Question about Samsung SP-R4232 42 in. Plasma HDTV
Takes several minutes to turn on/clicks continually
The on/off light blinks until it finally comes on. it is only a year and a half year old. we do not have a computer hooked up to it so it shouldnt be using a power management mode. really need help cause we are 200 miles from nearest repairman. and 1fter paying 2500 dollars for something it should work longer.
  • 834 Answers
You have 1 weak capacitor in the power supply check it out the can like cap will have a puff up top where it vented change it or have it doen and you will be alset
Posted on Sep 28, 2009
Sharp aquos model lc-13s2u-s . When first turned on , the red/green standby/power on led blinks for several minutes before finally turning green
The power supply may be failing. The blinking will continue for longer and longer periods until eventual total failure.
Sep 10, 2014 | Televison & Video
Startup takes hours, help?
The clicking suggests a power supply issue, a old trick I use in cases like this is a hairdryer, Try to heat (don't melt things) different boards carefully until you get a dramatic reaction, considering the brand which I do not like much less endorse, what is there to lose.
If you pinpoint the issue to one board try to locate that board.
Dec 11, 2012 | Samsung LCD-TV LE40S81B 40 in. HD-Ready...
My Mitsubishi Medallion tv stays on for about 10 minutes and then shuts down and won't turn back on until a period of time has passed. It is a rear projection tv about 9 years old. Can anyone help ex
When it shuts off and the green power light goes off, press both the menu and input buttons on the front of the set (not the remote) and hold both for about five seconds and release.
Power light will blink a two digit error code like 2 blinks and then 3 blinks and repeat it several times.
What is the error code?
Nov 14, 2011 | Mitsubishi WS-55819 55" Rear Projection...
No display or audio
I had the same problem after replacing several things and still having same problem, it ended up being a capacitor.
Jul 03, 2010 | Toshiba TP55H60 55" Rear Projection...
LG 47" LCD shuts down several times w/ blinking red light.
Granger1212 we had the same problem. We called LG and although our LG was out of warranty by 4 months, we were asked to supply our proof of purchase and LG sent a serviceman to our home and in 2 days we had our television back working wonderfully. It's the power supply, call LG and BE NICE, I'm sure they will fix it.
Sep 22, 2009 | Philips 42PF7421D 32 in. LCD HDTV
Monitor takes several minutes to come on
ur problem is with VGA port of ur monitor check it out wether its connection loose or not the problem is of power signal its not getting a proper current supply so check it out otherwise repair it.....
Aug 30, 2009 | Mag Innovision Computers & Internet
My tv takes like ten minutes untill it's turning on,why?
Replace any swollen capacitors in power supply.
Apr 24, 2009 | Televison & Video
Blinking green light and clicking noise AFTER bulb replacement
do this. press and hold device and menu button on set for 5 seconds. this will retrieve a 2 digit error code .. the led will flash the first digit and pause the flash second digit. This unit is known to have capacitor problems on the power board. getting to these capacitors involves taking alot apart. let me know error codes and we can continue troubleshooting
Jan 15, 2009 | Mitsubishi WD-52525 52" Rear Projection...
My RCA D52W20 will not stay on
Clicking sound is power relay engaging. If all systems are not functioning properly, unit will shut down to prevent further damage and/or fire hazard
Apr 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Samsung SP-R4232 42 in. Plasma HDTV Logo
Jerry Greenberg
Jerry Greenberg
