Question about EPoX EP-9NDA3I Motherboard
It appears that the network connection on my ep-9nda3I is faulty. Th router I connect via wire to it is working fine as is the modem (neither allow my computer to access the internet) help!
Have you installed new antivirus programs lately on your system? Try to check your antivirus program and check your settings to see if blocks internet acesss.
Try uninstall Antivirus and see if this has improved your access.
Ples Mangi
Posted on Sep 30, 2009
My Officejet wont print pdf files from my minimac (os 4.11) but prints fine from my pc running xp. Also my mac has lost ethernet connectivity, but the pc works fine. Any sugguestion how to fix?
This seems to be a single issue. The fact you cannot print to a presumably shared printer AND cannot access the network or Internet, would indicate your issue is simply connectivity related.
Are you connecting the Mac via wired ethernet cable or wireless?
If it is wired, check your connection via the network icon on your screen (usually upper left) Click on the icon and choose "Open Network Preferences". In the window that appears, check on the left side to see if the appropriate connection has a green, yellow or red dot next to it. If the dot is red, you are not connected. If the dot is yellow, you are connected but there is an issue.
If the connection is wired and there are other computers able to get online, then check the cable connected to the Mac or replace it.
If the connection is wireless, then check try reconnecting again and make sure you are using the right passphrase for your security requirements. You may need to delete the profile and recreate it. You can do this by clicking on the Wi-Fi item on the left panel of your Network preferences window and then clicking on Advanced button. In the following window that appears, find your wireless network name in the list under Preferred Networks and click on it to highlight it. Then click the - button to remove it. Then close the window and try reconnecting to the network from the icon on the bar at the top of your screen, using the correct network passphrase (if needed).
If this still does not work, think this through...
1. Is any other computer using wireless connection and having a similar connection issue?
2. Did this computer EVER connect to the network and Internet successfully?
If the answer to either question is yes, then the problem is likely your Router/Modem. power OFF the router (and modem if separate) for about 30 seconds and then power it ON. See if this resolves the connectivity issue. If not, consider doing a factory reset on the router/modem, but make sure you have the appropriate settings needed to configure the router and/or modem as these will likely be lost when you reset the devices and will be required to get connected to your Internet Service Provider.
If the answer to question 2 above is NO, then the problem is directly related to the mac. If you are trying to connect via wireless, try connecting with an ethernet cable instead to make sure the mac can connect that way.
If neither way seems to work, it may be possible there is a network configuration problem, defective router, or possible network conflict present and may require a more professional approach requiring a visit from a networking professional to resolve it.
Apr 15, 2013 | Apple Mac mini G4 Desktop
Tip
Connecting ur Nokia N95 to internet through WIFI [No Wireless Router]
Tutorial for connecting ur Nokia N95 to internet through WIFI [No Wireless Router]
Hello mates,
Finally after 4 hours of searching and trying I was able to hook my Nokia N95 to my laptop without router and browse internet on my mobile.
I tried using my laptop’s Wi-Fi Card as router or connection point between my pc and my phone.
This connection is known as “ad-hoc” connection. Ad hoc wireless networks work more like walkie-talkies, because the computers communicate directly with each other. By enabling Internet Connection Sharing on one of the computers, you can share Internet access.
To see the difference between ad-hoc and router check the picture
With router
http://img127.imageshack.us/my.php?i...3669887ko0.gif
With ad-hoc
http://img408.imageshack.us/my.php?i...9484580ds9.gif
Now lets see what do we need:
1. We need a Wi-Fi card on the computer
2. Internet connection that doesn’t use your Wi-Fi card (example Like mine: Cable-modem connected to my laptop through LAN).
Now Let’s Setup our Wi-Fi card as router:
1. Click Start, and then click Control Panel.
2. Click Network and Internet Connections.
3. Right-click your wireless network connection, and then click Properties.
4. In the Wireless Network Connection Properties dialog box, click the Wireless Networks tab.
5. Next, click the Advanced tab at the top of the window. Select Computer to computer (ad hoc) networks only and clear the Automatically connect to non-preferred networks box if it is selected. This setting, along with removing preferred networks, ensures connection to the ad hoc network only.
6. Click the Wireless Networks tab again. Under Preferred Networks, click Add,
7. In the Wireless Network Properties dialog box, specify a Network name (SSID). I chose (My Nokia N95).
[img=http://img111.imageshack.us/img111/487/37714878od7.th.gif]
8. Unclear the box “ the key is provided for me automatically”.
[img=http://img87.imageshack.us/img87/9949/86872283hs2.th.gif]
9. Type your Network key password and confirm it in the second Network key conformation box( your password has to be 5 characters or 13 characters ), Press Ok.
[img=http://img503.imageshack.us/img503/9176/10is2.th.gif]
10. After configuring the network name (SSID) in the Wireless Network Properties dialog box, the new ad hoc network will be displayed with a PC Card icon to designate that this is a computer-to-computer network. Press also Ok.
[img=http://img111.imageshack.us/img111/4931/101mu2.th.gif]
11. Right-click the Wireless Network icon in the lower right corner of your screen, and then click View Available Wireless Networks..
[img=http://img503.imageshack.us/img503/7017/12yf6.th.gif]
12 . The Wireless Network Connection window appears and displays your wireless network listed with the SSID you chose( My Nokia N95). If you don't see your network, click Refresh Network List in the upper left corner. Do not click Connect in the lower right corner.
[img=http://img87.imageshack.us/img87/6600/13wm3.th.gif]
Now we have to share the internet:
14. Click Start, and then click Control Panel.
[img=http://img111.imageshack.us/img111/6918/14ta5.th.gif]
15. Click Network and Internet Connections.
[img=http://img503.imageshack.us/img503/5887/15xb5.th.gif]
16. Since I have a cable modem and it connected to my laptop through LAN so must share its connection with My Wi-FI card. Right-click the Local Area Connection and press properties.
[img=http://img503.imageshack.us/img503/4872/16ck2.th.gif]
17. Now you are in Local Area Connection Properties choose tab Advanced.
[img=http://img111.imageshack.us/img111/2746/17ih3.th.gif]
18 . select the Allow other network users to connect through this computer's Internet connection check box.
[img=http://img87.imageshack.us/img87/8369/18ve0.th.gif]
Now On Your Nokia N95 Phone (I have v20 Firmware) :
19 . Go to Menu>Tool> click on WLAN Wiz. Your Network name should appear ( in the example its “My Nokia N95”).
[img=http://img87.imageshack.us/img87/6633/screenshot0004vw7.th.jpg]
20. Select Option > Start Brwosing.
[img=http://img503.imageshack.us/img503/1807/screenshot0005wj4.th.jpg]
21. Now it should ask you for the Network key password you entered in step 9 and Press OK.
[img=http://img503.imageshack.us/img503/9264/screenshot0007yk6.th.jpg]
22. Now it opened the web so I chose Nokia Nseies web site ans start browse it.
[img=http://img87.imageshack.us/img87/4574/screenshot0010oq1.th.jpg]
23. While it connecting to” My Nokia N95” you should see that your phone Network status will appear Connected on your computer.
[img=http://img503.imageshack.us/img503/6197/19aw8.th.gif]
24. Wait for 30 Second and it will Open.
[img=http://img87.imageshack.us/img87/2649/screenshot0011qg4.th.jpg]
Note Important : you should turn you firewall off because it will block the connection and after you succeed connecting N95 to internet try configure your firewall so it will allow internet accesing.
on Aug 30, 2009 | Nokia 9500 Communicator
3G usb modem wont connect to internet through wireless router
Sure you can that. 1. you have new internet connection. need to configure the router according to internet connection type. it could be manually ..
2. set the wireless settings on the router again manually.
then try to connect the router.
If you need my help
the send me some information about the network.
1. when you connect your pc to modem what ip address you get.
2. what ip you get when u connect your pc to router. make hard wired in both condition.
and possible send me your email add.
Dec 23, 2012 | Computers & Internet
No lan enternet
you will need to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled
If you are trying to connect through a modem/router the driver should have come with a disc provided by your ISP internet service provider or your motherboard disc
you might have to connect the usb lead to your modem to get a connection then
click start control panel administrive tools computer management device manager scroll to network adapters should see a yellow question mark? right click install drivers if you cant find the driver hopefully one of these will help you
http://alpha.majorgeeks.com/Intel_Network_Adapter_Driver_for_Windows_7_d6273.html
http://majorgeeks.com/SiS191_Gigabit_LAN_&_SiS190_LAN_Driver_d5923.html
http://majorgeeks.com/IntelR_PROWireless_LAN_2100_Network_Connection_d4598.html Latest
http://majorgeeks.com/downloadget.php?id=5240&file=15&evp=5fbb1c6e47482358c61a5236fb38a112
VIA LAN Driver. If you don
Jun 22, 2011 | EPoX EP-9NDA3I Motherboard
Computer will not connect to internet through router
check the connections between the router and the modem either cable or dsl or whichever
and change the setting in the router interface so you know what the ssid is being broadcasted and the network key
Jul 18, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Router not speaking to modem
you need to change dhcp from the modem to the router to be a different network than what your router hands out via dhcp. you will also need to set dns up in the router to forward to the upstream modem.
Jun 03, 2009 | Dell TrueMobile 2300 Wireless Broadband...
Internet no longer working, but internal network is fine.
i agree with all the above.. it's definately clear as mud how the network is designed and or funtioning. The machines connected to the wireless d-link router.. are they via cat5 inthe wired ports or wireless ? is the server the machine thats connecting to the switch and wiress router and modem? i'd say reset all switches modems routers and machines.. shut them all down.. then fire the cable modem, then the wireless router then the desktop switch then the server, the workstations and the one lonely wireless.. run "ipconfig /all" on all machines and if they aren't all sharing common ips and access, provide the results here for further investigation.
May 20, 2009 | Dell Dimension 2400 PC Desktop
Everything appears to be working, but not internet connection
Turn off the firewall in both the router and the modem. try again-- once it is working ...just turn one of them back on..
May 16, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Belkin Router not allowing an Internet connection
It's not unheard of for a router to fail. When you connected the computer to the Modem, did you use the same cable that was connected to the router? Does your internet connection require a username and password? If so, is that configured in your modem, or the router? If not in the modem it must be the router.
Jan 05, 2009 | Belkin (F5D7230-4) Router (587009)
Wireless router does not connect to the internet
While you have the router connected to your modem, try unplugging the modem and plugging it back in. This will force the modem to redetect network connections.
Apr 15, 2008 | D-Link Air DWL-122 802.11b Wireless...
EPoX EP-9NDA3I Motherboard Logo
59 people viewed this question
Top EPoX Computers & Internet Experts
David
David
Steven Wander
Steven Wander
Are you an EPoX Computer and Internet Expert? Answer questions, earn points and help others
