Question about Minolta C350 Printer
Error C0098, how to solve - Minolta C350 Printer
    New Friend:
I had the same problem, coincidentally I changed the power supply board, and the problem is addressed.
Posted on Jul 08, 2013
Gear that drives pressure/retraction is broken
Posted on Jun 12, 2008
That is a Fuser Unit pressure/retraction problem. Most likely a faulty unit. If not, then defective connection/motor/system control PCB.
Posted on Feb 01, 2008
I got code 108 eror
How to solve 108.xx, 108.08 error on Lexmark printers ~ Fix ...
fix-your-printer.blogspot.com/.../how-to-solve-108xx-10808-error-on.ht...
How to solve 108.xx, 108.08 error on Lexmark printers. A 106.xx, 107.xx, 108.xx, or 109.xx error indicates a problem with one of the ... Libell?s : Error code ...
IBM OPOS, Common Error/Return Codes - United States
www.ibm.com/support/docview.wss?uid=pos1R1000395
IBMMar 30, 2006 - I'm new to OPOS and get error return codes or result codes. What do ...108, OPOS_E_OFFLINE, The physical device is not connected or not ...
why am i getting error code 108 - QuickBooks Learn & Support
Dec 26, 2015 | Office Equipment & Supplies
What does error code C0098 mean
no such code for the bizhub 350
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Mar 05, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Cannon ir 3530 all error code and solution
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
Mar 03, 2011 | Canon ImageRUNNER 3570 Copier/Printer
CAnon xerox Machine IR 2318 L Error code : E 000007-0000
My canon ir 2318L shows error**E000007-0000 how can i solve this problem
Feb 28, 2011 | Office Equipment & Supplies
How do I solve error code 0002 on my epson pro 9800 maitenance error code 0002 unable to print
tomas
how do I solve error code 0002 on my epson pro 9800 maitenance error code 0002 unable to print
Solve this problem:
Aug 02, 2010 | Epson Stylus Pro 9600 InkJet Printer
Bizbub 350 fault codec0098 none of the motors run
C0098 : Fusing Pressure Roller pressure/retraction failure.
Relevant electrical parrts:fusing pressure/retraction sensor PC33,fusing pressure/retraction motor M19,controlboard PWB MC or fusing unit.Please check M9 connector,PC 33,PC 34,M19,or if posible change the fusing unit.
Jul 28, 2009 | Minolta Office Equipment & Supplies
ERROR CODE C0096 - BIZHUB C350
2.6.19 C0096: Image Transfer Belt pressure/retraction failure
2.6.20 C0098: Fusing Pressure Roller pressure/retraction failure
Relevant Electrical Parts
1st Image Transfer Retraction Position Sensor (PC12)
1st Image Transfer Pressure/Retraction Motor (M11)
Control Board (PWB-MC)
Step Action
WIRING DIAGRAM
Control Signal
Location
(Electrical
Component)
Check the M11 connector for proper connection
and correct as necessary.
2 PC12 I/O check PWB-MC PJ3MC-6B (ON) 6-B
M11 operation check PWB-MC PJ5MC-1~4
(Pulse Output)
6-C
4 Change PWB-MC
Feb 18, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Minolta C350 Printer Logo
806 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Marvin
Marvin
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
