Question about Garden
I have a Troy-Bilt riding mower. The belt that makes the mower move in forward and reverse is very loose, like it would need to go around another pully. I can't see where it has one for it to go around. It does not move in forward or reverse when the clutch is let out. Do you think I lost a pully somewhere or does the engine move to adjust the belt?
Test cant find registering
Posted on May 18, 2014
  • 437 Answers
You may have lost an idler pulley or it has come off its normal route. The belt may be stretched out and need to be replaced.
You can go to www.precisionope.com and find an Ilustrated parts look up to see how it is on there. This model may be found under Troybilt or MTD.
Posted on Sep 28, 2009
Install new drive belts and mower still wont move forward or reverse.
Belts dont move mower back and forth, there is a bar that engage the hidrolic transfer, perhaps you move it and you have not tracking power, or, there are a series of rods that actuate the hidrolic, coud be that any of those rods came undone, if any of these to scenarios is happening to you, consider have the hidrolics chec out.
Good luck to you.
Jun 27, 2015 | Troy Bilt 175HP Manual 42" Riding Mower
Replaced drivebelt on troybilt riding mower now the forward pedal moves mower in reverse?
Sounds like you have the belt running in the opposite direction. You need to Change the way the belt is routed around the pulleys
Jun 18, 2014 | Troy Bilt 175HP Manual 42" Riding Mower
Need to put a new belt on the rear of the Troy-Bilt LTX 1842
First buy proper belt... Next note how old belt is warped around the pulleys, take a picture or draw a diagram... Remove all covers off deck pulleys, and guards to expose belt completely... Pull and stretch belt off one of the idler pulleys, once one is off the rest will slide off... Reverse procedure for installation... Note: grease all nipple fittings, bearing and shafts to avoid seizing of bearings or bushings.
Nov 17, 2013 | Troy Bilt 25HP VTwin Hydrostatic 50" Zero...
Mower slips in and out of forward gear but rides perfect in reverse;What do I need to adjust?
Reverse is a different gear set than forward gears. Sounds like forward gear set has a broken tooth. Not an easy fix.
Jul 18, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Troy-Bilt Horse XP, Model 13bx79kt011 - Won't Move
You need to check the belt to the hydro units is connected properly and is tentioned and not slipping in the pilleys
May 31, 2013 | Garden
Troy-bilt riding mower won't move in forward or reverse
I had a similar problem with my TroyBilt 50 inch zero turn mower. Was cutting grass when it stopped going either forward or backward even though it would start and the PTO would move the cutting blades. Turned out the tensioner spring for the belt that drives the motors near the rear wheels had gone missing. Searched the yard where I had cut and moved the machine but couldn't find it. A new one cost me about $7.50. Put the new one on and it worked fine.
Apr 19, 2013 | Troy Bilt 175HP Manual 42" Riding Mower
Troy bilt pony riding mower will go in reverse but grinds in forward where do i start
have a troy-bilt riding mower. place a gear in neutral and park it.
it dies instead idling. want to know why?
Jul 17, 2009 | Garden
Troy Bilt ride-on mower will not move in either fwd or reverse
Is the parking brake on? Or if it's a hydrostatic (automatic) there is a release lever to push the unit around when it isn't running. Most of those releases are on the back of the machine, and you just push it in for drive and pull it out to push.
Was this helpful?
yes
no
Mar 21, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
275 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
