Question about Sanyo PLC-XP46 Multimedia Projector
Need instructions on how to change fan speed on an PLCXP46
  • 2,237 Answers
You cannot. if it overheats, clean it out with canned air. dust keeps in the heat. and clean off your filters.
Posted on Nov 09, 2009
3 speed fan barely changes speed
You are talking about your blower fan for the air conditioner and heater right? More information will be needed to solve the problem.
When you say it barely changes speeds, does that mean it doesnt speed up, or doesnt slow down? By that I mean, is it "stuck" on low, or high?
Most blower fans run at different speeds through the use of a multi-stage resistor built into the fan switch circuit. Low speed is a high value resistor, medium speed is a low value one, and high speed is the fan running without any resistance.
If your fan is running on high and doesnt seem to want to run on lower speeds, the resistor pack may be failing. If the fan is running on low speed only, it may be that the fan itself is beginning to fail, or that the lubricant in it has gotten gummy.
Dec 07, 2015 | Cars & Trucks
IMac (mid 2007) fan speed running super fast after replacement of Hard Drive
The clue is in your first few lines. Put the sensor back where it came from.
Jun 09, 2012 | Apple 20" iMac Desktop
Need to know where the fuse is for the fan by the radiator. I know where the fuse box is at because mercury sable has 2 boxes. Which one contains the fan fuse. My fan is not working and been replaced and...
You have a relay there are 2 speeds low speed and high speed this is controled by a cooling fan module if you changed fan and it does not work then you will need to check the fan module, first the relay its in the engine fuse junction box High speed is marked on the relay C1056 and low marked C1058, here is what you can do go to the high spped relay open thhe cover and expose the relay with key on collapse the relay does the fan come on? if it doesnt replace the fan module if it does you will still have to replace the fan module here is the location is at the radiator on the front (may be under shroud)
Jun 08, 2011 | 2003 Mercury Sable
Ceiling fan stuck on high
The Inteli-Touch system does have a slight learning curve.
How the system works is. You turn the power switch on, and leave it on, all the time. To set fan speed, you press and HOLD the fan button and it will go. . beeeep. beeeeeeeeep. beeeeeeeeeeeeeep. beeeeeeeeeeeeeeeeeeeeep beeeeeeeeeeeeeeeeeeeeeeeeeeeeep beeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeep (higher pitched) when you reach your desired speed you let go of the fan button and it stays on that speed. So if you want to go to speed 4 you wait for the fourth beep and let the button go. To turn off the fan, press and release the fan button, to turn it back on to speed 4, press and release again. It has a memory. If you want to go to a higher speed while on speed 4 (or any other speed) just press and hold. To slow down the fan, you must turn the fan off by pressing and releasing the fan button, then pressing and holding until you get to the speed your desire.
The instructions which came with the fan should explain the rest. After you get used to using the IT control system, you will love it. I do. I have two Casablanca IT Victorian II fans in my living room. They are featured in this video. http://www.youtube.com/watch?v=2pv55wZqohs
May 20, 2010 | Casablanca Fan 6672G Panama® Ceiling Fan
Why is my Whirpool Window AC fan speed not changing? I have replaced the switch already!
possible that the fan motor speeds have gone out.. On the cooling cycle the fan speed is set for higher speeds and heat cycle slower speeds. it is possible that the fan motor in that speed you are needing is burned out
Jul 11, 2009 | Whirlpool ACQ108XL Air Conditioner
Fan Speed Too Slow
You need to pull the fan chain until it is set to the fast setting, then you use the remote to set the fan at the speed you desire.
May 26, 2009 | Dryers
Antec fans connected to akasa fan controller, Speed doesn't change
Sounds like a problem with your fan controller. The controller is simply controlling the voltage applied to the fan to adjust the speed. Have you tried a fan without a speed control built in?
May 09, 2009 | Akasa Fan Speed Control Fan Controllers
Uncontrolled CPU Cooling Fan Speed
Here is the link for all the various support manuals, software and instructions for your PC if you need them; http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=179911&taskId=101&prodTypeId=12454&prodSeriesId=316713 CPU fans should be plugged into the CPU fan power socket on the motherboard, in order to receive variable speed control instructions. If the fan has been incorrectly connected to a different motherboard fan socket, or directly to the power supply then it will run at a constant speed. If it is correctly plugged in to the correct socket, then the hardware management software (there are many possible options here - please post back with which management software you are using and I can give more specific instructions) that comes with the PC should allow you to change the settings - you can change the temperature range at which the cpu fan will go into higher speed mode - it sounds like you may have this set too high You should also be able to control the fans from the BIOS set-up menu - this should be accessible when you boot up. usually it will be by pressing F8, but all systems are set up slightly differently. watch the screen as you boot up and it should give instructions for this. Hope this helps, please give more details of how your machine is set up if you need more specific help :)
Sep 07, 2007 | HP Compaq d530 SFF PC Desktop
96 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
