The cold water often will not shut off even when power is turned off on my Fisher & Paykel GWL08 washer. It must be turned off manually. Is the problem the input valve, and where do I get a new one?
  • 4,059 Answers
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Post your model number(http://www.appliancepartspros.com/modelnumber_loca tor.aspx ) HERE and search for water inlet valve > http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=GWL08
Or you can go to an appliance parts store.
Posted on Sep 28, 2009
Why does it leak, even when machine is not running?
Small leak/drip with Fisher & Paykel GWL11 Washer (with ...
ths.gardenweb.com > Home Forums > Laundry Room
May 6, 2008 - Got a small drip/leak with my GWL11 washer..... The washer is ...Small leak/drip with Fisher & Paykel GWL11 Washer (with pictures) ..... New project for a new year: Light a fire under plans for an outdoor oven and claim the best pizza in town ... Speed Queen Front Load AFN50 Washer Review - Long Post.
Fisher and Paykel GWL11 Top Loading Washer
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... I have a Fisher Paykel GWL11 that I purchased new and have loved until this problem started. ... The machine fills with a small amount of water to saturate the clothes ...... Fault 36 is related to water leaking, but is *not* the kind of leaking from ...
Fisher and Paykel GWL11 Top Load Washer - faqqq
www.faqqq.com/.../fisher-paykel-gwl11-washer-leaking-and-squealing-fish...
Question Product: Fisher and Paykel GWL11 Top Load Washer Question Details:Fisher Paykel ... Small leak/drip with Fisher & Paykel GWL11 Washer (with .
Dec 12, 2015 | Fisher and Paykel GWL11 Top Load Washer
F & P, gw712. has error lights --11---1.
I have a code book for GWL08 & GWL10 and if the codes are the same for yours it looks like a problem with your cold water valve. The first thing the book says to do is check your wiring to make sure the valve is connected properly and if that does not take care of it to check the valves to see if the coil has an open circuit. If the valve is okay than they say the motor control module is bad and to replace it. Hope this helps you!
Oct 06, 2014 | Fisher and Paykel Washing Machines
Why won't fisher & paykel gwl11 fill cold water?
If the cold water only comes out at a trickle, you need to replace the valve. I have had to replace the hot and cold water valves on my washer every couple years.
Jul 06, 2014 | Fisher and Paykel GWL11 Top Load Washer
Fisher & paykel gw612 washer constantly trying to drain
The pump triacc in the motor control board needs to be replaced
by a technician, it's cheaper than getting a new board.
Apr 22, 2013 | Fisher and Paykel Fisher & Paykel Washer
Fisher & paykel IWL12 Fault code 12
Your water inlet valve is likely defective. The supply hoses behind the machine lead to the watervalve.
Jan 08, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
Cold water valve?
Replace the inlet valve. This is a common fault easily fixed with a new valve.
Apr 07, 2017 | Fisher and Paykel GWL11 Top Load Washer
Fisher&Paykel washer ran about 30 seconds during water fill and shut off. Now completly powered down. Power supply is o.k. Control panel none responsive.
u need a new cold water valve nd controller if it is over 7 years old dont fix it controller around $160 water valve around $35
Jan 21, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel GWL08 top load washer appears a crack in the inside water dispenser
With the lid open, you'll see two white plastic plugs on the top front lip of machine. Pry them up with fingernail to reveal screws to remove. Take care not to let top flop back as plastic tabs may break.
May 10, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
61 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
