Question about Cameras
I asked about a problem with my screen being blank. The camera is a Sony Cybershot DSC-S650
  • buddhiman651 May 11, 2010
    Here is your Solutions
    » Canon » Fuji » Kodak » Nikon » Olympus » Panasonic » Samsung » Sony
    buddhinma9
SOURCE: Sony Cybershot DSC S650 Memory stick not formatting
Well I have the same camera.
And mine won't turn on.
Suggestion dont trust this camera.
Or maybe it just can't hold that much memory.
Posted on Mar 21, 2008
  • 8 Answers
SOURCE: sony cybershot dsc-s650 camera
Just take the back cover off, unplug the cable that runs to the switches from the main board and plug it back in. I had the same problem and it now works great!
Posted on Aug 26, 2008
  • 6 Answers
SOURCE: i have cam sony dsc-s650 " dark screen "
camera needs to be reset...but not gonna be easy
take batteries out...hold down power switch for 15 seconds...then put batteries in and restart
if camera works...go straight to menu and reintialize all functions
this is a firmware/software problem that is not easily fixed...and Sony wants $91 to fix a $100 camera
keep repeating this until it works...may take numerous attempts...but this is how I got my camera running again
Posted on Sep 19, 2008
BillB-SA
  • 2761 Answers
SOURCE: TURN CAMERA ON SCREEN FLASHES cYBER-sHOT AND GOES
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your camera may have a problem that requires professional repair.
Posted on Oct 13, 2009
  • 11967 Answers
SOURCE: SONY Cybershot (Model DSC-S650) Turns Off
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Dec 08, 2009
I need cables for a sony cyber shot dsc-s650
Hi.here is the link that you can buy it directly from eBay...
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Brand New For Sony CyberShot DSC-S650 Camera Compatible USB Cable Features:
  • Brand New Sony Compatible USB Data Cable
  • The USB port transfers data between your digital camera to your PC or laptop. This USB cable is a must needed accessory along with your digital camera.
  • Compatibility: PC & Mac USB 1.0, 1.1,& 2.0 devices
  • Support Data transferring up to 480Mbps
  • Color: Black
  • Length: 5ft
  • Weight: 2 oz
Package Included:
  • 1 x Brand New USB Data Cable For Sony Digital Camera/DSLR
http://cgi.ebay.com/Sony-CyberShot-DSC-S650-Camera-Compatible-USB-Cable-/270724518269?pt=Camera_Cables_Cords&hash=item3f0870517d
Jul 18, 2011 | Sony Cameras
Bonjour, je voudrai savoir si quelqu'un pourrai me donner un lien pour que je puisse trouver le logiciel d'installation de mon appareil sony cyber-shot DSC-S650 Merci d'avance pour vos reponses.
http://support.sony-europe.com/dime/digistill/cyber/cyber.aspx?site=fr&m=DSC-S650&site=odw_fr_FR&odw_model=DSC-S650
voir ici pour software and manual
Mar 02, 2010 | Sony Cybershot S650 Digital Camera
My camera is beeping
try changing the camera software from sony site there might be an update for this model otherwise check ur lithium cell inside the camera sometimes it is accessible sometimes not depending on model
Jan 05, 2009 | Sony Cyber-shot DSC-S650 Digital Camera
Can cyber-shot dsc-s650 b used as a webcam?
yes put a paper clip in the bottom port and plug it in to the wall
Sep 30, 2008 | Sony Cybershot S650 Digital Camera
Sony Cyber Shot Model DSCS650
i have a sony cyber-shot model DSC-S650 camera driver software
Sep 13, 2008 | Sony Cybershot S650 Digital Camera
Sony cybershot dsc-s650 camera
Aug 23, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
TIME DATE STAMP
push the wtz key its number 1
Aug 19, 2008 | Sony Cybershot S650 Digital Camera
Driver for cybershot dsc-s650
http://esupport.sony.com/US/perl/swu-list.pl?mdl=DSCS650&region_id=1
here is the drivers page of Sony if you have XP or Vista the drivers are already there and none have to be downloaded. Hope this helps?
Apr 15, 2008 | Sony Cybershot S650 Digital Camera
Sony cybershot DSC S650
send the camera back, you should have 12 months warranty on the item either ask for a repair, replacement or full refund
Mar 25, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
Mar 15, 2008 | Sony Cybershot S650 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
