Question about Lexmark P6250 All-In-One InkJet Photo Printer
When I print pictures, there is a red and green line across them
I assume the printer needs to be cleaned? If that's correct, can I do it somehow?
Thanks
  • 39 Answers
Open the Lexmark Solution Center (shortcut should be in the Start Menu under Lexmark 6200 Series).
Click on the Maintenance tab.
Click on Clean to fix horizontal streaks.
If this doesn't help, you can try gently cleaning the nozzles manually using a cotton ball dipped in a little rubbing alcohol, then dry with a clean cloth. A little ink may come out when you do this and that's OK.
Posted on Aug 07, 2008
Will print a printed page with picture fine, try to print photo or any picture comes out with lines across
print heads need cleaning. check the tools/options maintenance for the print head cleaning option. It should be able to do a "self clean"
Mar 22, 2015 | Epson WorkForce 630 All-in-One Printer...
My Officejet 6000 E609n printer doesn't print the correct colors. The red is printing yellow and the blue and green are a lighter version of what is on the screen. I have cleaned the printer head
This is not a cartridge issue. IT is Printhead issue. Since you have done the manual cleaning, it is now time to replace the Printhead.
Regards,
Suhail
May 14, 2012 | HP Officejet 6000 All-In-One InkJet...
Horozontal lines across picture
hai there...go to control panel,click prnter and fax.now choose your model printer,right click the model and go to properties...and then click maintenance...you will see a clean button and deep cleaning button...just click the deep cleaning and your printer will clean the cartridges automatic...
Feb 25, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Red and blue lines across printouts
open printing preferences and click on maintenance. Run the print head alignment utility. Sometimes this will remove the horizontal banding. I had this same problem and had to uninstall the printer and reinstall just like it was new, running the alignment feature before it was corrected. Worked ok for a few days then started again. I assumed that the printhead is bad. To costly to repair and bought a new printer.
Jun 27, 2009 | Epson Office Equipment & Supplies
PIXMA iP90, all the pictures come out really faded..new ink,
I've cleaned it every which way..but still all the pictures print out really realled faded with slight lines horizontally runnung across.
Mar 01, 2009 | Canon PIXMA iP90 Mobile Printer
Poor picture printing
Do not try to clean print head again and again, it consumes too much of ink.
Try reseting print head and then calibrate it.   after then check nozzles and align prinhead.   Now u can try cleaning printhead last time.
If it does not fix your issue , your printer needs to be replaced  (In case printhead has already replaced within 30 days)
MS
Dec 22, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Orangy red lines across the pictures
You will need to replace the cyan cartridge and do a print head clean. You can clean the head through the menu on your control console on the printer. In your control console, you will also find a thing called a nozzle check. If you print this out you will find that there are missing lines in your cyan. A printhead clean should fix this.
Gremlin11
Dec 12, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Horizontal colored lines through grayscale printed photos
Hi George,
It sound's like an ink-feed issue:
1) Dirty heads, even after cleaning
2) No-ink or poor quality ink
3) Damaged head: some are part of the cartridge, some are not
4) Air bubbles in ink
The test page is typically not as hi-res nor as saturated as a
photo print. The hi-res photo puts the greatest demand on the print head.
The color lines you see are actually lines of missing color,
where the head has failed to deposit ink, so one or two primary
colors are missing from the complete picture.
For example missing yellow will make a blue line.
Missing magenta will make a green line
Missing cyan will make a red line.... etc..
Clean the heads again and again, print again and again,
hoping to flush the system.
BUT, keep in mind that cleaning wastes huge amounts of
ink and tiny little cartridges of ink cost more than many new printers.
Martin
Apr 24, 2008 | Canon PIXMA iP90 Mobile Printer
Red lines across page
What program are you using to print the pictures? Try cleaning the print heads and using another program.
Feb 20, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Vertical lines
1. Took out the ink carts and cleaned the copper contacts of both the ink carts.
2. Clean the copper contacts on the ink carts slot in the printer and then insert the ink carts in the printer and then print out the page.
Dec 11, 2007 | Epson Stylus C60 InkJet Printer
Lexmark P6250 All-In-One InkJet Photo Printer Logo
82 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
