Question about Whirlpool MH1150XM Convection/Microwave Oven
The guys here gave me good advice and that I probably need a new magnetron for the Whirlpool MH1150XMB-0 (runs but does not heat food). I think I can replace the magnetron but dismantling this hood microwave and vent and stuff will be a big problem. I don't know how to do it.
  • 3 Answers
DO NOT!!!!!!!!!!!! undertake this job unless you have a pair of discharge leads and you know how to discharge this appliance the capacitor holds a charge large enough to kill you for about a month
Posted on Sep 28, 2009
My microwave won't warm anything up. Everything works, except it doesn't heat my food.
The magnetron (the part that heats the food) may be bad or the circuitry to the magnetron may have burned out. Basically my advice is that if you have no electrical expertise, it isn't worth fixing. The magnetron if bad, costs almost as much as a new microwave. If you open it up (make sure it has been unplugged for a few hours and don't seen any obvious burnt parts (including a fuse and the diodes), then most likely the magnetron is done and a new microwave is the way to go.
Let me know how this works out for you.
Benjamin
Aug 18, 2010 | Whirlpool MH6150XLS Microwave Oven
Microwave not heating up
If the microwave is not heating check magnetron connections, probably you will need to replace the magnetron.
Sep 06, 2008 | Microwave Ovens
Whirlpool model number MH7140XFB no longer heats
you either need a new h.v. capacitor or h.v. diode in the magnetron circuitry if you cant hear it cycle when it runs as in a low pitched hummmm when its drawing current to operate the magnetron tube, each part runs about $30 to $45 each,normally its the h.v. capacitor though
Jul 28, 2010 | Whirlpool MH7140XF Microwave Oven
Not heating food, not cooking, vent is not operating... After the installation of the microwave today, the timer works well. When trying to heat up anything, it does not work (the timer goes on and at the...
The magnetron (the part that heats the food) may be bad or the circuitry to the magnetron may have burned out. Basically my advice is that if you have no electrical expertise, it isn't worth fixing. The magnetron if bad, costs almost as much as a new microwave. If you open it up (make sure it has been unplugged for a few hours and don't seen any obvious burnt parts, then most likely the magnetron is done and a new microwave is the way to go.
Benjamin
Jul 20, 2010 | Whirlpool WMH1162XVS Microwave Oven
No heat
Benjamin
Jul 18, 2010 | Whirlpool MH1150XMQ Microwave Oven
Whirlpool MH1150XMB-0 runs but does not heat food
If the housing of the unit isn't too difficult to remove (normally 3-5 Phillips screws around the rear edge), with the unit unplugged of course, check for a user replaceable fuse inside. The magnetron is separately fused and fuses can fail due to metal fatigue. It will be high amperage; 10-20 amperes and many hardware stores will have them. BTW, there is no residual radiation from a magnetron that isn't operating.
Aug 18, 2009 | Whirlpool MH1150XM Convection/Microwave...
MICROWAVE WONT HEAT
the lock on the door could be loose so the microwave light will turn on but it wont heat u should press on the door or buy a new one emai me at chattarbox24_7@yahoo.com
Jul 21, 2009 | Microwave Ovens
Whirlpool Microwave no longer heating
Sounds like the magnetron has failed. It is the magnetron that generates the microwaves that heat the food. If it or the circuit that powers it fails then it stops heating. There are some high voltage circuits that feed the magnetron and you can potentially get hurt if you don't know what you are doing. Would recommend you have it serviced by a professional if you want it fixed, otherwise look for a new one since the cost of repair can come close to the price of a new microwave oven.
Jan 10, 2009 | Whirlpool MH1170XS Microwave Oven
Whirpool microwave MH1150XMB-1 fan is on when heating
yes , that is how it works. fan cools the magnetron so it run the same time it is heating. you have to look at the fan why it is very noisy, it could have been touching some wires or the bushings may need lubrication. you have to bring it down again, remove the fan and bench test it . lubricate the bushings if necessary.
tnx 4 using fixya,
drcool
Sep 18, 2008 | Microwave Ovens
MIcrowave light and turntable are working, but food comes out cold
I suspect the magnetron or high voltage transformer, and either part's cost or labor would probably be about the same as the cost of a new comparable unit.
Aug 14, 2008 | Whirlpool GH5184XPQ Microwave Oven
Whirlpool MH1150XM Convection/Microwave Oven Logo
327 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
