Question about Keurig Coffee Makers & Espresso Machines
The plastic disk is broken
The plastic disk that is around the puncture needle is completly broken. How do you fix that?
    Champion:
  • 213 Answers
Why can't thread tension be adjusted?
Upper thread breakage is usually caused by incorrect threading, the tension being too tight, or the thread is wrapped around the spool pin or catching somewhere in the thread path.
Remove the thread completely from the machine.
Install a brand new needle making sure it is compatible with the thread and fabric.
All About Needles
RAISE the presser foot and rethread the machine making sure it follows the correct thread path (consult the owner's manual). Verify that the bobbin is spinning the right direction in the bobbin case and the bobbin case is properly threaded.
Set the upper tension somewhere around the midway point between high & low numbers.
Retest.
If problems persist, there may be debris buildup stuck in the tension disk. Remove the thread. RAISE the presser foot, set the tension all the way to zero. Dampen a length of pearl cotton with rubbing alcohol and gently pull the pearl cotton DOWN through the tension disk a couple of times. Rethread with regular sewing thread, reset the tension to the midway point and retest.
If cleaning the tension disk does not help, then it is possible the tension disk is malfunctioning or broken. Take it for service.
Feb 22, 2016 | Sewing Machines
Broken pin stuck in S-Video port
1.) Find a needle 2.) On a hard surface, bend the very tip of the needle slightly so that it forms a tiny barb. 3.) heat the tip of the needle with a lighter until it glows red hot. 4.) stick the needle into the plastic core of the broken RCA pin 5.) wait a few seconds for it to cool 6.) pull the needle out, and the broken tip should follow!
Nov 16, 2013 | Daewoo DTQ-20U4SC 20" TV
DeLonghi Nespresso U not puncturing capsule
Not a fan of nespresso, a lot of cheap plastic. I am guessing the pivot for the capsule puncture arm has worn out allowing some play in it, which is keeping it from closing all the way just a guess, but it is an issue I have fixed before.
May 02, 2013 | DeLonghi Coffee Makers & Espresso Machines
How do I fix a puncture in my sleeping pad?
The best way to fix a puncture is with gorilla glue and any sort of water proof material. Just make sure the patch is completely sealed around the puncture
Jul 09, 2012 | Camping, Backpacking & Hiking
Coffee overflows and grounds sit on top of pod
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
May 18, 2011 | Keurig B60 Coffee Maker
Gasket - coffee grounds in coffee
hi! It goes on the top and surrounds the pin that pops the hole in the kcup....the problem I'm having is how do you stick it on? Should we use crazy glue?
Apr 03, 2010 | Keurig B70 Coffee Maker
Punctured inner bladder Tachikara SV-5 volleyball
Fix A Flat. Screw the needle valve into the noozle of a can of Fix a Flat. Squirt enough in to inflate to normal pressure, Roll the ball around to coat the inside. Blow the needle valve clear afterwards attached to a bike pump.
Jan 30, 2010 | Sport & Outdoor - Others
Coffee Makers & Espresso Machines Logo
437 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
