Question about Denon AVR-2500 Receiver
Denon AVR 2500 no sound from 3 of 4 speakers
No sound from speaker B. Right speaker A ok. Appears to be an electrical disconnect at speaker terminal. When I move the terminal post, the speaker will temporarily engage. I removed covered and checked for voltage at the lead to the speaker terminals. Voltage was present on all speaker leads.
Thanks for help.
  • tuneman 76 Jun 22, 2008
    I have 4 speakers hooked up to my AVR-2500 Denon...The left 2 are great, but the right 2 are cutting out...they will stay on for a few minutes, then they will cut out, leaving only the left 2 on. I have checked all of the connections, and re-secured them all to the back of the reciever...This has'nt solved my issue. I have the center 2 hooked up to the 'A' side, and the outside 2 to the 'B' side...but again...same issue...HELP !! Paul, Auburn Ca.
Do you have a copy of the owners manual for the Denon AVR 2500? I can't find a copy of one.
Posted on Jun 14, 2008
Denon avr 592 no sound
First of all check all the speakers. Maybe all the speakers gone out because of the loud blast. Also check in the tuner mode. Is there is any sound. If there is some problem in the avr then it will show the fault and will go into protection mode.
You can check the speakers with a battery from any one of the remote. Take the leads of each speakers and connect the lead to the battery terminals. If the speaker is ok then it will make a small cracking sound each time when you connect its wire to the battery.
Sep 27, 2012 | Denon AVR-2802
No Sound in Right Front Speaker- Denon AVR-1508
hi there,
have you check the system settings for each of the speaker..? should be set and balance all output of the speaker
May 24, 2008 | Audio Players & Recorders
I have a Denon AVR-587. It has worked fine for 2-3 years, but ever since I tried to connect it to a different set of speakers, it cuts out after a few minutes and I hear this loud clicking sound coming...
There is a short either on the speaker wires to the speakers or the speakers are defective (some sort of a short or too low of resistance). Lastly, check to see if a stray strand of wire is not touch the left and right terminals. Any short in the network (wire, lack of insulation, staple, screw, etc. ) will cause the system to clip.
Nov 10, 2010 | Denon AVR-587
Power light blinks off and on Red
* The speaker terminals are shorted -- Disconnect speakers one at a time and try again.
* Ventilation of the unit is inadequate
* Has been running at too high a volume with inadequate cooling
Go here, register and get the manual for free....
Search for Denon-AVR-485S
May 04, 2009 | Denon AVR-485 Receiver
Speaker connection from Denon AVR 2105 to Wharfedale suround
The spkrs sound like they are bi-amp spkrs, meaning you have multiple terminals on the backs of each spkr, the jumpers on the spkrs should be connected as such. Now you just connect the spkrs according to the Denon spkr conection diagram. Do not use the surround back unless you have 6 or 7 pair of spkrs
Jan 27, 2009 | Denon AVR-2105 Receiver
Speakers on the right side of my AVR will produce no sound in any
change the right channel audio ic of your denon amplifier.
Jan 07, 2009 | Denon AVR-1906 Receiver
Denon avr-1403/483
Denon AVR-1403/483One of the speakers when connected trips the units power off.
Disconnected it and it works OK without that channel. Connected a different speaker and wire to that channel and it does the same, trips power off. It's acting like a when two wires are shorted. This is not the case as I have tried different wires and speaker. Not sure whats going on. Presently running system without that channel. Hope someone has an idea.
Oct 19, 2008 | Denon AVR-1403 Receiver
Denon AVR 2807 with Bose Acoustimass 15
Well,i can tell you are not very focus,cause you posted Denon AVR-2807 with Bose AC 15 problem,but under your details,you put down AVR-5807!
First of all,it is so unfortunate that you are NOT able to gain and experience to true ability in sound for this wonderful receiver when you are using a dual tweeters speakers and expect to have good sound separation as a TWO WAY speakers(a tweeter and a midrange-for true high frequency and mid frequency sound separation.)
Secondly,you have defeated the audio configuration of the Denon AVR-2807,since all your speakers are control BY the Bose subwoofer.
Now,i could show you a way to hook this up,and it doesn't matter how you connect them, they are the "bicycle tires" installed with a "Porche"engine if you know what i mean.
If you want a good recommendation for your "beast",i will more than happy to show you the way!
Sep 28, 2008 | Denon AVR-2807 Receiver
Denon AVR 883 Audio glitch
More than likely the protector circuit is getting activated... You can't go below 6 ohms on the surround back which means you need 12 ohm or higher speakers for outside (since the two outputs for surround back/zone2 are in parallel). As a simple diagnostic test, disconnect one speaker and see if the sound survives longer than 2 seconds.
Mar 26, 2008 | Denon AVR-883 Receiver
AVR-1603 - no Sound exept over Headphones is a weak signal
First check the outputs at the output fets/transistors for any DC voltage. Reference your voltmeter to the speaker - terminal. If there is ANY DC offset, the amp is shutting down the outputs to protect your speakers from DC. Is the power supply + and - 47 volts? If only one supply is there That is your problem because the supplies should be symmetrical. Also look for any wiring problems from the amp to your speakers... any shorts? Try disconnecting all your speakers to totally eliminate any speaker problem and see if the relays still click. You should hear only ONE click when you first turn the amp on (delay of about 2-5 seconds). If they keep clicking the amp outputs are next. Also, is there any indication on the front panel of what is failing?
Jul 29, 2007 | Denon AVR-1603 Receiver
609 people viewed this question
Top Denon Audio Players & Recorders Experts
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
