Question about Craftsman Garden
Lawnmower starts but cuts off every time i start it
  • 437 Answers
It is not getting fuel or air. Depending which engine it has on it, the carburetor jet may be clogged or a carburetor diaphragm needs to be replaced.
Check spark plug; Air filter; fresh fuel; and of course make sure the engine has oil in it.
Posted on Sep 28, 2009
Why lawnmower cut off after it start
Make sure the fuel filler cap breather hole is clear if its blocked it will create a vacuum in the tank which prevents the fuel flowing forward. also check out the kinks below
Lawn Mower Troubleshooting Guide Engine
Small Engine Repair Help
May 01, 2014 | Toro Lawn Boy Self Propelled CARB Walk...
My electric lawnmower sometimes does not start, just humms. Then I TURN IT OVER, AND TURN THE BLADE A LITTLE BIT. the blade feels hard at first but soon feels loose. then it wil start as normal
The lawnmowers electric motor has a bad spot on the armature. You need to replace the electrical brushes that contact the motor. If you are lucky you may just need to clean them and reinsert them in to brush holders.
Nov 25, 2013 | Electric Lawn Mower
Starting problem with admiral 16SE Petrol lawnmower
lack of fuel
possible water in the unit or blocked main jet
have the carby overhauled
Feb 08, 2018 | Admiral Garden
Lawnmower keeps cutting out
drain out the fuel and try fresh fuel gas is only good for 30 days in small engines
Mar 27, 2012 | Garden
I have a honda o h c push lawnmower it starts easy but cuts out in about 30 secs
I have the GVC160 motor....same problems....just found this info (see link),...and it turned out that Honda used a NGK spark plug that was defective,....I couldn't believe that is all it was...after changing the carb (new),...adjusting valves....etc.. I just went down and bought a new spark plug.....and it runs great!!
BEFORE go thru all of the advice and look at most other Honda web info.....go and buy a brand new spark plug and start with that! It appears Honda used a NGK spark plug in the past that fails after some time....giving the syptoms of problems with the carb, sticky valve, etc. Do not try to clean and use the old spark plug!! Check this out....it was the answer I was looking for after hours of work, reading, and talking to Honda dealers - http://forum.doityourself.com/outdoor-power-equipment-small-engines/261743-honda-lawnmower-starting-then-cutting-out.html
Sep 05, 2010 | Husqvarna 160 CC Honda OHC Engine 21 in
Sluggish when started, light smoke
check carb an get a can o sea foam
Jul 28, 2009 | Garden
Lawnmower cuts out on fast idle + runs rough
REBUIld carb it is dirty jet is clogged
May 25, 2009 | Echo Garden
JCB LS45 lawnmower - 2 stroke or unleaded petrol??
JCB LS45 specs Manufacturer: JCB
Blade Length in cm: 42 cm
Blade Width in cm: 40 - 44 cm
Cutting Width in cm: 42 cm
Electric Start: with Electric Start
Grass Collection Bin: Back
Horse Power: 3.5 hp
Mowing System: Rotary
Power Supply: Petrol 2 Stroke
Type: Walk behind mower
Apr 04, 2009 | Garden
Garden Logo
205 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
