Question about Samsung CLX-3175FN Printer
How to remove covers and fuser unit?
Yes, I have a piece of paper stuck in my CLX-3157fn Samsung Multifunction Printer. Its rolled around the roller. I need to get access to the inside part. Can you help me? Thanks, Heather
    Problem Solver:
  • 4 Answers
Ive got the same problem :( and because i used compatible cartridges, it apparantly voides the warrantly, so staples will not fix it :( so im now stuck with a £260 uselss printer :( good luck getting it fixed.
Posted on Feb 18, 2010
How do I clear a "door open" message when no doors are open and I have checked the door sensors?
Reinstall software. You do not have to
uninstall the original software, re instalation will roll over it.
Brad
Nov 26, 2014 | Samsung CLX-3175FW Multifunction Laser...
Samsung printer clx-3185 paper jam under rollers
You should be able to turn the rollers manually and take the pieces out, just make sure to have the unit unplugged first
Tony
Jul 14, 2014 | Electronics - Others
How do I fix Samsung Clx-3185 Fuser
The micro "flag" located at the fuser has been broken or dislocated or some gears broken and fuser not spinning.
If you cannot get spares, buy a new printer
May 06, 2014 | Samsung Clx 3185 Multifunction Printer...
Replace fuser unit
Have konicaminolta service tech come and look at it.
Nov 21, 2013 | Konica Minolta PagePro 1300W Printer
I have a Samsung CLX6210FX. I get this error Paper Jam 2 Check Inside. I check the paper tray and the toner door but could not find where the paper jam is. Please help
This can be very difficult to find especially if they are small pieces. If you remove the toner cartridge and with a flashlight look all around for any evidence of paper. Also check thoroughly all the doors that will open and all around the rollers. Lastly and this is difficult is the fuser in the very back of the printer. These rollers are extremely hot and sometimes when the fuser goes bad, it will keep the paper in the fuser causing the jam. On the menu you will probably see error codes as well. Hope this helps.
Mar 19, 2011 | Samsung CLX-6210FX Laser Printer
Everytime intry to print it keeps coming up as paper jam or open/close door. which there is no paper jam and door is closeed
To fix this kind of error, remove the ink cartridge and turn the printer upside down and gently shake it.Check if anything comes out.If nothing goes, or you can't hear anything rattling around, get a piece of card stock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there. Open up the printer and clean the insides with a soft cloth and a brush. That should remove all the bits of paper inside.The teeth on the roller sides may have some dirt stuck on them which does not allow the rollers to roll freely and hence is as bad as paper jam. The idea is that the rollers do not roll whether because of paper or some dirt on the roller teeth. They have to be cleaned.
Thank you !!
Jul 19, 2010 | Samsung CLX2160 Multifunction Color Laser...
I cannot even see the "stuck" paper.
it will probably have wrapped itself around one of the fuser rollers. You may be able to see the fuser rollers from the rear of the printer and check to see. to remove the fuser is quite involved even after removing the 2 side covers, the top cover and the back cover. the fuser is the component that gets extremely hot, near the paper exit.
Sep 15, 2009 | HP LaserJet 1200n Printer
I have a small peice of paper stuck in the fuser unit of a samsung CLX 3160- How do I remove the fuser to get it out? I removed the 4 screws holding it in, but it is attached somewhere else, is there a...
open back cover,remove 4 screws of fuser,standing at the back of printer on your lhs on the fuser there is a lock,pull lock towards right and fuser should come out.
Jul 13, 2009 | Samsung CLX-3160 All-In-One Laser Printer
Nec 860 laser printer fuser unit
remove cartridge and leave top door open, then remove two screws in back ; open front sheet panel to find two screws to remove then remove outer case carefully AND PLACE ON LEFT SIDE BECAUSE THERE'S A RIBBON WIRE ATTACHED.
there are 4 screws holding the fuser unit in place, remove AND LIFT OUT BY ROLLING TOWARD YOU to reveal 2 screws to access the red roller assembly!
In my case there was a very tightly wound piece of paper stuck in there not visable without removing the screws on the fuser unit!
Dec 18, 2008 | NEC SuperScript 860 Laser Printer
How to clear internal paper jam on CLX-3160FN Samsung Multifunction Printer
Get rid of it. Your problems will only get worse. Mine is going to the landfill.
May 18, 2008 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX-3175FN Printer Logo
1,650 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
