Question about HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook
Hp dv2500 wont turn on
I have an hp dv2500 and when i push the power button it lights the lights up for about 2 seconds then goes off again i have tryed using just the power adapter with no battery and then just the battery, i have checked the hd, memory and i getthe same result every time
  • shadow83
    shadow83 Sep 29, 2009
    ive already tryed that and its not in the power adapter or the plug tech support from hp thinks its in the cpu what do you think?
  • Elz824 Nov 26, 2009
    i turn on my laptop and nothing but 99 99 99 99 99 comes all across the screen..
    what to do???
  • 40 Answers
Does the laptop plug in tightly to the power socket
if not the pavilion part to get the system power needs replacement
contact a local technician and state the power adapter plug-in on the motherboard needs replaced
these commonly go bad on pavilions
it should cost you less than 100usd to repair
or rma the laptop if you have warranty coverage left on the hp dv2500
good luck
Posted on Sep 28, 2009
Testimonial: "thanks "
  • marktyan
    marktyan Sep 29, 2009
    yep.. if the computer never "beeps" once.. then the MB or CPU are bad...
    try to pull the memory totally out of the laptop..
    if it makes it to the memory testing .. a beep beep beep repeating should occur
    if so then the cpu is okay.. then it is the motherboard
    mark
Printer does not print
Instructions
    • 1 Switch the Canon MX310 off using the "Power" button, then push the "Stop/Reset" button on the control panel. Hold the button down for about five seconds.
    • 2 Push the "Power" button while holding "Stop/Reset." Hold down both buttons for five seconds.
    • 3 Release "Stop/Reset" while holding down the "Power" button.
    • 4 Push "Stop/Reset" twice while continuing to hold the "Power" button. Release the "Power" button. The power light will turn green.
    • 5 Once the light is steady green, push "Stop/Reset." Wait about three seconds and push it again. Wait three more seconds and push it one final time, for a total of three times. The power light will turn orange.
    • 6 Push the "Power" button, then lift the MX310 cover open.
    • 7 Remove both ink cartridges and wait 10 seconds. Replace the cartridges and close the MX310 cover. Wait 30 seconds.
    • 8 Push the "Power" button. Wait a few seconds to allow the printer to fully power down, then switch the Canon MX310 back on using the "Power" button.
Jul 23, 2014 | Canon PIXMA MX310 All-In-One Printer
I have an hp dv2500 and when i push the power button it lights the lights up for about 2 seconds then goes off again i have tryed using just the power adapter with no battery and then just the battery, i...
According to the manufacturer's web-site, some HP notebooks manufactured in 2007 and 2008 have been "recalled", due to an overheating problem with the video-card triggering wide-spread failures.
HP will repair those affected computers for free. Just contact them.
Nov 06, 2009 | HP Pavilion dv2500t Notebook
My sandisk mp3 is frosen on the meau and wont trun
1. Push the "Power" switch downward into the "Hold" position.
2. Press and hold the "Menu" and "Record" buttons at the same time until the device resets.
3. Push the "Power" switch upward all the way to turn it back on.
OR
1. Grab a steady hold around the device.
2. Push the "Power" upward and hold it there until it powers off.
3. Power the device back on by releasing the power switch and then pushing it upward again.
OR
1. Unscrew the screws on the back of the device (or simply push the lid off if it is a model without screws.)
2. Take out the batteries from the slot and wait until the screen goes black.
3. Insert the batteries the same way they were mounted and attached the lid again.
4. Push the power switch upward to turn on the device.
Oct 01, 2009 | SanDisk Sansa e250 MP3 Player
HP Pavillion dv2500 laptop will not boot up.
Pressing the f8 key doesn't work either? This should boot the laptop to safe mode, if it doesn't then check the memory cards before you do anything else, try to get somebody with the same type of memory card to lend it to you. If that doesn't work, then your HDD is corrupted, and to re-install Windows.
Sep 05, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Compaq Presario F700 wont boot. Powers up then turns off again a
that means you might have a hardware failure. possible powersupply. check with local shop.
Jun 17, 2009 | HP Compaq Presario F730US Notebook
HP officejet D135 scanner and copyer
Hi..
if the scanner bulb is not moving, then its an hardware problem.
We can try by resetting the printer.
POWER DRAIN:-Turn off the printer, Unplug the power cable from printer and from the wall outlet.Press and hold ON buton for 30-60 seconds.
PARTIAL RESET:-Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the buttons.
----(for below reset cartridges must be removed out)---------
SEMI_FULL RESET:-Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait untill the ON light flashes,or wait for 20 seconds,hen release the button.If the printer goes off dont worry release the button and Push the ON button.
FULL NVM RESET:-Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold OK/ENTER and CANCEL button and connect the Power cord while holding the buttons.keep Holding the buttons until the printer goes off ,release the button and Push the ON button.
(Notes - resets will take a while)
Please let me know after resetting.
Thank U!!
Feb 10, 2008 | HP OfficeJet D135 All-In-One InkJet...
Chatters
i belive that your printer needs to be resetted. Just try the reset options which are for HP 6110xi.
FULL NVM RESET:-Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold OK and CANCEL button and connect the Power cord while holding the buttons.keep Holding the buttons until the printer goes off ,release the button and Push the ON button.
Thank You
Feb 10, 2008 | HP OfficeJet 6110 All-In-One InkJet...
All lights flashing
This is HP's "Full Reset" solution:
1. Turn the HP All-in-One off.
2. Unplug the power cord.
3. Wait a minute, then plug the power cord
back in.
4. Turn the HP All-in-One back on.
Is that what you have already tried?
Oct 06, 2007 | HP Photosmart C3180 All-In-One InkJet...
HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook Logo
869 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
