WHIRLPOOL MTW5700TQ TOP LOADER LEAKS ABOUT 1/2 GALLON OF WATER ON FLOOR
  • 5,911 Answers
You will need to remove the exterior casing of the washer to access the interior and determine where the leak may be coming from. Follow these steps:
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the consoleWHIRLPOOL MTW5700TQ TOP LOADER LEAKS ABOUT 1/2 - 2.gif has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
If the leak is coming from the front of the washer, most commonly this is caused by a leaking drain pump. The pump is located in the front directly below the wash tub. The pump is not serviceable and must be replaced if it is damaged.
Some other items to consider:
1. Check your fill hoses to ensure they are tight and not leaking. What can often appear as a washer problem, may be a loose hose.
2. With the washer case removed, check the area UNDER the wash tub. If the leak is coming from the center above the transmission, the tub seal may be leaking.
3. Inspect the wash tub for any cracks. If the tub is cracked and its not serious, you may be able to get by with some marine epoxy to reseal it. If the crack is significant, a new tub will be required.
4. Check the air dome on the lower right hand side of the wash tub. This is a small plastic air hose that runs from the wash tub all the way to the pressure switch. If this hose comes loose, the washer will start to leak as it fills. Simply reattach if it comes loose.
NOTE: It is important to remove the washer case in matters like this so that you can get a full view of everything to determine the source of the leak.
If you need an illustration of your washer and components, searspartsdirect.com, appliancepartspros.com, or pcappliancerepair.com usually has some excellent exploded view diagrams that you can refer to.
If you determine the pump is damaged and needs replaced, the following link explains how:
http://www.fixya.com/support/r397092-replacing_water_pump
Prices can vary between these sites so shop around for the best deal. NOTE: Use the part number from the Sears site and use it to "Search by Part Number" on the other sites. It makes it easier to find as some sites may not have your model number listed, but will still carry the part.
To reinstall the washer casing, follow these steps to ensure you get the case correctly placed and secure on the frame:
1. With the lid of the washer open, grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
2. Make sure the back of the washer fits into the washer casing on each side by leaning over the front of the washer and grasping the back panel and pull towards you. Reinsert the brass clips by placing the clips into the slot on the back of the washer first, and then forcefully push then down into the opening on top of the washer.
3. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
4. Reinstall console.
Read through everything thoroughly before beginning any repairs. If you have any questions, or require additional assistance, please let me know. I hope this information is helpful.
Posted on Sep 28, 2009
My whirlpool 7.5kg 6th sense front loader has stopped 1 min from completing the Mixed Wash cycle. Normally at 1 min it then swings over to 'end' and we can open the door. I have tried turning the power...
Hi Anonymous, is the machine draining out? If not,the pressure switch will not allow the door to unlock to keep from spilling gallons of water on your floor. If that's the case, there's probably something blocking the drain pump. A sock, bunch of lint or even a quarter can block the pump intake. You should be able to access the pump clean out behind the small door at the bottom of the front panel. Get a good wet vac and slowly open the trap and vacuum until no more water is leaking out. If that doesn't solve the problem, it could be a bad door lock assembly, which will need to be replaced. Hope that helps.
Jul 22, 2017 | Whirlpool Washing Machines
When filling my Kenmore washer to begin a load of laundry the water enters the tub like it is going to wash but immediately drains onto the floor and the "water sensor" never tturns the water...
This either due to a detached "water sensor"/pressure switch hose or a broken drain/leaking drain pump. Disconnect power then remove the screws securing the console to the top of the machine. Pull the console forward then up and lay it back on the hinges. The screws are located at the rear of the console, front corners of the console, or at the front corners of the console under the end caps.
Click on the link below for the detailed procedure in troubleshooting and repair of this leak problem.
Whirlpool and Kenmore Top Loader Washing Machines Leaking From the Bottom
Aug 20, 2011 | Kenmore 24032\24036 Top Load Washer
Ytek.netwe just moved into a house with a duet washing machine- a few years old. when we do a normal clean cycle, it doesnt appear there is that much water getting used. How much water should we see thru...
All front loaders use very little water as a opposed to a top loader that uses up to 45 gallons per load a front loader uses about 10,plus a front loader cleans clothes very well with that minimal water usage.
The major question is do the clothes seem to come out clean when you have used that washer?
Aug 20, 2011 | Whirlpool Washing Machines
Leaking water
Water can't leak out the top from overloading unless the entire tub is full of water which is a major malfunction, or an inlet hose between the powder drawer and tub is somehow blocked (extremely unlikely).. Are you using topload detergent? Normal detergent can foam up and out through the drawer and leak onto the floor..
Normally water enters through the top of the powder tray to disperse it into the tub. pull out the tray slightly while filling to see how this works. You might be able to identify that the water is not flowing properly. Normally you can really pack into a front loader, I've been thrilled with my 5100 for 8yrs.
If this doesn't help let me know and I'll suggest next step.
May 14, 2010 | Whirlpool AWM5125/1 Front Load Washer
My Whirlpool Gold leaking water
the water pump is bad, call a repairman usually only 75 to 85 bucks depending on where you live
Mar 01, 2010 | Whirlpool Washing Machines
Need APPROXIMATE water consumption on 10 yr old Whirlpool washer
Hello. The older top load washers use up to 60 gallons of water per load. That said, also check your toilets as a leaking toilet can use tens of thousands of gallons per year. Here is a link that explains how to check your toilets and other items for leaks. Regards, Joe
ps - kindly rate my answer as helpful. thanks.
Feb 17, 2010 | Washing Machines
GE FRONT LOADER WASHER LEAKING WATER
inspect the door boot the rubber thing between the tub and door also inspect the hoses inside the machine you will see the leak
Aug 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water found on floor under unit
Plug off the mains. You have to take off the front or back panel, whatever to observe the machine. Load a bucket of water into the wash basket (front or top loader) and use some good lighting to observe where the leak is.
If you find it is hose which is not secure you can tighten it, but if it is tear, you simply have to replace it.
Sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Mar 31, 2009 | Whirlpool Washing Machines
Water on my floor
Is it the bottom or coming out the door at the bottom? When your seal is bad it will leak, mine leaks only on handwashables and delicates. I have had to have my seal replaced twice in the three years i have had one, and the last seal was not put on right and leaks.
Dec 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
