Question about Sage Timeslips 2008 Full Version for PC (TSW2008RT)
Lost "full name" option in Client Job List... anyone know how to retrieve it? cannot find in options tab
  • 557 Answers
Try it with Copyright (c) 2004-2008 Topala Software Solutions
* SIW - System Information for Windows - version 2008-04-02
free for use and download
Posted on Sep 28, 2009
Testimonial: "Thank you!"
Lost my tool bar
Step 1:
Create Menu tab right click in the top of screen (toolbar) you will see a number of toolbar options select the menu bar This will add to your screen toolbar File Edit View Favorites Tools and Help Select Tools tab then from the drop down menu Mange Add - Ons you will see Toolbar Extensions Search Providers Accelerators and Tracking protection You can remove or disable them right click on them select disable or remove some don't have the option to remove
Feb 20, 2013 | Borland Quattro Pro 5.0 Full Version for...
Tip
DHCP Server configuration in Linux
Linux is a UNIX based operating system. It is a server operating system. REDHAT Linux is Enterprise version of Linux. Now a day's Most of corporate sectors use red hat Linux as server in their company because it is secure very much.
Full form of DHCP "Dynamic Host Configuration Protocol. DHCP server assigns IP addresses and other network configuration information like subnet mask, broadcast address, etc to computers on a network. The DHCP assignments are the following.
Lease Request: Client broadcasts their request to DHCP server with a source address of 0.0.0.0 and a destination address of 255.255.255.255.
IP lease offer: DHCP server replies with an IP address, subnet mask, network gateway, name of the domain, name servers, duration of the lease and the IP address of the DHCP server.
Lease Selection: Client receives offer and broadcasts to al DHCP servers that will accept given offer so that other DHCP server need not make an offer.
The DHCP server then sends an ack to the client. The client is configured to use TCP/IP. Lease Renewal: When half of the lease time has expired, the client will issue a new request to the DHCP server.
Installation of DHCP server: First of all while install the RedHat Linux enterprise version server be careful about the ports and the services must be turned on. To create DHCP server in Linux first download DHCP RPM package and install with "rpm-ivh" command. Where I have done it there I have create YUM server, so easily I have download and install it by YUM (yum install dhcp version). DHCP package will locate in /usr/share/doc/at Linux file system. I copied the DHCP's files from /usr/share/doc/ to /etc/dhcpd.conf.. Then I started to configure the dhcpd.conf file to route the DHCP server in there local network. I have open the configuration file with "vi" command. Then commented out the lines from "default gateway to option netbios" because system don't read the commented lines. After that I set the range of IP address in dynamic- bootp of their local assumption of system. I have change the "next-server" with the dhcp server name and have also change the fixed address with the dhcp server IP address (end range of dynamic IP). It is very easy job to configure DHCP server. After configure the .conf file of dhcp just turn on the service with "chkconfig" command and restart the dhcp service. After that entire job I reboot the system. And after rebooting of server I turned on the other client system. While startup the client system without static IP address all of those picked up IP from dhcp server and going on successfully. I have prefer the command line mode to do the total job.
The DHCP server configure file is following:
ddns-update-style interim
ignore client-updates
subnet 192.168.1.0 netmask 255.255.255.0 {
# The range of IP addresses the server
# will issue to DHCP enabled PC clients
# booting up on the network
range 192.168.1.201 192.168.1.220;
# Set the amount of time in seconds that
# a client may keep the IP address
default-lease-time 86400;
max-lease-time 86400;
# Set the default gateway to be used by
# the PC clients
option routers 192.168.1.1;
# Don't forward DHCP requests from this
# NIC interface to any other NIC
# interfaces
option ip-forwarding off;
# Set the broadcast address and subnet mask
# to be used by the DHCP clients
option broadcast-address 192.168.1.255;
option subnet-mask 255.255.255.0;
# Set the NTP server to be used by the
# DHCP clients
option ntp-servers 192.168.1.100;
# Set the DNS server to be used by the
# DHCP clients
option domain-name-servers 192.168.1.100;
# If you specify a WINS server for your Windows clients,
# you need to include the following option in the dhcpd.conf file:
option netbios-name-servers 192.168.1.100;
# You can also assign specific IP addresses based on the clients'
# ethernet MAC address as follows (Host's name is "laser-printer":
host laser-printer {
hardware ethernet 08:00:2b:4c:59:23;
fixed-address 192.168.1.222;
# List an unused interface here
subnet 192.168.2.0 netmask 255.255.255.0 {
on Mar 17, 2011 | Computers & Internet
Tip
How to add fast and efficient spot light to text... in windows 2000 and windows...
Follow these steps to create user classes in the DHCP console:
1. Open the dhcp console, right-click the server and choose Define user classes
2. Click add in the dhcp user classes dialog box and then specify a name. optional description, and class ID. the class id is the string you will configure on the client as that client`s user class.
3. Right click the scope options branch, choose configure Options, and Advanced
4. Select the user class from the User Class drop-down list and, in the resulting Available Options list, select and set the options that you want to apply to computers in the selected user class.
Thanks
Tips by uttam
on Jan 11, 2010 | Computers & Internet
When i try to open my mail box it shows application not found
Do you have an e-mail client installed? If it was, then something told the operating system to disassociate e-mails from that application. If you don't have an e-mail client installed, then pick one (Outlook, Thunderbird, old Navigator, and many others) and install it. But make sure the operating system associates your e-mail files with your new client. In Windows, the icon should change to something like an envelope. MacOS has something similar.
In Windows, you have two options to reestablish the link between e-mail files and the client.
#1. place your mouse over the e-mail file, then press the right mouse button (or which ever is NOT the normal selection button). Look for a drop down menu option that says "Open with ..." which should show you a list of installed applications. Your e-mail client should be in that list. If not, then click the "Browse" button (lower left section), and find your original e-mail client program.
#2. Start your e-mail client (should still be in the START-->All menu (or sub) somewhere). It will probably ask if you want it to become the default for all e-mails. If not, go to Preferences (usually under Tools, but might be under Edit), and (usually) Advanced tab/listing, and find something that says "make XXX (program name) the default...", and then save the new setting.
Good luck. (Since you didn't provide the operating system name or possible installed e-mail client)
Feb 19, 2011 | Computers & Internet
HOW DO I SECURE PRINT ON MY NEW M3035 MFP PRINTER
The 3035 supports a pin printing method. This is done from the print driver. Start a print job as normal, if you have Word or Exel you cannot use the quick print option. Once the print window opens, click on properties which is right next to the printer model name. then click on the job storage tab, select stored job in the job storage mode mode and click require pin and enter the pin number you want to secure the job with. The driver will default to using our windows username as the username that your job will appear under on the control panel of the printer.Click ok and then complete the print job as normal. Then go to the 3035 and select job storage from the control panel options and follow the steps to retrieve your job.
If you are searching for even more secure methods, Cappella Technologies makes a product that will encrypt the data stream between your computer and the printer.
Feb 10, 2011 | HP LaserJet M3035 MFP Printer
My microsoft outlook will not let me use it it says that my email profile isnt set . how do i set it
here we are providing you gmail client setting so
follow thies steps and configure your outlook
To set up your Outlook 2007 client to work with Gmail:
  1. Open Outlook.
  2. For new setups, select Do not upgrade.
  3. Click Yes.
  4. Enter your display name, email address (including '@gmail.com'), and password. Google Apps users, enter your full email address, e.g. 'username@your_domain.com.'
  5. Select the 'Manually configure server settings or additional server types' checkbox.
  6. Select Internet E-mail.
  7. Settings: name, full email address (including '@gmail.com' or '@your_domain.com')
    • In the Account Type dropdown menu, select IMAP; enter the incoming and outgoing server names shown below.
    • In the 'User Name' field, give your full Gmail address, including '@gmail.com' or '@your_domain.com.'
    • After creating these settings, clicking Next takes you to the end of the setup.
  8. In the Tools menu, select Options then Mail Setup. Under 'Email Accounts,' click E-mail Accounts.
  9. Select an account, and click Change above the list of accounts. Click More Settings, then the Advanced tab.
    • Incoming server must be 993, and must use SSL encryption.
    • Outgoing server can use 587, TLS encryption.
  10. Click the Outgoing Server tab. Make sure that 'My outgoing server (SMTP) requires authentication' is selected. The radio button 'Use same settings as my incoming mail server' should also be selected.
  11. Click OK > Next > Finish > Close > OK.
  12. Check our recommended client settings, and adjust your client's settings as needed.
if(document.getElementById('kb_ie6') != null) showLayer('kb_ie6'); if(document.getElementById('kb_ie6_win') != null) showLayer('kb_ie6_win'); if(document.getElementById('z_ie6') != null) toggleZippy('z_ie6'); if(document.getElementById('z_ie6_win') != null) toggleZippy('z_ie6_win'); if(document.getElementById('kb_ie') != null) showLayer('kb_ie'); if(document.getElementById('kb_ie_win') != null) showLayer('kb_ie_win'); if(document.getElementById('z_ie') != null) toggleZippy('z_ie'); if(document.getElementById('z_ie_win') != null) toggleZippy('z_ie_win'); if(document.getElementById('kb_win')) showLayer('kb_win'); if(document.getElementById('z_win')) toggleZippy('z_win'); if(document.getElementById('kb_winxp')) showLayer('kb_winxp'); if(document.getElementById('z_winxp')) toggleZippy('z_winxp'); if(document.getElementById('kb_IN')) showLayer('kb_IN'); if(document.getElementById('z_IN')) toggleZippy('z_IN'); if(document.getElementById('kb_non_US')) showLayer('kb_non_US'); if(document.getElementById('z_non_US')) toggleZippy('z_non_US');
Nov 29, 2009 | Microsoft Office Outlook 2007: Windows
Error Code ED09C7 when scanning to the shared Network Folder
this means the computer name and or passwordare incorrect when creating the one touch key in the user name and password fields the user name and password must match exactly to the name and password on the pc
Oct 29, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Outlook configuration
  1. Open Outlook.
  3. Click Yes.
    1. In the Account Type dropdown menu, select IMAP; enter the incoming and outgoing server names shown below.
    2. In the 'User Name' field, give your full Gmail address, including '@gmail.com' or '@your_domain.com.'
    3. After creating these settings, clicking Next takes you to the end of the setup.
    4. In the Tools menu, select Options then Mail Setup. Under 'Email Accounts,' click E-mail Accounts.
    5. Select an account, and click Change above the list of accounts. Click More Settings, then the Advanced tab.
  8. Click the Outgoing Server tab. Make sure that 'My outgoing server (SMTP) requires authentication' is selected. The radio button 'Use same settings as my incoming mail server' should also be selected.
  9. Click OK > Next > Finish > Close > OK.
Sep 03, 2009 | Computers & Internet
Hi, I have a Samsung G800 and it has an option to add numbers to reject list. I have done this for a couple numbers and would like remove them from the rejected list. How can I do this?
easy to solve this Go into phone menu/ settings/ call settings/ all calls/ now go to No.3 it should say "Auto reject(on), in the tab "Activation" just press left to turn off. Also you could press down to go to reject list, press centre o.k button and you can then just remove the tick from whichever name you would like to remove from the reject list press options and save. Job done. I hope this is of help to you. cheers.!!
Dec 31, 2008 | Samsung SGH-G800 Cellular Phone
Create personal signature and save as file
If you are talking about using Outlook as your email client, then here is the directions for creating a signature.
Create a signature for messages
If Microsoft Word is your e-mail editor, see Word Help. Word offers the most customization options for signatures.
  1. From the main Microsoft Outlook window, on the Tools menu, click Options, and then click the Mail Format tab.
  2. In the Compose in this message format list, click the message format that you want to use the signature with.
  3. Under Signature, click Signatures, and then click New.
  4. In the Enter a name for your new signature box, enter a name.
  5. Under Choose how to create your signature, select the option you want.
  6. Click Next.
  7. In the Signature text box, type the text you want to include in the signature. You can also paste text to this box from another document.
  8. To change the paragraph or font format, select the text, click Font or Paragraph, and then select the options you want. These options are not available if you use plain text as your message format.
  9. To add an electronic business card — vCard — to the signature, under vCard options, select a vCard from the list, or click New vCard from Contact.
  10. Click Finish when you are done editing the new signature.
Once you've created a signature, you can insert a signature in a message
Jun 12, 2008 | Microsoft Windows XP Home Edition
Sage Timeslips 2008 Full Version for PC (TSW2008RT) Logo
70 people viewed this question
Top Sage Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Clinton Daley
Clinton Daley
Are you a Sage Computer and Internet Expert? Answer questions, earn points and help others
