Question about Sharp AR-235 Copier
How to rest h2 code on sharp ar-235 what is the simulation process now on sharps
  • Sharp Expert
  • 257 Answers
Make sure the thermistor is clean and ok then press, P, Interrupt, C, Interrupt. It asks for a code, Enter 14 press print then press Execute on touch screen.
Posted on Nov 30, 2009
    Guru:
  • 389 Answers
H2 00 Faults the termistor.
Requires checking the block of the fastening. For conditional gap of time heating element, the lamp of the heating does not leave in mode of the temperature. Apply to service mode. It Is Required avoid the specialist. The Possible faulty controller of the direct current. Need the measurements on finding signal controller. Good luck
Posted on Sep 29, 2009
I have problem in my sharp AR- M205 Copier When i Swith On Of the Printer Then H 2 eroor on the display
H2 Trouble code is a problem with one of your thermistor. I would start by removing the fuser and then check if your thermistors are damaged or need to be cleaned. After you clean or replace use Simulation 14 to cancel the error. Perform the following procedure to enter the simulation mode. "#" key Interrupt key "C" key Interrupt key
"14" Main code Start key
Jul 14, 2014 | Sharp AR-M205 Copier
To to clear f2,f6,u2 and u9 sharp Ar235 error code.
go to the simulation 14-0/16-0 and 24-7, the simulation is # interupt c interupt
Jun 13, 2011 | Sharp AR-235 Copier
I have a sharp ar-235 what does call service code U2-40 mean
CRUM chip communication trouble = the chip on the toner cartridge is faulty.
1, Try to clear the code press P, *, C, *, to enter the service simulation, on the key pad press 1,6, then the copy start, press execute on the screen.
2, Change the toner cartridge.
If it is a brand new one return to supplier as fault, if it is a refilled new one take back to supplier (the CRUM chip serves as a genuine supplies protection for sharp and 'blows' when the toner is empty the re-filler will have to put a new chip on it)
Nov 04, 2010 | Sharp AR-235 Copier
Is there a reset code for a Sharp AR-507 copier, error H2-00?
enter simulation: pound, interrupt, clear, interrupt, then enter 14, press start,press execute on touch screen, press ca until copier restarts, this is a general clear code, if problem returns you will have a heat problem in the fuser.
May 04, 2010 | Sharp AR-507 Copier
H2 problem sharp AR 5516
sharp ar5516 showing code f2 or h2
Jan 14, 2010 | Sharp AR-5320 Black and White Copier
Sharp AR-M450N+ Code: H2-01
Hello sir; You may do a reset simulation; press "p" "*" "clear" "*" enter 14 press start enter 0 press start , machine will go back to working condition.
Sep 12, 2009 | Sharp Office Equipment & Supplies
Sharp AR-5127 H2-00 code reset
Sharp Fuser
H2-0 Fusing unit temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKING ON MACHINE***
You have to reset fuser errors with simulation 14. Push P * C * then 14 then Start (the button you use to make copies) and it should reset the code. If not then replace the fuser.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective replace.
Feb 01, 2009 | Office Equipment & Supplies
SHARP AR163 Displaying H2 error code
Dec 11, 2008 | Sharp AR-163 All-In-One Laser Printer
Sharp AR-235 Copier Logo
330 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
