Question about Hotpoint Aquarius WF220 Front Load Washer
How to attache drive belt to drive drum .belt will not reach.loosening bolts that hold motor on did not help.forced on but belt twisted on drum.
  • Hotpoint Master
  • 3,463 Answers
Remove rear cover of washer, and top cover also, tilt washer towards you, get someone to hold washer steady, fit belt round motor pulley,and slowly feed belt round drum pulley, watch your fingers, keep feeding belt round oulley, turning drum at same time, it will be tight, but persist, and belt will go on.
Please rate my solution.
Thanks.
Posted on Sep 28, 2009
Drum wont turn but the moter does
Hello Deanna - This particular issue could be caused by a variety of reasons. I would suggest trying the following steps:
1) Verify a circuit breaker isn't tripped
2) Advance the timer control dial slowly 360 degrees-
If the washer starts spinning, then that means the motor and drive belt are fine but that there is something wrong with either the timer control dial or the agitator solenoid. Call in a professional for this.
If the washer doesn't budge, then verify that the drive belt(s) is attached and not broken by removing the back panel. If the belt is broken, replace it. If it is loose, then tighten it by loosening up the bolt holding the motor and moving it on its swingarm (much like a car alternator) until there is a 1/2 to 3/4 inch deflection in the belt.
Some washers use reversing motors. It's possible the motor works on the spin cycle but not on the wash cycle. If so, call a pro.
3) Visually inspect the lid safety switch- Is it loose or cracked? If so, the washer might work intermittently, stopping at different cycles.
4) Check motor and drive belt- Remove the main access panel (usually in the back). Is the motor spinning, but the drive belt isn't? If so, then you have a drive belt problem.
Sep 30, 2012 | Frigidaire Affinity ATF7000E Front Load...
Belt routing
V-BELT ADJUSTMENT CAUTION
On models equipped with an electric cooling fan, disconnect the negative battery cable or fan motor wiring harness connector before replacing or adjusting drive belts. The fan may come on, under certain circumstances, even though the ignition is OFF. Alternator Drive Belt
  1. Position a ruler perpendicular to the drive belt at its longest run. Test the tightness of the belt by pressing it firmly with your thumb. The deflection should not exceed 1?4 in. (6mm).
  2. If the deflection exceeds 1?4 in. (6mm), loosen the alternator mounting and adjusting arm bolts.
  3. On 1968-72 V8 and 6 cylinder models, use a prytool to move the alternator toward or away from the engine until the proper tension is reached. NOTE: Apply tension to the front of the alternator only. Positioning the prytool against the rear end housing will damage the alternator.
  4. On 1973 and later V8 models, place a 1 in. (25.4mm) open-end or equivalent wrench on the adjusting arm bolt and pull on the wrench until the proper tension is achieved.
  5. Holding the alternator in place, tighten the adjusting arm bolt. Inspect the belt tension. When the belt is properly tensioned, tighten the alternator mounting bolt. Fig. 1: Alternator belt adjustment 86651054.gif
Power Steering Drive Belt ALL 6-CYLINDER AND 1971-72 V8 MODELS
  1. Holding a ruler perpendicular to the drive belt at its longest run, test the tightness of the belt by pressing it firmly with your thumb. The deflection should not exceed 1?4 in. (6mm).
  2. To adjust the belt tension, loosen the adjusting and mounting bolts on the front face of the steering pump cover plate (hub side).
  3. Using a prytool on the pump hub, move the power steering pump toward or away from the engine until the proper tension is reached. Do not pry against the reservoir as it is relatively soft and easily deformed.
  4. Hold the pump in place, tighten the adjusting arm bolt and then inspect the belt tension. When the belt is properly tensioned tighten the mounting bolts.
1973 AND LATER V8 MODELS
  1. Position a ruler perpendicular to the drive belt at its longest run. Test the tightness of the belt by pressing it firmly with your thumb. The deflection should be about 1?4 in. (6mm).
  2. To adjust the belt tension, loosen the three bolts in the three elongated adjusting slots at the power steering pump attaching bracket.
  3. Turn the steering pump drive belt adjusting nut as required until the proper deflection is obtained. Turning the adjusting nut clockwise will increase tension and decrease deflection; counterclockwise will decrease tension and increase deflection.
  4. Without disturbing the pump, tighten the three attaching bolts. Fig. 2: Power steering belt adjustment (slider type) 86651055.gif
Air Conditioning Compressor Drive Belt
  2. If the engine is equipped with an idler pulley, loosen the idler pulley adjusting boot, insert a prytool between the pulley and the engine (or in the idler pulley adjusting slot), and adjust the tension accordingly. If the engine is not equipped with an idler pulley, the alternator must be moved to adjust, as outlined under Alternator Drive Belt.
  3. When the proper tension is reached, tighten the idler pulley adjusting bolt (if so equipped) or the alternator adjusting and mounting bolts. Fig. 3: Air conditioning belt adjustment 86651056.gif
Thermactor® Air Pump Drive Belt
  2. To adjust the belt tension, loosen the adjusting arm bolt slightly. If necessary, also loosen the mounting belt slightly.
  3. Using a prytool, pry against the pump rear cover to move the pump toward or away from the engine as necessary. WARNING
    Do not pry against the pump housing itself, as damage to the housing may result.
  4. Holding the pump in place, tighten the adjusting arm bolt and recheck the tension. When the belt is properly tensioned, tighten the mounting bolt. Fig. 4: Air pump adjustment points 86651057.gif
Nov 12, 2010 | 1988 Mercury Grand Marquis
Haier HLP21E belt broke. My machine was overloaded. How do I replace it?
put new belt on big pulley first then roll in over on smaller one
Mar 29, 2010 | Haier HLP21E Top Load Washer
If I stand on the belt it stops moving
Unplug unit remove motor shroud so you can see the drive belt, plug in unit then start it you will be able to see whether the drive belt or running is actually causing the problem.If it is the running belt then turn both rear roller adjustment bolts clockwise in equal quarter turn increments until treadbelt stops slipping. NOTE: Be sure to run on treadbelt to ensure that the treadbelt does not slip while under load. Use 1/4" allen wrench
If the drive belt is slipping then to adjust the belt you must loosen the adjusting bolt on the motor frame then hold the motor by hand applied tension to belt then tight bolt you should be able to twist the drive belt no more then 45 degrees if you can repeat adjusting process.
Mar 13, 2010 | Proform 760 CrossTrainer Treadmill
Drive belt has slipped off treadmill. how do i get it back on
What type is it? Usually you need to remove the cover over the motor first. Then loosen the motor. There are probably 2 bolts, 1 that it pivots on and 1 that holds it in place. Loosen the hold bolt (and possibly the pivot bolt as well) then slip the belt back on making sure you center it in the grooves. You will need to apply pressure to the motor (maybe you will need help with this) then tighten the hold bolt and pivot if you loosened as well.
DO NOT OVER TIGHTEN THE BELT!!! It can result in bearing or motor failure.
You should be able to twist the belt 90 degrees at the midpoint between the 2 pulleys as an indicator.
Note: If you belt has slipped off it's a good sign that it might be time to replace it. If you do you will still need to re-tension it.
Jan 16, 2010 | Exercise & Fitness
How to remove and replace a motor belt on proform
Hello there. To replace the drive belt (motor belt) follow this procedure.
1)Remove power to the machine
2)remove the hood cover (3 screws on the rear of the cover)
3) loosen the adjusting bolts for the walk belt located on the opposite end of the walk belt from the hood assembly. Loosen the adjusting bolts 10 full revolutions. This will loosen the walk belt.
4) You should then walk the drive belt off of the front roller/pulley assembly by pushing the belt to one side while turning the motor. If you are nable to do this you will need to loosen the 2 bolts holding the drive motor in place.
5) After removing the drive belt you can then slide the drive roller to the side out of the frame and it will slide out the other side of the bracket. This will allow the belt to be removed from the front roller and be replaced.
If you had to loosen the bolts holding the motor you will need to retension the drive belt by pulling the drive motor back while tightening the bolts. This will require another person to help tension while you tighten the bolts.
You can then retension the walk belt using the adjusting bolts and retightening them 10 revolutions.
Good Luck Tim
Dec 13, 2009 | Exercise & Fitness
How do I replace the motor drive belt
  1. 180px-underneath_920.jpg magnify-clip.pngPictured here on a folded sheet on a carpet floor.Unplug the jointer. Invert it on a thick cloth to protect the blades and the work surface. Underneath you will see a base plate that covers the bottom and is held in place by seven screws.
  2. 180px-baseplateremoved_628.jpg magnify-clip.pngBase plate removedRemove all of the seven screws and set them aside with the baseplate. With the baseplate removed, you will see the power leads running to the main switch and back to the motor.
  3. 180px-hexbolts_779.jpg magnify-clip.pngTwo of the hex boltsRemove the hex bolts that hold the motor in place. There are two on one side of the motor (indicated by purple rectangles in the picture), and another one on the other side. Remove them completely to allow the motor sufficient room to move in order to place the drive belt over the motor spindle.
    • 180px-hexkeyextension_378.jpg magnify-clip.pngHex key "extension"If your hex key is not long enough for this job, hold the key in a pair of pliers or vice grip to remove them.
    • Now that the jointer is disassembled, this is a good time to clean all the motor housing thoroughly and lubricate, if applicable.
  4. 180px-twistedmotor_569.jpg magnify-clip.pngMotor twisted, drive belt belt attached towards bottom of pictureLift and rotate the motor and attach the drive belt. The motor will not easily return to its normal position. In the picture you can see just how far the motor has been turned to get the drive belt on.
  5. Insert the hex bolts again, deep inside a very narrow space, whilst using a fair bit of force to hold the motor in place. This is the difficult part, and you may utter a few choice words at this point and consider some unauthorized modifications to the housing.
  6. 180px-done_728.jpg magnify-clip.pngDone!With patience and persistence you should be able to secure the hex bolts once more and once again have an operational planer/jointer.
Jul 30, 2009 | Exercise & Fitness
I need to see a diagram on how to take apart and install a new wheel for pushing out the hot air to the outside.
Since you did not provide a make and model I cannot give you specific diagram or instructions. Here is the general procedure to replace a fan wheel that is attached to the shaft at one end of the motor.
Disconnect power. Remove drum drive belt from the small wheel at the motor. It should have a spring tension wheel that can be loosened to remove it. You shouldn ot have to remove the belt from around the drum. Remove the screws/bolts that hold the motor in place. Disconnect wiring if necessary. Keep track of what wire is connected to each terminal so you can reconnect easily. Lift the motor out and install the new fan wheel on the shaft (after removing the old wheel.) Reverse the procedure to re-install.
Jul 08, 2009 | Dryers
How do you install a new belt? its hard to fit around !!
Youmust loosen the motor bracket bolts and this will allow the motor to swing. Put belt on the motor pulley and feed the belt onto the large drum pulley and at the same time turn the drum pulley so that the belt pulls onto the pulley groove. Put some tension on the motor to tension the belt - not too much tension though. Holding the motor & belt tension, tighten the motor bracket bolts - job done. Should take no more than twenty minutes to complete.
Apr 14, 2009 | Washing Machines
SAV205DAWW Maytag Washer Belt Replacement Instructions
This is specifically for a Maytag Legacy SAV515DAWW, but may apply to the whole Legacy line.
There is only one drive belt on this washer and it is not accessible directly from the bottom as a pan forms the bottom of the case. All work can be performed through the bottom front panel, once it is removed.
Before one starts, an overview is helpful. The motor for the washer is bounted just behind the access panel. Attached to the shaft at the motor bottom is the drive pully for the drum belt, along with the belt tensioning pully and spring. Below that is the pump assembly attached by three screws in the shafts, which are accessible only from the bottom. What you must do, is remove the pump by unfastening four hex-head bolts, then rotate the motor and pump assembly bottom upwards to the front, so the bottom of the shafts containing the torx head screws fastening the pump are accessible.
While everything is all together it is helpful to notice that the far support for the pump is in almost a direct line with the motor shaft and the tum pully shaft. When you reassemble the components, this vertical pump support must go between the belt. As you face the washer, the tensioning pully will ride on the outside of the right side of the belt.
1. Unplug the washer.
2. Pull it out from the wall, so it may be tilted back at about a 45 degree angle and will not fall foreward.
3 Remove the two hex head screws on the right and left bottom front of the washer. The panel should lift out from the bottom, Two pins hold the top of the panel in.
4. Examine the mechanism as described above.
5. Detach (Unhook) the tensioning pulley spring from the front of the bracket above the pump..
It is not necessary to remove any of the hoses. There is adequate flexibility and slack for replacing the belt.
6. Remove the four hex bolts attaching the galvanized motor bracket to the frame.
7. Rotate the motor back, so the pump bottom faces the front.
8. Remove the three torx head screws in the pump support arms.
9. Detach the pump from the motor. Gently pry it off or gently strike the body of the pump away from the motor with a soft faced mallet.
10. Place the new belt on the motor pully and reinstall the pump, so the leg closes to the tub pulley is inside the two sides of the belt. Reinstall the pump screws in the plastic shafts.
11. Reinstall the motor and fasten the bolts.
12. Make sure the tensioning pulley is to your right of the belt and then side your hands to the rear and slip the belt under the drum pulley and completely around it.
13 Feed the belt onto the drum pulley. I did this by reaching back with my left hand and feeding the belt, coming from the motor pulley, into the drum pulley, then slowly rotating the right side of the drum to me with my right hand.
14 Check to ensure the tensioning pulley is to the right of the belts, then reattach the spring, so the pulley forces the righthand belt to the left.
15. Set the washer upright, open the lid and rotate the drum around twice using your hands. This will help seat the belt on the pulleys and ensure the drum is not stuck.
16. Make sure the cycle switch is pulled out (set to off) and plug the power in.
17. Set on a wash cycle and looking in the bottom , check for proper operation. If the motor appears to be stalling, immediately turn the unit off. Rotate to tub some more by hand and test for operation. If it still doesn't work, see help, your problem is more than just a belt!
18. If everything seems to work, toss in a test load of laundry and pat yourself on the back for being able to save some money!
Mar 24, 2008 | Maytag Legacy Series Top Load Washer
Hotpoint Aquarius WF220 Front Load Washer Logo
154 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
