Question about Microsoft Word 97 Full Version for PC
Can't print Word 97 documents. Status says
Can't print Word 97 documents. Status says ''spooling'' but never prints. What should I do?
    Novelist:
    Scholar:
  • 187 Answers
First check the printer is actually ON - (lights etc) Then see if the printer works from other applications (Excel etc) If not, unplug the printer and plug it back in again. Check your ink tanks (though you should get a message if that is the problem).
If you can print from a different app, it is not the printer that is the problem. Check the printer settings within Word. Still nothing? Go to the control panel, select printers and check that the correct printer is selected. If so, you may have corrupted the driver - get onto driver.com (or any other) put in the model details, download./install the new driver.
Posted on Jan 28, 2015
SOURCE: document printing hangs at 99%
same problem. everytime i restarted my pc and deleted the printed files from control panel/printers/lexmark x5150.
Posted on Jan 07, 2008
iqbal_del
  • 655 Answers
SOURCE: Problems deleting printed files from the spool
Navigate
Start-> Control Panel -> Printer
Right click on printer icon and select properties
Find out Advance settings. See Spooling, Select Print Directly and try.
Although your driver looks like incompatible but above will fix your problem.
Thanks
Iqbal
Posted on Apr 09, 2008
SOURCE: Color chart in Word 2007 prints as a black box
One of our staff members had a chart that they have embedded in a Word 03 document. The text on the Y axis is in reverse order, but when the chart is double-clicked, the text it is correct. When printed to Acrobat, the chart is black.
I saved as Office 2007, with no better success, but the text (compatibility mode) did not disappear from the heading of the document even though I saved as a docx.
I saved once more, this time making sure the Maintain Compatibility checkbox under the file type was not checked. The chart corrected itself on-screen and it printed correctly.
Posted on Aug 11, 2008
Riztech
  • 731 Answers
SOURCE: Can't print because of Error-offline status.
Hi
To fix the problem permanently try the below solution, you will not experience this anymore.
1.Right click on MY computer ->Properties->Hardware->Device manager.
2.You will get Device manager window popping out.
3.Scroll down to "Universal Serial BUS controllers".Click on the (+) sign.
4.Check for the "USB Composite Device" and right click on it, click Uninstall.(IMPORTANT NOTE:wE HAVE TO UNINSTALL THE PRINTER'S USB COMPOSITE DEVICE, TO KNOW WHETHER IS THE PRINTER'S USB COMPOSITE DEVICE, RIGHT CLICK ON USB COMPOSITE DEVICE AND PROPERTIES,look for what location says, Eg -LOCATION : HP photosmart C6100
5.Disconnect the USB and reboot the PC.
6.Connect the USB after reboot, you will get popup "Found new hardware".Then the Drivers will be installed Automatically.
Thanks
Riz
Posted on Jan 11, 2009
  • 684 Answers
SOURCE: Printer continues to say ''Collecting printer status''
Uninstall the Printer Drivers and reinstall it this should work.......And for this problem this is the only resolution...........
Good Luck....
Posted on Jan 22, 2009
My printer will not print. When you check the status of the document it says printing. When you cancel that it doesn't cancel. DAYS later the document prints all by itself. What's that about?
It's because the print queue is saved on the printer's flash memory. This happens when you don't cancel the queues properly or terminated improperly. To get rid of the issue, always try to give the command slowly and don't over load. If you are printing photos, try to make the file size small so that it'll not take long to spool and prepare for printing.
When the problem occurs, so as follows:
Cancel the queues from the print status box ("Cancel all documents"), if they are not cancelled, then turn off the printer (directly unplug the power cord from the printer), it you still see the printing status, keep on cancelling until everything's gone.
If the problem persists, restart your computer. Definitely the problem will be fixed.
It's also important to press the cancel button while the printer powers On.
Good luck.
Thanks for using FixYa.
Aug 11, 2010 | HP Officejet 5510 All-In-One Thermal...
Requested to print a Word Document it says it going to print 377 pages (only 1 page should print) I delete it status says deleting for two days now. How do I get rid of this document?
Try this next:
1. On the taskbar, click Start, and then click Run.
2. Enter the following:
net stop spooler (and hit enter)
3. Delete all files in the following folder:
C:\Windows\System32\Spool\Printers
4. Once the spool files are deleted, start the spooler again:
net start spooler
Re-boot
Dec 09, 2009 | HP OfficeJet 4215 All-In-One InkJet...
I can't "delete" a document from the que
Have you tried to stop the spooler service in services?
Option 1)
Click on start orb
Type in search window:
services.msc
click ok
Scroll down to Print spooler service and click on it in the right side
window.
On the left side click stop the service and wait forthe process to
stop
Do not close the window yet. You will have to restart it here later.
next delete the print job in the printer queue
then restart the spooler service
Resubmit your new print job.
Option 2)
If that doesn't clear it, the next step would be to stop the spooler
service as stated above
Go into windows explorer
(Print job data is collected and stored in a spool file in the spooler
folder.)
It is located in:
C:\WINDOWS\system32\spool\PRINTERS
Your print job will show 2 files there Example below:
00002.SHD
00002.SPL
Delete the files located in there. There may be several of them
depending apon how many print jobs you submitted. You will have to
resubmit your print jobs all over again.
Next go back to services window and restart the spooler service
That will definitely fix it.
Apr 10, 2009 | Lexmark International Z611 Printer
Print queue will not clear after printing
dear sir
this is a typical usb inkjet printer problem
just follow the steps
open notepad
and copy paste
net stop spooler
del %systemroot%\system32\spool\printers\*.shd
del %systemroot%\system32\spool\printers\*.spl
net start spooler
and save as delete.bat file on desktop
run this file and reboot the machine
and run this file again
now print queue will get cleared
thanks
Apr 10, 2009 | Dell 966 All-In-One InkJet Printer
When printing documents from my PC documents always sent to queue
Go to control panel, printers. Set your defaults there. You probably have spooling enabled. Uncheck it and your print job will go to the printer, rather than to spooling. Spooling is like rolling the print job up on a spool until the whole thing is processed, then unwinding it to the printer.
Feb 17, 2009 | Lexmark X3550 All-In-One Printer
Deleting Files from spool after they have printed
see your Spool settings, Set Print directly option and try.
Apr 09, 2008 | Lexmark X6100 Flatbed Scanner
Navigate
Thanks
Iqbal
Printing takes a very long time
In this case you can bypass the spooler by the following steps:
1. Right click the printer icon & left click the printer properties
2. Click the Advenced tab in the printer properties.
3. Select the option PRINT DIRECTLY TO THE PRINTER & UNCHECK THE OPTION SPOOL THE DOCUMENT.
4. Click apply and ok.
5. Try printing.
Feb 08, 2008 | Office Equipment & Supplies
Hp psc 1200 series all-in-one
Right click my computer.
Click manage.
Computer management should open.
Click services.
On the right window there should be a list of services.
Find the print spooler in the list.
Check the status.
It should be default be started.
If not, then right click print services and select start.
Feb 06, 2008 | HP PSC 1210 All-In-One InkJet Printer
Microsoft Word 97 Full Version for PC Logo
69 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
