Question about Sprint Hitachi P300 Cellular Phone
Got 3/4 through initial charge on new player and it appears to have stopped charging(been on for over 8 hours) Any ideas?
How long to charge I only recieved it today
The initial charge will take the longest. I would give it 4 to 8 hours to fully charge.
Mar 07, 2016 | Audio Players & Recorders
How long does it take to charge battery initially and should there always have a lighting bolt while charging
I would do 24 hours the first time. I have no idea what you have so I cannot answer the remaining questions.
Dec 10, 2014 | Audio Players & Recorders
How long do I initially charge the hanset for? What Do I need to download before I can use the phone? Thanks Helen
Most manufacturers recommend the initial charge to be 8 hours, this is not a necessity though. The older model handsets had nicad batteries and they had a charging memory, whereas the newer handsets have lithium polymer batteries that do not have the charging memories, nevertheless, it is a good idea to charge the device until it states CHARGE COMPLETE. The only prerequisite is that you activate the handset, then you can begin to use it.
Mar 03, 2011 | Cell Phones
How long do I charge my new 265wt initially with ac adapter
It should be fully charged after 4 hours with the ac charger. It also takes 4 hours with a car charger or 8 hours through a USB connection to a computer.
Feb 17, 2011 | Garmin GPS
I am charging the battery of a brand new purchase. Do I need to let the battery charge fully, ie; the 3.5 hours before I can use it? I keep getting a, "Key LOCKED, system shutting down message on the...
For the initial charging, YES, you need to follow what's on the manual. If it requires you to charge the player for 4 hours as the initial charging, you need to leave it connected to the wall outlet for 4 hours, so that the battery life will become longer.
Though the key is locked, it's still charging. As long as it's connected to the outlet.
Thank you.
Nov 03, 2010 | SanDisk Sansa e200 MP3 Player
Unit will not turn on
Your battery is recharged when connected to your computer. Turn the player off and connect it to your computer via the USB cord. The computer must be turned on. Initial charge should be for 10 hours with subsequent charges 3 to 4 hours for a full charge. A quick charge of 1-1/2 hours will give you a 70 percent charge. A fully charged battery will last up to 15 hours under normal use.
Dec 09, 2008 | GPX MW3837 MP3 Player
How long do i charge the iPhone 3g before using it?
if it is a new one initial charge for 8 hours even if the battery is full...
after that you can try can stop after the charge is full
Sep 15, 2008 | Cell Phones
I have a audiovox dvd player model D1998PK. I need to know how to tell when the battery is charged.
1. A blinking light indicates that the battery is not charging.
2. The steady light goes out (or turns green) when the battery is charged.
3. 6 to 8 hours for the initial charge.
4. Charging time after the initial charge depends on the length of time the battery was used and will increase over time as the battery gets older.
5. 2.25 hours of play time
Aug 23, 2008 | Audio Players & Recorders
Brand new Samsung YP-K3 charging FOREVER..
well have had my k3 die on me once, pressed reset on the back and it worked again (this in the it doing nothing anymore case) as for the cgarging thing try it on another computer, when I charge my k3 at work it charges all day but I don';t get a full battery, at home I charge it for bout 2 to 4 hours to get full battery. I think it has something to do with ho many things u have connected to ur usb ports or how much output ur computer gives to ur usb, maybe it goes to like a lower voltage to preserve electricity, no idea how to change this but unplug unneccecary things.
Dec 09, 2007 | Samsung YP-K3 MP3 Player
Sprint Hitachi P300 Cellular Phone Logo
14 people viewed this question
Top Sprint Cell Phones Experts
Vernon Taylor
rgnestle
Level 1 Expert
Are you a Sprint Cell Phone Expert? Answer questions, earn points and help others
