Question about Saeco Incanto Classic Espresso Machine
Water is full, but red water light is on and coffee wont come out
I tried turning the frother on to prime it , but red light still on. I also tried unplugging it and plugging it back in, still doesnt work.
    Sergeant:
  • Saeco Expert
  • 223 Answers
99% of the time it's the float. You can change the float or the whole water tank.
Saeco Gaggia Water tank Float
Complete water tank.
Water Tank for Incanto Classic Deluxe Sirius Rondo
Send the machine fro service to the service center.
Service Center for Saeco Gaggia Rancilio Spidem Starbucks Espresso Machines
Posted on Jun 03, 2015
Had a similar problem with float - requires service call and was fixed under warranty
Posted on Oct 05, 2009
    President:
  • 1,618 Answers
Try lifting the water tank and make sure it is pressed along the back of the machine when you put it back in.
Posted on Sep 29, 2009
Saeco coffee machine with a red blinking exclamation point light won't make coffee, how do I fix it?
When the red exclamation point is flashing slow, something is not where it is supposed to be, bean hopper lid, door, brew mech, water tank empty, dregs box or water tray on dregs container is full. If the red exclamation point is flashing quickly, open the steam valve for pump priming. If pump turns on, and water passes correctly, the light should go off and return to heating stage. If not, we have a blockage or a pump that is not working correctly.
Nov 16, 2015 | Saeco Odea Giro Plus Coffee Maker
The descaling light stays on even though I have gone thru the process of descaling.
You are not completing the descale program. See below.
10.3 DESCALING
Due to the continuous heating of the water used to make the coffee, over
time it is normal for the tubing inside the machine to fill with lime scale.
When the light starts flashing( chap. 12-point 5), it is time to descale
the machine.
NOTE: when the light switches on, the coffee maker can still be used to
prepare coffee.
Proceed as follows:
• Empty the tank and pour in the contents of one bottle (125 ml) of
DURGOL descaler plus one liter of water. For subsequent descaling
operations, descaling solution can be purchased from authorised
technical service centres.
NB: Make sure splashes of descaler do not fall onto surfaces sensitive
to acid such as marble, limestone and glaze.
• place a container with a minimum capacity of 1.5 litres under
the milk frother (Fig. 3);
• turn the machine on by pressing the button (Fig. 4).
• wait for the green and indicator lights to come on steady.
• press and hold the button for at least 5 seconds (Fig.14). The
light inside the button switches on (chap. 11 - point 8) to indicate
the start of the descaling program (the and lights remain
off to indicate that it is not possible to make coffee).
• turn the steam knob half a turn anticlockwise (Fig.5). The
descaling solution will come out of the milk frother and start to
fill the container underneath.
• the descaling program automatically performs a series of deliveries
and pauses, so as to remove the lime scale deposits from
inside the coffee maker.
Fig.32
The two red buttons
have opened
out CORRECTLY
The two red buttons
have not
opened out
CORRECT INCORRECT
33
OPERATING INSTRUCTIONS
• after around 30 minutes, when the light comes on (chap. 12 - GB
point 1), turn the steam knob half a turn clockwise (Fig.6) until it
stops.
The machine must be rinsed so as to eliminate the residues of descaling
solution from inside the machine. Proceed as follows:
• remove the water tank, rinse it and fill it with clean water.
• reposition the tank.
• empty the collection container (located under the milk frother) that is
full of liquid, and then replace it under the milk frother.
• turn the steam knob half a turn anticlockwise (Fig. 5). Hot water will
come out of the milk frother and fill the container underneath.
• when the tank is empty, the light goes off and the light
comes on (chap. 12 - point 1).
• turn the steam knob all the way clockwise (Fig. 6) and fill the water
tank with clean water again.
• the program of descaling is hour terminated and the machine is
ready per do again the coffee.
NOTE: if the descaling procedure is stopped before completion, the
alarm (chap. 12 - point 5) is not deactivated and the procedure
must be started again form the beginning.
IMPORTANT: THE GUARANTEE IS NOT VALID IF THE ABOVE DESCALING OPERATION
IS NOT PERFORMED REGULARLY.
Sep 20, 2011 | DeLonghi Magnifica 3300 Espresso Machine
Hello. I was given the coffee maker below for Christmas. Unfortunately I find it a bit of a nightmare to use and I definitly will have to return it to John Lewis if I cannot overcome the problem...
To prime machine run the hot water cycle, press the button for hot water and open the steam knob until you get a nice flow of water. It is possible that you grind is too fine, try adjusting it coarser by 2 numbers.
Jan 19, 2011 | Saeco Vienna Deluxe 708461030122DE
How do you descale my Delonghi Magnifica?
10.3 DESCALING Due to the continuous heating of the water used to make the coffee, over time it is normal for the tubing inside the machine to fill with lime scale. When the light starts flashing (section 12 - point 5), it is time to descale the machine. NOTE: when the light switches on, the coffee maker can still be used to prepare coffee. Proceed as follows: • Empty the tank and pour in the contents of one bottle (125 ml) of DURGOL descaler plus one liter of water. For subsequent descaling operations, descaling solution can be purchased from authorized technical service centers. Note: Make sure splashes of descaler do not fall onto surfaces sensitive to acid such as marble, limestone and granite. • place a container with a minimum capacity of 34 oz. under the cappuccino frother (Fig. 3); • turn the machine on by pressing the button (Fig. 4). • wait for the green and indicator lights to come on steady. • press and hold the button for at least 5 seconds (Fig.14). The decalcification warning light will illuminate (section 11 - point 8) to indicated the start of the descaling program (the and lights remain off to indicate that it is not possible to make coffee). • turn the steam knob half a turn counter-clockwise (Fig.5). The descaling solution will come out of the cappuccino frother and start to fill the container underneath. • the descaling program automatically performs a series of deliveries and pauses, so as to remove the lime scale deposits from inside the coffee maker. Fig.32 The two red buttons have snapped out CORRECTLY The two red buttons have not snapped out CORRECT INCORRECT 17 OPERATING INSTRUCTIONS • after around 30 minutes, when the light comes on (section 12 - point 1), turn the steam knob half a turn clockwise (Fig.6) until it stops. The machine must be rinsed so as to eliminate the residues of descaling solution from inside the machine. Proceed as follows: • remove the water tank, rinse it and fill it with clean water. • reposition the tank. • empty the collection container (located under the milk frother) that is full of liquid, and then replace it under the milk frother. • turn the steam knob half a turn counter-clockwise (Fig. 5). Hot water will come out of the milk frother and fill the container underneath. • when the tank is empty, the l ight goes off and the light comes on (section 12 - point 1). • turn the steam knob all the way clockwise (Fig. 6) and fill the water tank with clean water again. • the program of descaling is now terminated and the machine is ready to make coffee again. NOTE: if the descaling procedure is interrupted before completion, the alarm (section 12 - point 5) is not deactivated and the procedure must be started again form the beginning.
Jul 14, 2010 | DeLonghi EAM3500 Espresso Machine/Coffee...
Flashing lights on my saeco italia espresso machine
I had the same problem, two green flashing lights with one red (water) all 3 would just keep flashing and not turn solid. No coffee can be made or hot water. I could not pump prime. The problem was the steam wand was blocked with old milk residue. It needs unblocking or you will never pump prime. I could not unscrew the steam wand...so I let it sink in a glass full of hot water for a few minutes and then turned the water knob counter clockwise to push out the softened residue. After that, everything was good. When water started flowing out of the steam wand, the red light turned off and the green lights turned solid. The obvious answer to why you can't pump prime is there is a blockage somewhere and best to start with the steam wand. --Mabada
Feb 22, 2010 | Starbucks Saeco Italia Digital Barista...
Saeco Italia SUP021 YR green lights and red water light flashing
You can't manually reset. The machine will have to do it. I had the same problem, two green flashing lights with one red (water) all 3 would just keep flashing and not turn solid. No coffee can be made or hot water. I could not pump prime. The problem was the steam wand was blocked with old milk residue. It needs unblocking or you will never pump prime. I could not unscrew the steam wand...so I let it sink in a glass full of hot water for a few minutes and then turned the water knob counter clockwise to push out the softened residue. After that, everything was good. When water started flowing out of the steam wand, the red light turned off and the green lights turned solid. The obvious answer to why you can't pump prime is there is a blockage somewhere and best to start with the steam wand. --Mabada
Sep 14, 2009 | Starbucks Saeco Italia Digital Barista...
I have a Briel ED 132A Classic how do I prime the pump for the st
Sometimes the self- priming pump feature may not work due to a momentary "air lock" condition. If water does not flow from brew head, place a cup under the steam frother. Open steam control and turn the switcher onto the icon of the half-full cup until water flows from steam frother. Turn off steam control, as Espresso maker is now ready.
Manual is located here:
http://www.smithagy.net/BrielInstructionManual.pdf
Mar 15, 2009 | Briel Sintra ED-132 Espresso & Coffee...
Saeco Incanto Classic Espresso Machine Logo
422 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
