Question about Echo Garden
Echo cs3450, how to replace purge pump - Echo Garden
  • elliott1295 May 11, 2010
    how to replace purge pump on echo 3000 chainsaw
    President:
  • 2,220 Answers
The IPL (exploded parts list) for your saw can be found here:
EchoUSA
http://www.echo-usa.com/pdf/documentation/CS3000T1T1E_081303.pdf
Page 8 is the fuel system detail. Compared to most manufacturers’ this is a novel, a good one. Use it as a guide, it doesn't look to difficult. Take extensive notes and digital photo or two may pay huge dividends. HTH
Lou
Posted on Sep 28, 2009
Purge bulb not working on echo pb-500t,gas leaf blower
get a new primer bulb and diaghram and rebuild your carb or buy a new carb,same price,gas and ethanol and oil kill carbs, echo A021000781
Echo PB 230LN 05001001 05020818 Handheld Parts
May 26, 2015 | Echo Garden
Hello there,my 2001 echo is lighting up trouble codes p0440 p0441 p0446; how and where should i start?
code p0440 refers to evaporative emission (EVAP) system--malfunction=== causes --hose connections --intake leak--EVAP canister purge valve
code po441 refers to EVAP --incorrect flow detected==causes the same as for po440
code po446 refers to EVAP system vent control --circuit malfunction===causes --wiring---EVAP can purge valve--ECM
generally I would replace the purge valve as it is common to all codes
Feb 03, 2014 | Cars & Trucks
Code p0440 code p0441 code p0446on toy echo 2000 what is the diagnosis?
P0440 Evaporative Emission Control System Malfunction P0441 Evaporative Emission Control System Incorrect Purge Flow P0446 Evaporative Emission Control System Vent Control Circuit Malfunction
  • Remove and reinstall the gas cap, clear the code, and drive for a day and see if the codes come back.
  • Inspect the EVAP system for cuts/holes in tubes/hoses
  • Inspect for damaged or disconnected hoses around the Evap purge solenoid
  • Check and/or replace the sensor
  • Check and/or replace the purge valve
  • Have a professional use a smoke machine to detect leaks
Aug 19, 2011 | 2004 Toyota ECHO
While filling up our 2000 Toyota Echo at the gas station the pump at the gas island keeps shutting off. Takes forever to fill the tank.
this is becoming a common problem, what is going on with your car is that as you fill the fuel tank you have to displace the air inside the tank( as the fuel goes in the air has to come out ) this is done by the purge system, as the fuel goes in the air is displaced threw a purge canaster the canster trapes any fuel vapers that are in the displaced air and as you are driving the car the vapors are burned by the engine, this canister is either pluged or the valve that opens and closes the canister is stuck so as you fill the tank the air can not get out so you get back pressure in the fill neck and this causes the pump to shut off, bottom line you need to have the purge system checked. it might be a bad canister or a bad switch could also be one of the hoses to the canaster, heres the bad news to replace almost anything on the system the fuel tank will have to be removed and that can be expenceve....sorry
Aug 04, 2011 | 2000 Toyota ECHO
What is the spark plug gap setting for small ECHO CS3450 chain saw with new autolite plug?
0.020" should work well. Check the quality of the spark--it should be blue and snappy with the new plug. Hope this helps!
Dec 10, 2010 | Echo Garden
How do I replace the purge pump on thr Echo chain saw model CS 3000
take side cover off and remove screws that hold the pump bulb in place and remove the gas lines make sure you put the right one back on each side.the one that sucks goes to carb. and other goes to gas tank.
Jun 12, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
What is the carburetor metering lever adjustment for an echo chainsaw model #cs3450. the fuel diaphragm sits on this metering lever and valve inlet needle.I need to know what to adjust the lever to so the...
Clarification Request
Posted by slohry on Apr 10, 2009
What kind of carburetor does it have? Zama, Walbro? And what model carb?
No response to clarification request... delete this question.
Mar 06, 2009 | Garden
Purge pump removal
By studying an exploded parts diagram found online, I determined that it snapped out the top before the bracket slid out the front.
Jan 29, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Starting problem
purge valve for gastank and emmission system
Jul 26, 2008 | 2002 Toyota ECHO
Open Questions:
Garden Logo
893 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
Jim London
Jim London
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
