Question about Asko W6021 Front Load Washer
I have an asko washer that does not dry. how i fix this
  • Asko Master
  • 2,605 Answers
I'm going to assume against my better judgment you mean the clothes are not spun out but are soaking wet. Since Asko washers do not dry the clothes as some all in one units do, you likely have a problem with either overloading, too much detergent, wrong type of detergent, an obstruction in the pump i.e coins, buttons, sock, undies etc. (not allowing the spin cycle to occurr) or a faulty drive motor/brushes.
Unfortunately there's no easy answer without more info. consider these...
1) have you operated this machine before ?
2) Do you use "HE" detergent
3) have you put very different types of garments in together, i.e. towels and cottons, denims and polyester ?
4) does the water drain out ?
5) is the unit stable on its legs/on the floor ?
there are many factors that can create the symptom you're describing, as these are just a few possibilities.
let us know here if any of these are possible and we can go from there.
p.s.
a model number would be helpful as well.
Posted on Sep 29, 2009
  • Kate Rigter Jul 07, 2011
    My washing machine doesn't drain at the end of a cycle, any suggestions?
Asko D5457 DISHWASHER. Dishes are clean but not dry.. Especially plastics on top eack despite long dry selected. Any ideas as to what may be occurring?
Unfortunately, plastic will not dry well if at all in this model. The only heat for drying is the residual heat left in the dishware after the hot rinse cycle. Plastics do not have enough thermal mass to hold on to the heat long enough to dry. Also, you MUST use a rinse agent in this washer. Those detergent packets with rinse aid in it is not enough. Make sure to keep the rinse aid dispenser full.
Jul 01, 2016 | Asko Dishwashers
My washing dries coarse since I purchasing my Asko front loader. Towels and socks in particular. What can I do to stop this from happening?
Use a washing softner in the final rinse water such as Downey Apparently you have hard water that lealeaves precipitated minerals in your clothes.
Feb 05, 2011 | Asko W6661 Front Load Washer
My Asko D1976 dishwasher is not cleaning dishes properly. There is a lot of clumped detergent left in the dispenser after wash cycles are complete, and many of the dishes have dried-on food left on them. ...
First of all, don't pre-rinse the dishes. Check the water temperature, it should be between 120 and 140 degrees. Be sure you are not partially blocking the dispenser door so that it isn't opening.
Sep 18, 2010 | Asko D1976 Built-in Dishwasher
Asko WCAM1812 Front Load All-in-One Washer / Dryer It does not start the lights are blinking on spin. the door remains unlocked
hold down the "cycle signal" button for 3-5 sec. unplug and plug back in. should clear and reset computer
Aug 08, 2009 | Asko WCAM1812 Front Load Washer / Dryer
Asko D3121 Dishwasher - won't dry dishes
Has anyone found a Fix for this one yet????
I have the same problem Dryer fan (Turbo Fan) in the door not working.
Apr 06, 2009 | Asko 24 in. D3121XL Free-standing...
Asko Washer/Dryer (WCAM 1812); Dryer not working.
Update: The dry cycle is now working! Apparently the automatic overload/shut off on the heating element got tripped. We had a technician out this morning. He unplugged the machine, removed the top of the unit, and simply pushed a little red/orange button that was on top of the heating element. When we plugged it back in the heating element worked again. The technician was able to troubleshoot this by checking the amps while running the dry cycle. But the proof was really when we did a load and the machine heated up (just like it used to) during the dry cycle. This was actually a relatively simply fix - though could be dangerous as you have to open up the electrical area. The reset button is rather inconspicuous and located on top of the heating element, which is long (runs front to back in the center part of the top of the machine - which you can get to by removing the lid/top outer housing) and silver - wrapped in insulation. It's pretty obvious. The button is in a little metal fixture on top of the heating element. The technician told us that the rest can get tripped when the unit overheats. (We think this happened when the laundry tub overfilled and the hose was totally submerged - the machine was working overtime to pump out the water.) The technician also warned that this can happen if the machine gets turned off suddenly mid-cycle - especially during the drying cycle. He said that the heating element gets so hot, it needs to have a gentle cool down period, which is marked on the dryer dial for the last 20 minutes of the cycle. I hope this helps others!
Mar 08, 2009 | Asko WCAM1812 Front Load Washer / Dryer
I need to know if a new Asko Dryer will stack with my old washer
The exterior size hasn't changed and the plug to run the washer is the same so I don't see a problem. A good retailer can check this for you , but I haven't seen any difference in the stacking kits.
Feb 12, 2009 | Asko T712 Electric Dryer
Clothes smell.
Mold, mildew and other fun things use washers as a breeding ground. Clean your machine with a generous amount of white vinegar run through a cycle. Or there is a product called Affresh you can buy at Lowes or Home Depot.
Jun 21, 2008 | Asko W6221 Front Load Washer
Aslo T700 Dryer Heats but won't dry.
TRY DISCONNECTING THE EXHAUST FROM THE BACK OF THE DRYER AND RUN ONE LOAD THROUGH IT. IF IT DRIES O.K., THEN YOU HAVE A RESTRICTION IN THE DUCT WORK.
Apr 07, 2008 | Asko T700 Electric Commercial Dryer
Asko 12505
It's probably the heater, or the thermostat. You must have a serviceman to fix that:)
Feb 03, 2008 | Asko W6461 Front Load Washer
Asko W6021 Front Load Washer Logo
116 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Joseph Hoffmann
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
