have a Whirlpool electric dryer Model LEC6848Aq3 that stopped heating. Any ideas on where I should check?
  • 142 Answers
Check heater or tocs or thermal fuse.
Posted on Sep 28, 2009
Whirlpool electric dryer LER5620KQ1. won't heat up timer does not advance
Same problem with my Whirlpool Dryer: Model LER4634EZ2 which stopped heating. I checked the coils that was "OK" then I checked the fuse that was "OK" I replaced the Thermal Fuse and High Limit Thermostat then after starting the dryer the heat came on ... problem solved NO.... the dryer just kept running and running until I opened the dryer door. Not going to put 70 or so $$$ into this 10 year old dryer which up until 12/15/2011 worked fine.
Dec 08, 2011 | Whirlpool LER5636P Electric Dryer
My Whirlpool clothes dryer model GEW9200LW0 stopped drying completely. The drum turns but no heat. It began slowing down the heating process approx. 2 years ago. Any suggestions?
Electric Dryer Does Not Heat
  • If your Whirlpool electric dryer is having trouble heating, you should check all of the thermostats, the thermal cut-off, all fuses and the electric heating element for continuity and proper connection.
Apr 18, 2011 | Whirlpool GEW9250 Electric Dryer
Whirlpool dryer stopped heating Model - wed5500sq0
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101.,.,.
Mar 21, 2011 | Whirlpool Dryers
I HAVE A WHIRLPOOL DRYER MODEL LER4634PQO...IT WON'T STOP RUNNING WHEN IT GETS TO END OF CYCLE AND IT DOES NOT HEAT UP
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 10, 2011 | Whirlpool Dryers
My whirlpool electric dryer stopped heating up, any ideas what it might be,could be as simple as the heating element
Here is a video to show you what to check in the dryer for the "no heat" condition.
Jan 05, 2011 | Dryers
Hi, I have a whirlpool dryer model WT84503, it has topped heating. Any ideas? I though it may be the thermal fuse but not sure were to find it in the dryer.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 26, 2010 | Whirlpool Dryers
Our Whirlpool Gas Dryer (Model No. WGD5200VQO) doesn't seem to heat up. It runs for hours and hours to dry a load of laundry. Admittedly, it never really worked that great since it was new. Any ideas on...
heatman101
Oct 02, 2010 | Whirlpool Dryers
The dryer stopped heating. any ideas? mark
Hello, Most likely cause is the thermal fuse part 59 on the schematic I have provided. you should test it with an ohms meter. It will read infinite if it is good. Hope this helps. Mike i338426.gif
Nov 24, 2009 | Whirlpool GEW9250 Electric Dryer
Dryer Stopped Heating
Use a multimeter to check the heating element. You can't always go by looks. Check continuity and if there is none, the element is defective. Another thing to check is the thermal fuse. It is about an inch long and is usually attached to the exhaust duct. Use the meter to check it as well and if defective, replace it. Sure hope this helped and best wishes.
Jul 28, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool Electric Dryer
need more info on your unit the ending of the model here is a link to the service manual on this unit just pick the right ending to your model if you have any more questions please post it here http://servicematters.com/docs/wiring/wiring_main.htm
Dec 10, 2007 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
94 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
