Question about Hoover U6630-900 WindTunnel Bagless Upright Vacuum
How to install a U8172-900 belt - Hoover U6630-900 WindTunnel Bagless Upright Vacuum
  • 294 Answers
Your savvy bagless has a geared belt. remove the bottom plate and then remove the 2 back screws near the back wheels to remove the top cover also peel off the hoover decal to access the top cover screw. this will expose all components to replace the belt.
Posted on Oct 11, 2009
Kirby heritage 2 How to put the belt on. I'm having a problem getting the belt on the rod
The belt goes around the brushroll before you install the brushroll in the nozzle compartment, you must then twist the belt lifter casting which will rotate the belt lifter hook to lift the belt into the proper location to allow you to install the nozzle compartment on the vacuum. Then rotate the belt lifter casting to release the belt onto the motor shaft.
Sep 14, 2017 | Kirby Vacuums
How to install belt on Riccar 8750 commerical vacume cleaner?
No. There is only one belt. Remove the bottom plate to gain access to the belt.
Jan 18, 2014 | Riccar 8650/8625 s Vacuum
Dirt Devil featherlite cyclonic belt comes off
What makes the belt come off?
1) Wrong belt. use only genuine DD belt. No generics.
2) Worn out belt. Sometimes a worn belt acts this way. Just because it looks good, does not mean it is good.
3) Belt improperly installed.
4) Brush roll not spinning freely. (replace Brush Roll
5) Brush roll is not installed properly.
6) Machine is worn out where it pivots between the body and the lower nozzle. To check (without a belt installed) see if there is a lot of play forward and backward between the nozzle and the main body. If so, once a new belt is installed and you are pushing and pulling on the handle the motor shaft comes out of alignment.
NOTE: the #6 problem is the rarest and usually is due to an extreme amount of use over years.
Let me know if this helps.
Dec 31, 2012 | Dirt Devil Featherlite Bagless Vacuum...
Why do the belts keep breaking
Well the problem happens due to the belt If the belt not installed correctly, the rubber belt will grate against one of the components in the roller brush housing. The friction of the belt against the housing produces a pungent burning odor. To correct this you need a right belt, each vacuum cleaner manufacturer produces specific belts for specific machines. An incompatible belt installed on the vacuum cleaner will cause the belt to break or burn.
Good Luck!!
Thanks for using FixYa!!
Mar 26, 2011 | Bissell 3576 CleanView II Bagless Upright...
Hoover very noisy after new belt installed.
what is the belt # you have installed (generic)? Yes, there are problems with using generic belts on Hoover Vacuums. If you have noise I would suspect the roller, and replace it. the cost is about $25 and is something that you can install. The newer type are mande of wood and are very quiet.
Nov 23, 2008 | Hoover U5753-900 WindTunnel Bagless...
I have a Hoover Vacuum Cleaner, Runabout Supreme, on which the belt has broken. I purchased a new belt, part number 38528-040. I need some instructions on how to install the replacement belt? Thank...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=728341
Generic problem for all Vacuums
Posted by Jimbob48 on Jul 01, 2008
I need some instructions on how to install the replacement belt? Thank you. JBS
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Usually there are screws, clips or levers on the bottom of the vacuum and you need to either remove the bottom plate and once you have taken the screws, etc. out the top cover will come off. And then you can proceed with the removal and the install of the new belt. 1st you need to remove @ least one end of the Hoover brushroll and take of the old belt and slide on a new belt. Once the belt is on the pulley side of the brushroll; then re-install the brushroll. Make sure that the brush is spinning freely B4 you install the new belt, then take a belt puller or a screwdriver with a left or right hand hook to use as a belt puller and then stretch the belt onto the motor pulley, then take and roll the belt until it is tracking straight and then re-install the top cover and or the bottom plate, tighten down the screws, levers or clips. So, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 01, 2008 | Hoover Elite U5061-900 Bagged Upright...
Install self propelled belt
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=647063
Posted by wmtp on Jun 04, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Usually the self propelled vacuum have 2 belts and you should replace them both 2 the same time 1st the self propelled belt and then the brushroll belt. Normally you would hook the belt on the pulley side of the brushroll or self propelled unit and then stretch the belt onto the motor pulley side of the motor using a belt puller or a screwdriver with a bend on the end for pulling and or stretching either belt onto the motor pulley. If you have a problem please feel free to contact your local vacuum cleaner dealer.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Go Ahead. Use Us.
Jun 04, 2008 | Vacuums
I want to install a belt on the turbo power 2000 upright vacum cleaner , What do I have to do to install it. The old belt broke.
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=564997
I want to install a
Posted by mcpo on May 02, 2008
I want to install a belt on the turbo power 2000 upright vacuum cleaner , What do I have to do to install it. The old belt broke.
There are only 2 ways you can install a belt on a Turbo Power 2000, either you can remove the bottom plate and expose the belt, 1st place the belt on the brushroll section of the vacuum then use a belt puller or a screwdriver with a left or right hook @ the end and pull the belt onto the motor pulley, once you get the flat belt onto the motor pulley than you do what is called tracking to straighten belt out so it runs straight, replace the bottom plate. 2nd then remove the top cover by 2 to 4 screws or levers and then remove the top, then follow the procedure listed above. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Don – The Vac Man
Go Ahead. Use Us.
May 02, 2008 | Vacuums
How to install kirby vaccum belts
Take the noozle off of the vac. take out the brush roll and old belt, put the belt over the brush roll and re-instal in the noozle. Turn the big square knob on the front os far as you can, it will lock in that position, then put it back on the vac and lock it down, then turn the knob the other way to release the belt unto the belt pulley.
Feb 20, 2008 | Kirby Generation 3 Bagged Upright Vacuum
Hoover U6630-900 WindTunnel Bagless Upright Vacuum Logo
168 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
