Question about Sharp Microwave Ovens
Re: Sharp carousel microwave oven minute display light out
Re: Sharp carousel microwave oven model-R-610DSA
The microwave works fine but the light has gone out on the door where the minutes show. Can a bulb be replaced? Is that the problem? Can you help me?
  • 3,051 Answers
Hello there
To replace the light you will first have to remove the outer shell.
To do this
(1). Remove all of the screws on the back of the microwave that hold on the shell
(2) Remove the screws that are on the bottom.
(3) now the shell should slide off towards the back of the microvave.
Note : this may take a little bit of pressure to get it off ok?
(4) Once the cover is off look towards the fromt of the microwave and
you will see the bulb. now just replace the bulb and reinsert the cover and the screws and you are all done ok? pretty easy ha/
best regards michael
Posted on Sep 28, 2009
MODEL R-395Y sharp carousel microwave not working. All power outlets are fine. Please help, cheers lyn
I was unable to locate a service repair manual specific to your microwave; sorry.
You'll must likely have to find a Sharp service and repair center.
I've attached a link that contains the user's manual to your microwave...it has the phone number and address of Sharp; perhaps you can phone them and ask where a repair center is located.
This is the diagnostic check list Sharp recommends before calling for service:
SERVICE CALL CHECK
Please check the following before calling for service:
1. Does the display light up?
2. When the door is opened, does the oven lamp come on?
3. Place one cup of water (approx. 250 ml) in a glass measure in the oven and close the door securely. Oven
lamp should go off if door is closed properly. Press the INSTANT COOK/START pad once.
A. Does the oven lamp come on?
B. Does the cooling fan work?
(Put your hand over the rear ventilation openings.)
C. Does the turntable rotate?
(The turntable can rotate clockwise or counterclockwise. This is quite normal.)
D. After one minute, did an audible signal sound and COOK
indicator go off?
E. Is the water inside the oven hot?
If "NO" is the answer to any of the above questions, please check your wall socket and the fuse in your meter box.
If both the wall socket and the fuse are functioning properly, CONTACT YOUR NEAREST SERVICE CENTRE
APPROVED BY SHARP.
Sharp Carousel 395Y Operation Manual And Cookbook
Feb 22, 2017 | Sharp Microwave Ovens
Sharp Carousel Model R-1874 no heating or turning, display works
sorry without seeing the machine we can not help try whatever you want . that is how many of us learned what we know today
Nov 17, 2017 | Sharp R-1874 Convection/Microwave Oven
Sharp microwave stopped working
Is it totally dead? No display? Or just does not cook? If it made an unusual noise before it 'died' something probably shorted out.... You need an ohm meter to troubleshoot. If the fuse is open, switches and HV circuit need to be checked before replacing fuse. Sometimes on the convection Microwaves (not just Sharp) the fuse will 'rust' and open rather than blow. Or the fuse holder can over heat and fail.
Sep 11, 2009 | Sharp Microwave Ovens
Hi our Sahrp Carousel microwave LCD panle display is not working
You have to replace the control board. Sharp has had problems with the display boards for awhile. There is no bulb or fuse you can change.
Mar 15, 2009 | Sharp Microwave Ovens
Sharp Carousel Microwave oven
Assuming the unit works ok other than the display, you have a problem common to many Sharp models.
Check with www.microwavedisplay.com - lots of info on this issue and they offer a repair service for the boards at a very reasonable price.
Jul 10, 2008 | Sharp Microwave Ovens
Sharp Carousel Model R9H84B
I've attached the portion of the manual which shows how to lock & unlock this model.
If that doesn't work, unplug the oven for one minute, plug it back in aga9in, then try again.
If it still doesn;t work, then your keypad has failed, and they are no longer available for these model, so the oven would have to be retired.
Good luck.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 03, 2008 | Sharp R-230 Microwave Oven
Sharp Carousel Convection Microwave R-9H56 suddenly stops heating
at highvoltage section wiring may bae problem, check wiring and connectrors of magnetron and capacitor and transformer.
Dec 11, 2007 | Sharp R-510HW Microwave Oven
Microwave Ovens Logo
382 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
