Question about Philips 27PT643R 27" TV
I have the Philips 27PT643R 24". Have had the tv since 2005. Two days ago I have been getting this problem: the tv will be fine, then the screen goes gray with white lines running across, then the tv will shut off.
3 Suggested Answers
  • 117 Answers
SOURCE: No picture on my Philips Magnavox HD2528
your tv has a vert problem
Posted on Jun 24, 2010
gopakumarg43
  • 75581 Answers
SOURCE: philips magnavox smart series tv has wavy white lines all across a gray screen, then turns itself off. Was working fine 2 hours ago.
The ABL [Automatic Bright Level] circuit has the fault. Try adjusting the secreen voltage to a little bit low.
Posted on Apr 30, 2012
Philips 42PFL5405h/12 - Black screen and no audio on turning on.
It sounds that the settings have been corrupted. It will be best to contact the authorized service center to make this set right. Beware, not to make any experiments hereafter. It's 'PHILIPS'
Jun 24, 2013 | Philips Televison & Video
Philips tv jarred in drop
Tv's don't take rough treatment well,picture tubes and other displays break,circuit boards are easily cracked usually around heavy parts,that sounds like your type problem broken board,if the damage is not severe it may be possable a tech.can repair the broken copper traces but this is becoming more difficult with newer more densely packed circuit boards with thinner and thinner traces many are not repairable and even if a new circuit board is available from the mfgr.it will cost more then a new tv.Good luck
Feb 26, 2012 | Philips 27PT643R 27" TV
My phillips lcd 46 The GREEN light blinks on it come on black screen the it goes off again and does some thing over and over just got this tv new three days ago model 46PFL5705D
This tv is having a power supply board issues,that the electronic board where the tv power a/c cord plug into it.This is a new tv.Return the tv where u bought it quickly and get a new tv replacement.
May 08, 2011 | Philips 42PFL5603D - 42 IN. LCD HDTV
Philips 27S300 C101 TV. How do I program the channels into the Philips TV. It's hooked up directly to cable. Right now I need to type in the channel I want to view. The channel up and down button skips...
use this user manual because you will continue to get some problems with your TV. print this use manual;
http://www.p4c.philips.com/files/2/27pt643r/27pt643r_dfu_aen.pdf
Sep 15, 2009 | Televison & Video
Philips 26pfl3512 LCD TV loud power supply discharge
The "certified servicers" should have been able to identify a power supply that is breaking down at random. At random failures only occur when the TV is in your home, never in the shop. :-}. Eventually the power supply will fail completely and will have to be replaced.
Apr 26, 2017 | Philips 27PT643R 27" TV
Philips 27PT643R37A switches on and inmediatelly off
i had same...power supply board shortage...find short or replace board...replaced board here
Jun 28, 2008 | Philips 27PT643R 27" TV
Red line in top corner of screen
Sounds like an IC on the LCD panel went out of TV. Only thing to do is replace panel (it won't go away only get worse) It will probable be cheaper to just get another tv.
Apr 21, 2008 | Philips 42HF7444T 42 in. Plasma TV
Philips 27PT643R 27" TV Logo
178 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
